Just fitted an RS4 Rear Sway Bar - WOW!
Richardesty Jul 4, 2009
  1. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,462
    3,026
    Do it; you will be delighted.
  2. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Added this onto the to do list for this year...:respekt:
  3. AudiB7Jay
    AudiB7Jay Active Member Audi A4 S-line owners group Team Aruba Blue saloon TDi Manual
    451
    27
    i think I agree, apart from I'm not confident with fixing my audi xD I don't want to break it xD fancy helping me out? Also is there a front arb too?
  4. Purdy99
    Purdy99 Member
    90
    Reading the whole thread i think someone mentioned that most of the Front ARB's are the same size, but i'm not going to confrm that lol, as for fitting it, it is a pretty easy job you cant really go wrong... altho.. sometimes it does lol
  5. jdp1962
    8,462
    3,026
    You don't need to change the front anti-roll bar. The front bar is the same for all models. Keep in mind that increasing rear roll stiffness reduces understeer. So it follows that increasing front roll stiffness (by fitting a thicker front bar) would have the opposite effect.
  6. AudiB7Jay
    451
    27
    Currently I'm on stock sline running gear n tbh it's very sloppy, I'm hoping to fit these coil overs but while I'm there may aswell do arb's at the same time I guess?
  7. robotplant
    robotplant Member
    154
    Seems like this needs to be done! I will check the drop links this weekend to see whether I need new ones or not. Will post with results when fitted also
  8. Tolak
    Tolak Member
    238
    19
    Being old-fashioned, I think of ramps as being the wedge shaped metal frameworks that cause teh wheels to continue to support the weight of the vehicle, but approx 10" above the ground.
    And the original hydraulic ramps are moving "wheel tracks" that can be raise many feet into the air.
    Can you not use either of these to install the RARB, or will I *have* to get the car on the ground to bounce the suspension to settle the mounts before completing the clamp tightening?
    A hoist, however, may allow the wheel to be hanging free, as is needed for many servicing operations (but not this one)
    Obviously, if you let the wheels hang down, then the shape of the ARB is extended slightly (end to end), and so cannot be fitted without excessive force.
    I'm surprised about the comment about the bush sizes; too much sticking and there will be residual lean, but too slack, and the roll-resistance will be decreased. So fitting the "A" bushes to the 22mm ARB might be slightly sticky, and will be worst when initially fitted, and will only wear into a "better" more nominal state. Of course, fitting the right "D" bushes to the 22mm ARB will have the right level of "give" to reduce vibration, etc.
  9. Tolak
    Tolak Member
    238
    19
  10. rhinoman
    rhinoman Member Team Silver Audi S5 quattro Audi Cabriolet Owner Group
    117
    14
    Love the difference it made to my cab.
    jimbooboo likes this.
  11. Tolak
    Tolak Member
    238
    19
    Thanks for the reply.
    I will put this on the list; :) yet more card pain! :(
  12. Big Al
    Big Al Active Member
    489
    68
    I recommend the RS4 RARB too, see my build thread for details, part numbers, costs & photos.
  13. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I fitted one to my cab and it made such a difference. For the cost it's a good modification to do.
  14. Steve77
    Steve77 Member
    70
    Got mine in today to get this done. Can't wait to get it back.
  15. Tolak
    Tolak Member
    238
    19
    Ordered the bits on Saturday from Audi for just under 140 GBP (including bolts for exhaust and drop-links)
    Awaiting delivery, and then good enough weather to get out and install.
  16. Tolak
    Tolak Member
    238
    19
    Bits have arrived, but then so has the weather.
    Next stage is to get some free space in the garage, and then some free time to enjoy that space!
    maikysupra likes this.
  17. dpaz
    dpaz Active Member Team Tango
    528
    115
    43
    Fitted mine last Saturday. Roundabouts are now a completely different experience.
    Best description I can come up with is that fitting an RS4 ARB "sure's up the back end".
  18. Yeti3.0tdi
    Yeti3.0tdi Member
    30
    In two minds wether to get this done...Luke from east Kent Audi said the cabs only show an S4 as the biggest bar but on the avant of course they have the rs4 bar...does anyone think the rs4 version would be a problem for the cab?
  19. rhinoman
    117
    14
    Got an RS4 one on mine.
  20. Yeti3.0tdi
    Yeti3.0tdi Member
    30
    Whats the verdict? Or did I need ask the question lool
  21. rhinoman
    117
    14
    I said earlier in the thread, love it.
  22. Tolak
    Tolak Member
    238
    19
    One of the benefits is meant to be that it reduces the understeer, so it "sures up the front end", as well.
    Moving the action of keeping the car flat to the rear wheels means the front can be left with lower task loading, and can keep the two tyres at even contact force, so both wheels contribute to the steering. When the rear is softer, the front has to help keep the car flat, and so the inner wheel has lower contact force, and helps less with the steering.
    Ultimate is when an inside rear wheel lifts, and the car is in tripod mode; at this point, the rear axle has done (almost) all it can to keep things stable, and the front has to start compromising its down-forces.
  23. Just Rob.
    Just Rob. Moderator Staff Member Moderator Team Daytona TFSI Owners Group Team V8 VCDS Map User Gold Supporter Team Brilliant Black Audi RS4 quattro Audi A4 Audi Avant Owner Group S-line owners group Manual
    5,141
    1,787
    Just been reading start to finish on this , sounds like the way to go.
