Just got a 1.8T Quattro! Need 2 tyres - which make?!
Cossie_boy May 10, 2007
  1. Cossie_boy
    Cossie_boy Member
    472
    Hi all,
    Picked up my little baby last night! :hubbahubba:
    Its an 02 A3 5 door 1.8 T Quattro Sport!
    It needs 2 new tyres on the back so im trying to decide what to buy.
    The front has 2 new tyres which are the Bridgestone RE 040 Y rated ones
    The back has Bridgestone S-03 Y rated, but im guessing these could be an old model as cant seem to find them anywhere on the net?
    So do I get two more RE 040's so all 4 match, or go for 2 Goodyear Eagle F1 GSD 3 tyres? which ive been a fan of!
    Any advice much appreciated
    Dave
  2. Randomjim
    Randomjim Active Member
    2,752
    I've just got some RE 050A's from mytyres they must be the new version.
  3. Jampublic
    Jampublic Taking it easy..
    974
    12
    Well loads of choice on this subject, I am running Pzero's great all round tire. Works in the wet and the dry! :)
    So i trust you will post us some photo's of your new purchase!!
  4. Randomjim
    2,752
    This is the RE050's i got today dunno if they're similar to the ones you already have.
  5. Jampublic
    974
    12
    18's your showing off!
  6. Randomjim
    2,752
    :moa:
    £100 quid a tyre though :(
  7. Jampublic
    974
    12
    Pzero's £105!
  8. Randomjim
    2,752
    Is that how much yours are?
  9. Jampublic
    974
    12
    Yep sure is!
  10. Randomjim
    2,752
    Ouch what size are they?
  11. Jampublic
    974
    12
    17inch..:faint:
  12. Randomjim
    2,752
    Have you tried mytyres?
  13. Jampublic
    974
    12
    Mytyres, no i just use a local company down the road, or Headley Tires near Newbury!
  14. Randomjim
    2,752
    Guessing at your tyre size 225/45/17 £90 each on mytyres for p-zero rosso's.
  15. buckas
    buckas Member
    749
    mine came with goodyear GSD3 oversizes and michelin pilot premacys
    both great tyres in all conditions :sm4:
    (the dealer will probably stick semperits on it, also a good tyre in all weathers)
    drew
  16. TheSpaceCowboy
    TheSpaceCowboy Member
    520
    This has been debated many times before and I think its mostly down to personal preference, I'd go with P-Zeros.
  17. Cossie_boy
    Cossie_boy Member
    472
    Yip ill post some pics once ive given her a wash down :yes:
    So the Y rated should be ok? or would Z be better?
    I know I had the Zero Rossos on my Golf and liked them so may consider them again, steering well clear of P6000's tho!
    They seem to have run over inflated on the rears as have only gone in the middle :tocktock:
    Does anyone know the correct pressure? their 225/45/17's
  18. buckas
    buckas Member
    749
    look on the sticker on the inside of the fuel flap and it's also written on your sidewalls of the tyre itself
    drew
  19. CLS3
    CLS3 Every penny goes on the Audi!!
    100
    I may be totally wrong, but if you are changing tyres on a Quattro, is it not advisable to change all four? and also have all four the same make and model?
    I think in this case if you get 2 more RE040 Bridgestones for the back then that would be perfect.
    Thanks Chris
  20. Jampublic
    974
    12
    :iagree:
    Something like no more than 3mm difference, something about effecting the diff! Or something technical like that! :ermm:
  21. Tooks
    Tooks Active Member
    753
    30
    You don't need to worry about the tyre depth thing front to rear on a Haldex equipped car, as the Haldex system was designed to cope with it.
    That particular nugget only applies to permanent 4wd Torsen equipped cars (ie A4 up etc).
