Just fitted an RS4 Rear Sway Bar - WOW!
Richardesty Jul 4, 2009
  1. M7R
    M7R Type Approval Engineer,
    216
    Ive just asked my mate at TPS for the part prices, so fingers crossed this will all be done this weekend, and poss lowered in a few weeks :icon_thumright:
  2. M7R
    216
    I got my bits tonight off my mate, £60.65 inc vat :arco:
    I went for heavy duty bushes and clips as they were cheaper than the normal ones, the bushes were about 10p cheaper iirc and the clips about £2 cheaper...
    part numbers I have are:
    8E0 511 409 AL - Stabilizer
    8E0 511 327 A - bushes x2
    8E0 511 439 - clips x2
    should get mine on by the weekend at the latest all being well, so fingers crossed I notice the improvment.
  3. Richardesty
    Richardesty loves quattro
    742
    20
    :faint:
    I suggest you uncross your fingers right now - there really is no need to waste the energy :lazy:
    You WILL notice the improvement :friends:
  4. hazey7
    hazey7 Member
    170
    original post from Ricardesty stated the following parts:
    2no A8AO 511 439 Clip @ 4.16 ea + vat
    1no A8EO 511 409 AL Stabilizer Bar @ £53.77 ea + vat
    2no A8EO 511 327 D Y34 Mounting Bush @ 2.44 ea + vat
    4no AN 101 277 07 Z21 Bolt Hex @ 0.64 ea + vat (although can use old ones)
    Above/later post from M7R states:
    Any reason for the slight change in part numbers for the bushes (added 'D Y34')?
    Don't want to start this job and not have the right bits to finish it.....
    You know, before I read this thread a few times I was convinced my 2.0T Quattro cornered as flat as ****, now I can feel it leaning and its doing my head in !!
  5. M7R
    216
    Ricard's numbers are slighty wrong, they shouldnt have the "A" at the start, all B6 and B7 part numbers that are for those chassis only "ie not used on multiple chassis" should start "8E0"
    my bushes are supost to be heavy duty ones, as my mate said there was 2 sets, normal and heavy duty, and the heavy duty ones where a few pence cheaper so I went for them :thumbsup:
    I might get the bar on tonight if I get chance, failing that friday night it WILL be on.
  6. hazey7
    hazey7 Member
    170
    Thanks for that Mr M7R, let us know how you get on - both fitting it and with the results.....
  7. Dazmo
    Dazmo Active Member
    1,762
    So can someone please CONFIRM the exact list of parts needed to do this job!! and anyone know if i will need anything different with my 3.0 tdi quattro?
  8. M7R
    216
    my numbers are correct they are taken off the parts bags.
    i dont see why they wouldnt fit yours tbh, its a quattro so the same running gear as a S4 / RS4 pretty much..
  9. cyrusK
    cyrusK New Member
    13
    Straightforward swap.Mines been done about 8 months now.It's also a 3.0 tdi quattro.
  10. M7R
    216
    you can if you want re-use the clips as they are the same part number... also the bushes are the same number, but its never a wise idea to re-use used rubber bushes
  11. Mags
    Mags Have you seen my keys?
    40
    I have my car in the garage atm for new discs and to be lowered, so now would be the ideal time to do this mod.
    Questions though, mine is not a Quattro, would this still be worth doing and if so, can I use the part numbers above?
    Many thx
  12. M7R
    216
    Mines not a quattro either.... part numbers are still the same.
    and its worth doing! Im yet to really hussle mine but it already feels better, and makes islands alot of fun! :rockwoot:
  13. Mags
    40
    Thanks mate, just told the garage the part numbers.
    Also getting it lowered 30 mil, so should have a different car come Friday. :arco:
    I'll post pics when I can. :icon_thumright:
  14. fozworth
    fozworth Member
    85
    Hi can someone please give me a concrete answer regarding the RS4 rear arb thickness . Ice just got what I was told was a rs4 rear arb and it measures 20mm . I was told by the chap I got it from that it's a rs4 arb and that the ss+ had 22 mm and the normal rs4 has 20mm. Is this correct and what are people fitting when doing this mod . Is it worth changing from my s line arb to this so called 20mm rs4 one?
  15. Wrath
    Wrath Well-Known Member
    1,196
    41
    Can't remember the thicknesses but yes, change your s-line to the RS4 one! It's easy to see the difference when you have them side-by-side. I think the RS4 one is 20mm and believe the S-Line is 18mm.
    It's made a load of difference, only problem is my rear tyres are approaching their worn limit so I can't use it to it's maximum yet.
  16. fozworth
    fozworth Member
    85
    Cheers anyone confirm theve used the rs4 20mm arb instead of the 22mm apparently there the same price and both rs4 ones . But I bought mine used for £20 thinking there was only one thickness for the rs4 . I just don't want to fit a 20mm if the 22 is far better . Can someone who has the 20mm rs4 version confirm it's still far better. Cheers
  17. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,116
    2,571
    Yes, having had one of these on my old B6, I will have to get one for the 3.0TDi.
  18. Wrath
    1,196
    41
    Yep, definitely is. You won't know the difference if you drive like a Sunday driver but I suspect from your posts that you like to put your foot down :)
  19. fozworth
    fozworth Member
    85
    So are you saying you had a 20mm one then ?
