just fitted s3 satnav
damo2009 Sep 1, 2010
  1. damo2009
    damo2009 New Member
    29
    need a bit ov help ive just got hold ov a s3 satnav double din cage and double din air con
    my a3 add the single din in it
    when fitting it will i av to av it all programed to my car if so does anyone no ov anywhere in the manchester surrounding areas that i can gett it fitted properly
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    its likely you will but if you arent rnning any goodies like bluetooth or a changer you may get away with it, enjoy fitting the double din cage in, csan be a bit of a bugger first time round
  3. Smoothie
    Smoothie Active Member
    1,431
    kind of taking on this mod aswel, gathered most of the parts now, just Bluetooth needed so should be next week with any luck! Although I will be getting a local guy to do the fitting/coding as experience as experience serves best with these sortt of things
  4. damo2009
    damo2009 New Member
    29
    you say a bugger what you mean i dont have to cut anything do it
  5. Smoothie
    1,431
    no there's no cutting if you've bought a double-din climate, but getting the cage in is meant to be time consuming as it was never meant to be taken out/put in that way
  6. damo2009
    damo2009 New Member
    29
    were will i get somone to do mine iam in manchester
  7. sub39h
    sub39h Active Member
    2,502
    tclsatnav. google it.
  8. damo2009
    damo2009 New Member
    29
    is that in manchester
  9. PH1L
    PH1L Gievf Buckets
    3,851
    40
    no but it is easier if you remove the dash, trust me
  10. davej_anderson
    davej_anderson Member
    261
    I'm glad you guys understood Damo's English, I didn't have a clue the first time I read his post :sly:
  11. edition
    edition Active Member
    1,426
    Hehe tis like txt speak innit bruv.
    I did single to double din conversion on a evening on the drive in the dark... You should manage ok!!
  12. damo2009
    damo2009 New Member
    29
    av you ever done it before
