Just cleaned fuel injectors *wow*
s3dave Feb 26, 2011
  1. S3-SiB
    S3-SiB Member
    35
    I cannot see why not as its a simple spring mechanism similar to the DV if I remember correctly
  2. 08080808
    08080808 Member
    can someone post a pic-how-to of this? i really think my 10 yr old car can do with it's injectors cleaned but i am not great with my spanners and usually end up breaking something. i would really appreciate more details on how to remove the injectors and where to get the correct cleaning solution. thanks!
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    Sorry mate I did this on Satrurday but didn't take any pics. My car does feel and sound much smoother since doing it.
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It is very straight forward, ive give a quick how to on this thread, no pics though, if i do sombody elses i will do one, or if anybody is just about to do it do one?
  5. TDIQ
    TDIQ 8L > 8P > 8V
    777
  6. TDIQ
    TDIQ 8L > 8P > 8V
    777
  7. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Ok, so who wants to lend me an ultrasonic bath? Despite mine being recently cleaned I want to give this a go.
    And yes I am a tight b'stard ;)
  8. Westy
    17,443
    1,105
    I would mate but you're oop North!
  9. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Thanks anyway matey :thumbsup:
    Anyone else? Pretty please?
  10. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
    If you know anyone who works in the dental industry they use them on a daily basis.
  11. s3dave
    10,110
    736
    Well you will get some good brownie points when you clean her jewellrey (after your injectors of course..ah)
  12. [Dave B]
    [Dave B] Daddy
    2,027
    145
    If I start cleaning her jewellery will she stop asking me to buy her new jewellery..........
  13. Westy
    17,443
    1,105
    Haha, no she'll want you to buy her more jewellery for you to clean. And then she'll tell all her friends and they'll want their jewellery cleaned too. Keep it hush hush if I was you mate ;)
  14. minimatto
    minimatto Member
    66
    Im gonna try this today.
  15. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    How did you get to the allen bolts, I can't get anything in past the plastic casing thats blocking them
  16. Westy
    17,443
    1,105
    What allen bolts and what plastic casing do you mean? I'm assuming you mean the plastic bit in front of the dipstick? Have you got any pics?
  17. s3dave
    10,110
    736
    Move the plastic casing away it just clips off
  18. s3dave
    10,110
    736
  19. Westy
    17,443
    1,105
    If he's talking about those allen bolts then he'll end up removing the inlet mani!!!
  20. s3dave
    10,110
    736
  21. Reesy
    3,640
    148
    No, don't worry, I wasn't on about the ones down the bottom, just the two that are holding the fuel rail in place. I read the part about not opening the drivers door, but the fuses (for the fuel pump) are on that side aren't they. Do you think it's worth disconnecting the battery, or is it not a necessity?
  22. Reesy
    3,640
    148
    And cheers for the pics dave, just had to do a bit of multi tasking to get the both sides off at the same time, (something I'm regularly told I'm not good at!)
  23. s3dave
    10,110
    736
    Just watch your eyes, there is very little.. pull the FPR with a cloth in your hand and that should be it
  24. Westy
    17,443
    1,105
    I left the rail connected. I just liffed out the injectors and rail together and took the top off the FPR to release most of the pressure and tipped out the fuel from there. As soon as you remove the first injector from the rail fuel will run out so get a bit of cloth ready.
  25. Reesy
    3,640
    148
    Cheers for the help guys, I have left the rail connected as well. One last question, do the injectors just pull out?
  26. Westy
    17,443
    1,105
    There are little metal clips that hold the injector to the fuel rail. Remove these first then the injector will need a bit of a tug to come out. Also make sure that none of the rubber seal is left inside the hole on the fuel rail when you pull out the injectors.
  27. pj123
    pj123 Member
    307
    13
    Anyone want to do a How To with some pics?
  28. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    I'm cleaning the injector tips on the TDI and Patrol next weekend.
    I can take pics of that if people want but they are diesels, so the injectors and fitting it different.
  29. Sock
    Sock Shark in a Goldfishes clothing
    576
    Can someone tell me where the injectors are on the 2.0l A3 170?
    Are they easy to take out?
  30. Dani_B19
    9,382
    403
    Wrong section mate, sounds like youve got a 8p not a 8l.
  31. R1KVX
    R1KVX Member
    108
    i've cleaned my injectors in the newly bought ultrasonic cleaner, did you guys replace both the rubber seals on each injector?
  32. s3dave
    10,110
    736
    I didnt, but i suppose it would be good practice too....mine looked in good nick to be fair....
  33. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    188
    Glad you ask, think it stands for fuel pressure regulator but dont know where it is
  34. DenCar
    DenCar Member
    404
    Fuel Pressure Rail, connects all your injecters i think.
    DC.
  35. superkarl
    9,612
    2,481
    Fpr is on the right of the fuel rail. Stainless cylindrical thingymebob
  36. DenCar
    DenCar Member
    404
    Ahh, Fuel Pressure Regulator.
    DC
  37. Westy
    17,443
    1,105
    I didn't replace the seals either on any of the 3 cars I've done.
  38. wayne1.8t
    wayne1.8t Member
    150
    If it's any help they sell ultrasonic cleaners in aldi for 20squid they have the same in maplin for £40-£50
    Gona do mine at the weekend.
  39. wayne1.8t
    wayne1.8t Member
    150
    Did mine last night defo feel the differance in the gears b4 the turbo kicks in nice and smooth and more responsive(if thats the word)don't no if it's just me but the engine sound alot better now aswell..
  40. s3dave
    10,110
    736
    Great ^^
