Just got the car serviced and....
Defratos Jun 6, 2007
  1. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Had a few questions on things I could do to check the work was properly done. Ok it was the 60,000k service I changed the lot, cam belt & tensioner, water pump, changed haldex oil & filter change. and the usual longlife service inspection. Now how can I check if the below parts have truly been replaced:
    1) cam belt & tensioner
    2) water pump
    3) Haldex oil, on this one I've got more questions. Is the car supposed to feel really light after a haldex oil change? cause mine feels soo different all of a sudden, I mean jerking the car right and left seems to bring the back in either faster or smoother than before (if that makes sense) just wanna know how your cars feel after a haldex oil change?
    Other than that I checked the engine oil my self and seems to have been changed to some nice new clean syrup. The reason why I'm being a bit anal is because VW told a friend of mine that they did a haldex oil & filter change and it turned out they did nothing. (Oh and they forgot to stamp my service book, so I'm going back tomorrow) any feedback appreciated. I will post the service details in that other section for anyone who wants more details :beerchug:
  2. s3ollie
    s3ollie Member
    762
    you wont feel the haldex oil change. maybe check the drain plug and see if its be removed/replaced??
  3. S3_MCD
    S3_MCD Member
    389
    Disagree have always felt a big change when haldex oil (and esp filter) are changed. Back cuts in alot faster, far more responsive in keeping things in check....
    ..Ollie, maybe you havent been pushing hard enough :)
  4. s3ollie
    s3ollie Member
    762
    cant say i felt the difference when i had mine done. maybe they didnt do mine either :keule:
  5. rodenal
    rodenal Active Member
    1,992
    Dunno how you could tell about the tensioner, but if your 60k sevice wasnt too long ago, pop the cambelt cover, and turn the engine until you can see the writing on the belt, it should still be bright - if its not, or if its not there then be worried.
  6. Defratos
    2,232
    That's what I would have thought. I guess it has been changed as I can see the rear much more responsive from before. cheers
  7. Defratos
    2,232
    Cheers again, I would have thought that's the easiest way to check if it really has been changed, :beerchug:
