jUSt fitted H&R and perch plate, question though
schmergal Feb 25, 2013
  1. schmergal
    schmergal Member
    114
    Just today fiited H&R and front perch plates, car looks shweet (photos to follow) but camber seems very severe at front and steering feels weird, normal or not?
  2. Steve220
    Steve220 Member
    234
    15
    Have you had the car's geometry set up?
  3. schmergal
    schmergal Member
    114
    nope, was gonna wait till a fitted spacers which i havent ordered yet
  4. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Correct me if I'm wrong but wheel spacers shouldn't affect the geometry as essentially you're only changing the offset of the wheel (bit like fitting new wheels).
  5. schmergal
    schmergal Member
    114
    ur prob correct but just incase, is there a camber adjustment?
  6. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    The B7 has camber adjustment on the rear, not too sure on the front.
  7. ajax1976
    ajax1976 Well-Known Member
    1,256
    649
    Pictures!!!
  8. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    not on the front
  9. schmergal
    schmergal Member
    114
    well then im ****ed cuz the camber on the front is severe, almost undriveable, maybe ive done summit wrong?
  10. hades-
    9,480
    646
    sounds like it
    iv seen them fitted a few times b4 and after tracking and there not that bad to be honest
    have you got a pic ?
  11. schmergal
    schmergal Member
    114
    also replaced both upper control arms either side while i was at it????
  12. schmergal
    schmergal Member
    114
    ill add a pic 2moro night
  13. hades-
    9,480
    646
  14. schmergal
    schmergal Member
    114
    sorry still no pics as on 12 hour shifts and dont see daylight, had a look at car earlier and the toe is also severe, both wheels pointing in at front as well as camber in at top, ive had to park it up for now until i get to the bottom of it, any suspension experts on here? going to contact the control arm supplier and double check i was sent the correct parts, pure bummer1
  15. ajax1976
    1,256
    649
    Valuable lesson, compare like for like when changing things, always check lengths, centres etc.
  16. Steve220
    Steve220 Member
    234
    15
    You'll need to get the geometry done in order for the car to drive properly, lowering it will put it right out of tolerances. More often than not, when severely lowering a car, you will need camber top mounts to go with it. But as i have no idea what you've fitted, how low your car is or whether you've done it properly, it will be difficult to diagnose.
  17. ajax1976
    1,256
    649
    Quite sure he's aware of that but think camber top mounts are a bit extreme for 35mm lowering springs and B5 perches. Considering the amount of people who run identical set ups with no problems the issue is more likely to be with the replacement upper arms?
  18. ajax1976
    1,256
    649
    Did you get this worked out yet Schmergal?
  19. schmergal
    schmergal Member
    114
    I did yeh, just got it back yest, upper front control arms shorter so was pulling toe and camber in, got off ebay in 1 of those kits so need to get onto them now to get replacement, just put old 1`s back in, height also raised slightly again at front so sitting perfect.
    Im liking the ride now to, apart from going over speed bumps the general ride is improved, getting a wash 2moro so will add photos, wheel spacers next, cheers for the help to all above.
    She also got debadged and cupra splitter
