[ QUOTE ]
Hi Amb276s3,
I've got the Woodstock too and just ordered the external glass mount antenna.
Is this, in your opinion better than the internal antenna.?
Sorry, don't have an answer to your question, not had the pleasure of dab yet.
[/ QUOTE ]
The best reception will be gained with a bodymount external antenna, you can either drill a new hole and fit the dab antenna, or you can swap the existing vw/audi roof mount antenna for a dual purpose FM/DAB type (these are expensive), both methods require a seperate aerial cable running from head unit.
i simply drilled a new hole in the roof of my sprinter as i am not convinced about sharing one aerial for both FM and DAB but thats just my opinion they supposedly work well.
I had a external glass mount before on my old van and suffered from signal loss, this could have been because i had it mounted in the middle top of the screen where the 'sun shady black perforations' are, but i would have thought the fact that there is a piece of glass splitting the contact of the antenna can't help,
I was not aware you could get an internal antenna, i thought dab relied on at least a glass mount external one, are you sure that this is not just a mobile phone antenna?, could work though they all seem to be made the same way.