    As there has been no updates for over a year i wanted to check what the situation is re part numbers.
    I was going to order parts this week but would like to check the definative parts listing /reqiurements as of june 2014 to ensure i get the correct part numbers etc.
    any updates would be great guys .
    rob
  24. A4-gam
    A4-gam New Member
    Where do people reccomend getting these parts? the ARB from Audi has literally doubled since this post
  25. SDHA4SLine
    SDHA4SLine Well-Known Member Team Silver Audi Avant Owner Group S-line owners group
    2,631
    522
    Usual Audi tactic of supply & demand pricing structure :mad:
    I can imagine the yearly Audi pricing meeting probably goes like this....
    "Soooooo a lot of people really want these hey, hmmmm, I know rather than lower the price to encourage higher turn over we shall increase the price to punish our loyal customers! great idea ya? "
    Vorsch sprung durch technik my ****, more like progress through extortionate pricing structures :audibash:
    darren t and gary_a4_quattro like this.
  26. SDHA4SLine
    2,631
    522
  27. Just Rob.
    5,141
    1,787
    yep, rushed out just after getting the car to get one, ordered it up, went to fit it and found out i allready had one fitted:think:, anyway took it back and got a refund, but a great mod:cool::) .
  28. jdp1962
    8,462
    3,026
    Dealer or TPS are probably the only options.
  29. lowlife89
    lowlife89 Member
    193
    22
    This is the WRONG code. It is exactly the stock part number we all have on our cars!!!
    The correct upgrade/RS4 part number is: 8EO 511 439.
    Someone please double check and edit the original post.
  30. Jeebsy
    Jeebsy Active Member
    157
    44
  31. maxdrz400
    maxdrz400 Active Member
    198
    74
    Jeebsy likes this.
  32. Jeebsy
    157
    44
    Good to know, thought it would be just be same as the RS4 so for similar money the 034 is worth going for
  33. Giosabcsl
    Giosabcsl Active Member Audi A4 saloon
    853
    156
    43
    My advice would be don't believe everything you read. What people say is one thing but the effect it has may be another.
    And that's not to say the 034 kit isn't good. I am just saying its kinda ripple effect and causing the opposite effect well in theory at least.
    So you may be thinking what is this guy going on about.
    Well let me help explain the stock ARB on a saloon Quattro or estate Quattro is tiny in comparison to the RS4 on the rear, were as the DTM edition and s4 have thicker bars at the rear. You will notice there is no mention of anyone changing the front bar and the reason for this is physics.
    The physics of putting a thicker bar on a 4wd car helps prevent understeer and will aid for front end turn in. That's not to say it will remove all the understeer as naturally the rear of the vehicle will be pushing forward and the front wheels will be turning so the nature of Quattro is understeer. That said not everyone will experience this limit on a public road.
    But the point I am trying to get across is if you going to put a thicker bar at the rear great. If you going to replace both you kinda defeating the point of putting a thicker bar in the front. Yes the vehicle will feel more solid and planted in corners but the over steer will be more pronounced than a vehicle with a smaller bar in the front.
    I hope this helps and that the explanation is easy to understand.
    maxdrz400 likes this.
  34. Just Rob.
    5,141
    1,787
    well put that man , also allways check with a gauge what size arb you have fitted as it may not be as expected.
  35. maxdrz400
    198
    74
    Yeah i get what you are saying, i was planning on leaving the front alone anyway.
    My thoughts at the moment are stock bar is 18mm i believe, rs4 is 21mm? And 034 is 25mm, surely if you are going to upgrade anyway it makes sense to get the best you can afford.
    Now i have also read, that different manufacturers bars will handle differently with different size in mm's
    Say a 25mm 034 bar might not be any stiffer than a 22mm h&r bar (purely an example)
    So assuming the 034 bar isnt much stiffer than an rs4 (even though people report it to be) its got to be a good investment for £160 when compared with the cost of other arb's on the market
    Jeebsy likes this.
  36. Jeebsy
    157
    44
    "In addition, the 034Motorsport B6/B7 Audi A4/S4/RS4 Rear Sway Bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is needed or required."
  37. lowlife89
    lowlife89 Member
    193
    22
    Damn, wish I'd seen that link before I got my RS4 one.
    On second thoughts, I've read it's so rigid, it shatters the sway bar links, making it imperative to also get the 034Motorsport links. Think I'll stick with the RS4 one for now :)
  38. tony mc
    tony mc Well-Known Member Team Phantom Audi A4 Audi Avant Owner Group
    1,088
    591
    had mine fitted for well over a year on standard roll bar links and i have no problems with them being broken, car gets plenty of stick too as well
  39. Marc B7
    Marc B7 Active Member TeamMisano TFSI Owners Group quattro Audi A4 Audi Avant Owner Group Black Edition S-line owners group
    125
    81
    Anyone know if "quattro gmbh" built 2007 s-line special edition quattro cars come with RS4 size roll bars as standard?
  40. Just Rob.
    5,141
    1,787
    no they dont, i havent found out why mine had one fitted yet but audi say it was a factory fitment for some reason, and i'm not the only special ed quattro to have one either they say ,so i cant really complain, maybe they were short on stock and fitted the next available ARB at the factory.
