Just had 1st Audi 'Variable' Service and ......
Jonesy3.2 May 28, 2007
  1. Jonesy3.2
    Jonesy3.2 New Member
    10
    according to the DIS I've got to take the car back in 9400 or 364 days!:wtf:
    my cars' a 3.2 05 - over 18mths old & has covered 18500 before it required it's 1st service.
    This can't be right can it? Have the audi technicians reset the comp to fixed service interval in error? - They've definately put in longlife oil. Anyone else had this problem?
    As a side issue, I think £310 for dropping the oil & replacing filters is disgraceful. Audi couldn't even be ***** to wash it properly (quick going over with the jetwash) & the light grey carpets have several oily boot marks on both driver & passenger side. Nice!:crying:
  2. h5djr
    9,465
    1,772
    You should have read the 'sticky' AVS Servicing thread before-hand. The car is not serviced by Audi but by one of their dealers who are independent companies that decide their own labour rates. You could get a 1st AVS service for a lot less that £310.
    If there are marks on the carpet that were not there before the service, go back to the dealer and complain. My car always comes back to me with a plastic seat cover on the drivers seat and brown paper covers over the carpets, even after it's been washed and vacuumed.
    You may find it takes a while for the DIS display to settle down again.
  3. Dandle
    Dandle Member
    852
    My first service at Walton Audi was £154. Its normal for the next service to say about a year, it will alter as the car is driven the more long drives you do it will go up.
  4. Audimad
    Audimad Well-Known Member
    672
    276
    The AVS/DIS resets itself after a few days and it sets itself to your driving style, if you drive steady until it resets itself then you should see at least 18000 miles before your next service, if on the other hand you drive like a mad thing then you will need a service much sooner. That is what i was told when i had my first AVS/DIS so i drove steady and my next service is due in 18000 miles.:icon_thumright:
  5. h5djr
    9,465
    1,772
    The 1st AVS service does include more than just changing the oil...
    check all the lights, front and rear
    read the fauly memory for any problems
    check the windscreen washer and wiper system
    check all the tyres
    check for oil leaks, check all protective bellows for wear
    check all brake pads
    check battery level
    check brake fluid levels
    renew the dust and pollen filter
    road test the car
    The total labour time allowed by Audi for the 8P A3 id 1.10hours. The main variable between dealers is their hourly labour rate and the amount they charge for the longlife oil.
  6. Amchlolor
    Amchlolor Active Member
    5,604
    You mean "refill and charge for Audi windscreen fluid,even if bottle already full"
  7. h5djr
    9,465
    1,772
    Your dealer may, but mine does not.
  8. Amchlolor
    5,604
    Don't know if mine does or not,but it's a widely reported practice (rip-off) on here.
  9. S3-ROB
    S3-ROB RD350YPVS - Loves 2 stroke oil
    182
    Alot of main dealers do this so i've heard, not just Audi but all makes
  10. Amchlolor
    5,604
    Oh well,that's alright then...
  11. MiT
    MiT Work Hard, Play harder!!
    270
    19
    Just to add when i had my long life service, only 2 months ago, it says i 13500 miles left!!! and its meant to be a 20,000 service...but as i have read it depends on the driving style. I drive 10 miles to work and back, through the city, so a lot of gear changing and starting and stopping. I guess thats why the milage is already so low.
    Edit; cost £250 beechwood audi, birmingham, uk
  12. jasaudi
    jasaudi Member
    144
    Dandle - how do you find Walton Audi?
    I have just bought my car from them
  13. Dandle
    Dandle Member
    852
    I had a few problems when I turned down my first car i ordered where they wouldnt match the new price(the special edition came out the same spec as mine was but £2k cheaper). I just cancelled it and reordered the car I have now. The customer service is good Jenny always says hi and asks how we are and is the car ok. I've had a couple of problems with the car and they have always sorted them for me without any hassle. The service was the cheapest I have seen anyone pay as well. I would deffinately buy my next Audi from them(If its a new one).
  14. steve184
    steve184 Active Member
    1,138
    yes - this happened to me - pissed me right off - i purposefully filled my washer tabk up before i took it and they still drained it and put fresh in - what a rip off - i had a right go at them about it - apparently you need the aid of a crystal ball to tell them not to do it before you leave your car for a service.
  15. Vertigo1
    Vertigo1 Well-Known Member Team Navarra Audi S3
    3,815
    891
    Don't care what they do with my washer fluid as I ain't paying but I do tell them not to wash it and stick a large notice to this effect on the steering wheel!
