Just checked oil.....Oh.....crumbs....
a3_dan Feb 23, 2011
  1. a3_dan
    a3_dan Member
    588
    Hey folks,
    Had my car last serviced around Nov/Dec time i think and have just been really lazy and not checked the oil level since....Noticed the car being a bit tappier recently, so kept meaning to check the oil.....Well tonight i finally got my ass in gear and got out there to check the dipstick....well, its on the very very minimum level!! Oooops! :keule:
    Im a bit paranoid now that I have wrecked my engine some how? Would I have done any damage to it do you think?? :banghead:
    Dan
  2. audicruiser
    audicruiser Audi Heaven
    1,865
    Wouldn't of thought you have wrecked the engine, therer is a warning light that comes on when it's really low and you didn't get this so you must of had some in it.
    The 2.0T does like it's oil. You should be checking it every two weeks roughly. Don't be tempted to over fill it as this does as much damage!
  3. Farhan
    Farhan Active Member
    1,234
    59
    agree with above, When the oil level drops to far down and that light comes on iti means game over but seeing as the light hasnt come on you survived.
    Make it a regular practice dude! I check mine weekly when i pop out for a cig.
    The tappets would have been noisy because of slight lack of oil but changing the oil over will sort it.
  4. a3_dan
    a3_dan Member
    588
    Phew! Thanks for the advice lads.
    So how much oil do you think i will need to top it back up? 2 litres? I wont need to drain it first will i and start fresh?
  5. audicruiser
    1,865
    No 2 litres is too much. It is 1 litre from Min on the dip stick to Max on the stick so 1 litre max to top yours up. Would put in half a litre and check the dip stick after 10 mins or so...
  6. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,265
    365
    yeah you dont want to over fill it dude when i bought my car the monkey who PDI 'ed my car over filled the oil and that resulted in a fooked cat and it was only slightly over the max too that was a costly thing too i think it was something like £500 ish for a new cat at the time they have come down in price now but not by much
  7. N8
    17,163
    720
    TDIs drink oil also!
  8. a3_dan
    a3_dan Member
    588
    Cheers Guys!! Much appreciated!
  9. N8
    17,163
    720
    Well done though Dan, I'll check my oil when my car comes back :laugh: :wub:
  10. a3_dan
    a3_dan Member
    588
    Well done??!! I think im a **** for letting it get that low!! :blink:
  11. warrenlord
    warrenlord Member
    771
    15
    Mine got low recently and the light came on, i didn't leave it long till I filled up I don't think it's done anything but what could it have Poss done?
  12. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Moderator
    5,920
    30
    Oh always check it every couple of weeks! You'll be ok though
  13. pi quattro
    pi quattro Member
    127
    Had a few a3's petrol and diesel. Told by more than one dealer that it is ok if the orange/yellow light comes on. I think this comes on when oil level reaches the min. I top up with the 1 litre bottle that they give you at the last service. (1 litre is the difference between min and max)
    When the red oil light comes on - then worry!
  14. sub39h
    sub39h Active Member
    2,502
    yeah 2.0Ts need checking fairly regularly, tho my car's oil thirst seems to have calmed down quite a lot. was using a litre every month at first, now it's using one every 2-3 months.
  15. FranA3
    7,265
    365
    yeah ive heard that yellow light something is wrong but dont worry too much just get it done soonish red light get it done right now lmfao , my yellow exhaust emissions light has been on for the past few months i turn it off in work then in a few weeks it comes back on so it can stay on now till i get round to sorting it out
  16. pi quattro
    pi quattro Member
    127
    Do you know what's causing the light, that would freak me driving around for a few months like that!
  17. FranA3
    7,265
    365
    haha its only a lamba sensor nothing to serious so it can wait lol its even passed an mot with it like that too so its not that bad i should really get it sorted but ive got more important things to buy right now like coilovers and new wheels lmfao
  18. Farhan
    1,234
    59
    Should be fine you would have noticed it, I may be getting this wrong from my first post but im guessing the audis warn you that its low. Usually on japanese cars if the oil light comes on it usually means pressure has dropped seriously or its running dry thats a large cause for concern. Apologies if i worried anyone with my first post but i just recalled this happened in a friends mercedes and the indicator was a warning message and not an oil pressure light.
  19. Stotty
    Stotty New Member
    14
    What oil do you normally use?
  20. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    My PD140 (05) doesn't seem to, I have it on fixed interval and I don't need to top mine up between services (done it now though haven't I)
    Must have been run in nicely by the previous owner.
    Paul
  21. a3_dan
    a3_dan Member
    588
    I use Castrol edge, 5-30, need to pick some up today from Halfrauds
  22. Lee_R
    Lee_R Active Member
    2,499
    12
    Dont worry unless the light has come on. Even when the light is on, theres still enough in it to keep it running safely otherwise what would be the point in having a warning light?
    TDI's are fine, mine hasnt used a drop in 2 years. Mine must be special :)
  23. BlueSpark
    BlueSpark 6th Gear
    386
    Yep the 2.0Tfsi engine does drink oil which i noticed only because the engine became louder (tapping). I just topped it up and it was fine, but i do keep an eye on it every 2 weeks or so which i would recommend. You will also notice that your MPG will become slightly lower when this happens.
  24. pazaz
    pazaz Member
    323
    Checked mine about a week ago and it seems but be just above the max. How can I get this down slightly?
  25. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Sounds like the engine is knackered, world of pain and ruinous expense is just around the corner.
    Cut your losses and sell it to me for a grand.:sly:
    Here to help.;)
    Paul
  26. One Spoke
    One Spoke Member
    267
    :laugh:
    Hahahahahahhaha :laugh:
  27. Gti Jazz Blue
    1,655
    Not easy to do really, easiest way is with an oil extractor via the dip stick tube.
    Other than that you are looking at removing the sump plug to drain a bit off - but you are likely to loose more than you want that way.
    Paul
