Just installed rnse
vwgtiking Jul 26, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,030
    I haven't had my oem stereo for a while now. Just installed my new rnse an wanted to check that the stereo slightly overhangs the climate control? Ie not flush?
  2. s8craig
    1,756
    56
    On an A4 unit the stereo sits over the air con, it is not flush.
  3. vwgtiking
    1,030
    Fair enough.
  4. vwgtiking
    1,030
    Also. Are the directions suppose to show up on the top fis on clusters?
  5. s8craig
    1,756
    56
    If you have a RED fis then it's a bit hit and miss, with the colour FIS it can take upto 24 hours to appear, if everything is coded correctly, radio, instrument cluster etc the directions can be made to appear on the RED fis by powering off/on the RNS-E when a route has been selected i'm led to believe.
  6. vwgtiking
    1,030
    Hi Craig thanks. I am unsure what coding I need to do I added 4 to instrument coding but unsure on radio or
    Navigation.
  7. s8craig
    1,756
    56
    Well the ross-tech wiki is a good place to start.
  8. vwgtiking
    1,030
    Directions now work on cluster!!
  9. Mav190sline
    Mav190sline Active Member
    203
    29
    Hi. Sorry to hijack but I did this retrofit quite a while ago but do not have directions on red dis display. How do I get it to work
    Mark
  10. vwgtiking
    1,030
    Set a route, start engine, stop route then restart route. That should work. I also have a dis stalk so can choose to display it or not.
  11. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    But that only works AFTER you've changed the value in adaptation channel 62 of the instruments, see Audi A4 (8E) Instrument Cluster (8EC/8ED/8HE) - Ross-Tech Wiki
  12. Mav190sline
    203
    29
    Thanks. Will try that later