  20. Wrath
    1,196
    41
    There was a thread ages ago which mentioned a different sized bar and caused massive confusion. I got the RS4 bar (part numbers on other threads). I'm pretty sure it's 20mm and not even sure the 22mm actually does exist.
  21. jdp1962
    8,116
    2,571
    I didn't buy a 3.0TDi for nothing.
    Purdy99 likes this.
  22. Avant4me
    Avant4me The're Graphite not black!!
    257
    Anyone done this on a B6? i know they are largely the same car, but you never know?
  23. Marc1
    Marc1 Member
    728
    Sooooooo many people. You will not regret it mate.
  24. jdp1962
    8,116
    2,571
    Yes, I did, and it was the best change I ever made.
  25. OxfordRich
    OxfordRich Collecting Rings VCDS Map User
    112
    9
    Hi guys, can I get some advice on this please?
    This guide says to use 8E0 511 327 A - bushes x2
    But every other guide I can see out there says to use the B version of that bush. Is there a difference? I'm asking because the guys I've got fitting my bar are saying it doesn't fit in the bush....
  26. OxfordRich
    112
    9
    Just had it confirmed by Audi, the part number for the bushes posted up by M7R are WRONG for this 22mm bar... re-reading his post he even said he went with them because they were cheaper. Why didn't I spot that before.
    " The 'B' bush was revised part number and changes to 'D' now.
    A fits 18/20 mm bars & D fits 22 mm bars. "
    Great.
  27. fourcircle
    fourcircle nj
    928
    27
    I think I used A as per the thread and they were tight but fitted. I wonder if that's a potential problem brewing for those of us who used the "A" part?
  28. Craig Cull
    Craig Cull Well-Known Member
    2,311
    1,106
    All over this!! think its the only thing that lets it down really, bit of a loose rear end (if there wasnt a better phrase for it)
    weekend task!! :)
  29. weekenny
    weekenny Active Member
    138
    51
    What's the cost from Audi these days?
  30. John@mk
    John@mk Member
    105
    I paid tps £55.80 plus vat for the arb yesterday ..just rang with the part no. And they gave the trade price .. Cheaper than Audi .fitting at the weekend....
    Cheers.
  31. fourcircle
    fourcircle nj
    928
    27
    anybody think it's an issue?
  32. olly quattro
    olly quattro Member
    78
    this is one of the best mods you will ever do to your car
  33. weekenny
    138
    51
    The bar is designed to share load between the two sides of the rear suspension hence the more torsionally rigid bar tightens up the rear end. Over constraint of the bar at the chassis mounts limits the bar from transferring load to the opposite side of the car thus not allowing the bar to function as it should. The bar should be able to rotate in its mounting points.
    Having the bush grip the bar too tightly will restrict its movement and will inherently stiffen the suspension, but not in the way its supposed to.
  34. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    1,989
    754
    x2
  35. fourcircle
    fourcircle nj
    928
    27
    Thanks mate. That's exactly the technical explanation that justifies the nagging doubt in my mind. I've felt that there was something not 100% but having changed all front arms at the same time wasn't sure if something's amiss there.
    For the sake of a fiver or so i'll change them over soon.
  36. Custardsucker
    Custardsucker Member
    112
    Hi guys, sorry another query about the bushes for this job.
    Fitted the bar yesterday (8E0 511 409AL - 22mm) with bushes (8E0 511 327D) and clamps (8A0 511 439) but before fitting tried bushes in clamps and when fitted the hole in the bush goes oval.
    Fitted bar, bushes and clamps to the car and bushes are spreading out the side of the clamps. Has anyone else noticed this? Torqued clamp bolts to 25Nm and link bolts to 45Nm.
    Didn't take pics as it was 9 last night when i finished, will try pictures today. All part numbers are correct and checked against parts before fitting. Thanks for any advice.
  37. robotplant
    robotplant Member
    154
    Hi, Just resurrecting this thread and some really useful info on here.
    Want to change the RARB soon to the 22mm RS4 type, would like the improved handling for little money.
    Can someone just confirm the correct part numbers for me as there is a little confusion over 20/22mm and heavy duty bushes. Mine is a 03 2.5tdi quattro sport avant and if anyone could recommend a good supplier as mine is the usual "stealer"!
    Parts:
    8E0 511 327 D - bushes x2
    8E0 511 439 - clamps x2
    plus links...8EO 505465 AC/ or AF
  38. Purdy99
    Purdy99 Member
    90
    after Reading all of this it seems like "The thing to do" just wondering would the RS4 ARB fit a 2WD? is there any difference or are all RARB's the same? if someone could clear this up for me it will give me something to do this weekend :)
  39. Joe_Murphy21187
    Joe_Murphy21187 Tiptronic
    1,021
    67
    I bought the RS4 RARB and it's 22mm:
    S-line = 18mm
    S4 = 20mm
    RS4 = 22mm
    I think with the B6's the S4 and RS4 were the same (not sure if they were 20 or 22mm though?)
    Also you can reuse the links and the stabalisers, you just need the new ARB, clamps and bushes.
    Audi main dealer is about £100 for all parts inc VAT, you won't find it cheaper anywhere else
    All RARBs are interchangable, quattro, 2wd, diesel, petrol etc etc. You just want the RS4 one
  40. Purdy99
    Purdy99 Member
    90
    Thank you very much!!!
