JUST BOUGHT THIS S4 ANY THING MAJOR I SHOULD CHECK OR LOOK OUT FOR ?
S4UTTLEY May 14, 2014
  1. S4UTTLEY
    S4UTTLEY S4 B5
    19
    JUST BOUGHT THIS S4 ANY THING MAJOR I SHOULD CHECK OR LOOK OUT FOR ? :rulez:
  2. aragorn
    18,608
    871
    Its probably worth having a health check done by one of the specialists, there are various issues, some obvious, some much more subtle, that should be rectified.
  3. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Oh no, you got that one. Bit of a shonker, I'll cut you a break and take it off your hands.
    Looks smart mate, loving these in red at the moment. As aragorn says it may be worth getting it into a specialist for a once over. Enjoy it mate.
    S4UTTLEY and Nilz like this.
  4. S4 Muzza
    S4 Muzza oww! my giant blue head!
    359
    31
    Looks nice :rock: spoiler has to go though, that looks awful. Guessing its a pre-facelift so manifold rattle could be a problem, and there's the obvious turbo issues which i'm sure you know about. Not much you can to prevent these though so as already said, give it the once over and maybe a scan, then enjoy!
  5. B5QUAT
    B5QUAT Member
    317
    13
    Things I've had to do since buying mine:
    Prone to boost leaks so check all hoses/vacpipes and jubblys, ideally get it pressure tested.
    Dumpvalves....prone to leaking
    Rocker cover gaskets
    Coilpacks.....some people replace them with the later TFSI coils, but it requires additional hardware and is quite pricey.
    Rear diff oil seals.
    Proper 4 wheel alignment (about £120) worth its weight in gold. Car might feel ok but a good adjustment can transform the car.
    Echo what's been said, get a healthcheck and get it on a ramp and have a good look underneath.
  6. S4UTTLEY
    S4UTTLEY S4 B5
    19
    Cheers ;) what the difference between the face lift and pre face lift , there is a recite for the diff oil last year ? The boot , I had a bora with a lip spoiler on if I take this spoiler dose it leave hole sect ? N thank for the advise every one ile get it looked over ;)
  7. Oranoco
    3,998
    408
    Face lift cars have one piece headlamps with integral indicators, rounded door handles, different more beefy rubbing strips, tail lights have the indicator revers light swapped, central console arrangement is different, heater vents are illuminated
    Worth swapping the lights out for the Facelift versions as they really update the car
    S4UTTLEY likes this.
  8. S4UTTLEY
    S4UTTLEY S4 B5
    19
    Sound as pal, swapping the head lights ?
  9. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    391
    61
    assuming the mileage is over 120k, then yes, a rear diff gear oil change is worth doing. Mine came out the colour and consistency of Mellow Birds! Always remove the fill plug first. Takes just under 2 litres. More details here: AudiWorld Tech Articles
  10. S4UTTLEY
    S4UTTLEY S4 B5
    19
    Top man cheers
  11. B5QUAT
    B5QUAT Member
    317
    13
    Swapping the rear lights is dead easy and makes the car look more modern I think
    PFL
    Half and half
    FL
  12. adamss24
    adamss24 Well-Known Member
    4,584
    407
    I for one prefer the pre facelift smoked rear lights, facelift headlights are a must though !
  13. AVLO
    AVLO Active Member
    295
    52
    Looks nice mate you happy with it in general? Ive not had my Pre Facelift s4 that long, I also need a full health check!
  14. S4UTTLEY
    S4UTTLEY S4 B5
    19
    Yer I am made it with it , it's a bit to standard ATM tho lol I just want to keep the over all look standard , wheels re dun , full exhaust , remap, decent set of coil overs and the devil wot box lol
  15. aragorn
    18,608
    871
    Some tuners can program the WOTBox features straight into the engine ECU, saves having an extra device!
  16. Oranoco
    3,998
    408
    Unicorn can map in the WOTBOX features of full throttle shift and launch control.
  17. S4UTTLEY
    S4UTTLEY S4 B5
    19
    It will be on 24/7 tho n don't no if I won't that say if I take my nana to shop or summet lol
  18. Bradderz_1988
    3,987
    261
  19. aragorn
    18,608
    871
    Not really.
    It only activates launch control if you floor the accellerator with the clutch depressed and your speed at 0. Not something you typically do in normal driving, and certainly not with OAP's in the car :p
    And similarly, it only activates NLS/anti-lag if you change gear with the accellerator mashed into the carpet.
    So when your driving your nan to the shops or otherwise driving normally, it just drives like a normal car.
    AVLO and S4UTTLEY like this.
