Just picked S3 up, love it! Couple things to do...
-Keith- Jul 1, 2013
  1. -Keith-
    -Keith- Member
    84
    41
    Hi guys,
    '57 plate, 3 door, black... Love it! Great torque and pace, effortlessly sees you doing 100 without even realising. Bose system is wonderful too! Wife is very pleased (it's her new car).
    Still en route home south on the M6... Will do a proper post later to show you it, but right now (whilst I have iPhone reception!) I have a few things to ask that I noticed and want to sort ASAP.
    1. Rear wiper flaps a bit - it seems to missing a spring or something to keep it taught against the rear glass. This isn't normal I presume. Can anyone give the part number for the spring, or do I need an entirely new wiper arm (again, part number)?
    2. Being from BMW's I use an online parts catalogue database called realOEM to get part numbers. Is there an Audi/Vag site I can use to find bits myself?
    3. Can an armrest be retro fitted? Probably requires new centre console piece too? Am I best off waiting for a second hand one to come up or can all the bits be bought new reasonably?
    Thanks for the info, look forward to showing you the car in more detail when home and had chance to give it a good clean :)
    Cheers,
    Keith
    Kelza likes this.
  2. phil76
    phil76 Active Member
    572
    40
    Hello and welcome
    It would required new or second hand wiper arm
    Vw/Vag parts catalogue is called etka but you have to pay for the full service but i am sure people on here will help you anyway they can if they have it
    And the centre arm rest can be retro fitted,you just have to cut a square out of your centre console and buy the bolt as the threaded insert is already under there.
    get some pictures up !!
  3. sliced
    sliced Drive safe, stay alive.
    1,562
    334
    1. Probably arm, I couldn't find a spring for my rear wiper.
    2. ETKA
    3. yep it can be retretrofitted, think NHN on the forum does retrofits
    And finally congrats :D
  4. Sidhu88
    Sidhu88 Active Member
    808
    76
  5. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,457
    597
    Remove rear wiper all together - looks a lot sleeker without it
  6. Sidhu88
    808
    76
    +1... although mine never worked which is y i removed it
  7. -Keith-
    -Keith- Member
    84
    41
    Thanks for the tips guys, appreciated :)
    From a quick bit of research it seems there is a plastic spring retainer that goes brittle and breaks off in the wiper arm, causing the floppy wiper. A new OEM one seems reasonable so will get that ordered - don't want to remove it for looks.
    Is there any known decent factory supplier of OEM mats so I can get the quality without paying dealer prices? If not I'll just go genuine, although I expect them to be £70+ for a set?
