just bought 2003 AUDI A4 TDI SPORT - rev counter problem
ATAUK Mar 16, 2013
  1. ATAUK
    ATAUK New Member
    15
    H i , totally new to audi and diesels, and as per title just bought 2003 AUDI A4 TDI SPORT... now every thing is great and i love the drive , the only fault i have found is the rev counter sits at idle and doesnt realy move much although all the power is there and drives great ... this was apparently a problem that occurred after a flat battery ? told it should be ok with some kind of reset via audi ?
    any advice would be great :)..
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    yeah it sounds like it may need the needle resetting
    whats your location? check the vcds users map there maybe someone local who can do it for a few beer tokens
  3. ATAUK
    ATAUK New Member
    15
    Hi , im in Sale , near Manchester ....vcds ermm il go look :)
    Also any advice on the rest of the vehicle would be handy :)
    thanks
    Dave
  4. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Gold Supporter quattro Audi S3 s tronic
    25,443
    8,536
  5. ATAUK
    ATAUK New Member
    15
    Think thats who i just sent a pm to :)
  6. Sandra
    25,443
    8,536
    Ok. He is a top fella. :) x
  7. ATAUK
    ATAUK New Member
    15
    sent a pm , although nothing showing in sent and out box ?
    any ideas ?
  8. deano1978
    deano1978 different gear
    713
    80
    Only shows saved msgs if you save them.
    Funney i have similar issuses.
    Basically lost snyc with motor,immoblizer on,flat battery,central locking not working. Sorted now,same as you,got a local vcds from map to help out.
    Thing is,while driving, my rev counter wont go past 2k revs but engine still does????????
  9. ATAUK
    ATAUK New Member
    15
    yep , exactly the same , although after driving yesterday , let it sit for a about 4 hrs and all was good , this morning no power again :s
  10. deano1978
    713
    80
    Just drove my car and the revs are well lower than normal. Crusing at 40mph in 4th and its at about 800revs!!!.
    So urs resseted after a while of driving? As in back to normal revs?
  11. ATAUK
    ATAUK New Member
    15
    sorry , my mistake , the revs are the same , just battery totally dead .. just bought a new one and reset fob etc ..... still waiting for a response to fix rev counter etc :)
  12. ATAUK
    ATAUK New Member
    15
    anyone able to also test alternator , just incase ?... maybe could be done at same time if can get rev needle reset ?<br><br>thanks
  13. ATAUK
    ATAUK New Member
    15
    Just a update : needle drops when engine turned off , raises to just under the 1 rpm and stays there , doesnt move untill engine is turned off... no reply yet for getting needle reset , phoned a place up in sale who said its a problem somewhere in the car and needle wont need reset ?
    any one know of anyone who knows what they are doing ? dont fancy a wasted trip to a stealer :) rather a forum member get the money
    can get me on 09741448287
    thanks
    dave
  14. stu_m
    1,440
    Shame your not near me I would have a look for you as I have full vcds
  15. ATAUK
    ATAUK New Member
    15
    added pic of rev counter, it flickers when any throttle is added as though it want to move but doesnt.. Also i did mention that it dropped when no ignition but turns out it just stays where it is
    if i need a new cluster panel ive sourced one locally for £35 could anyone in the Manchester area code and fit ?
    DAVE
  16. stu_m
    1,440
    I don't think you can code them with vcds as it controls the immobilizer too I'm pretty sure even audi find it hard to code second hand clusters
  17. ATAUK
    ATAUK New Member
    15
    no probs , will c how things go ... dont want to spend to much realy but c what happens . thanks for reply :)
  18. ATAUK
    ATAUK New Member
    15
    Ok so N8 read the car with vcds - alot of codes been thrown up but not nothing came back
    do any of these corresond with probs im having with rev counter? bearing in mind the car has loads of power and drives faultless just the needle for rev counter just sits in the same place
    Wednesday,20,March,2013,14:01:39:43483
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E93A390092 Mileage: 256390km/159313miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 JQ
    Component: 1,9l R4 EDC 0000SG 1570
    Coding: 00002
    Shop #: WSC 63351
    VCID: 6FE9856D2D34D760C86
    WAUZZZ8E93A390092 AUZ6Z0C0184424
    5 Faults Found:
    17675 - PD Unit Injector: Cylinder 3 (N242)
    P1267 - 35-10 - Regulation Range Exceeded - Intermittent
    17672 - PD Unit Injector: Cylinder 2 (N241)
    P1264 - 35-10 - Regulation Range Exceeded - Intermittent
    18043 - Powertrain Data Bus
    P1635 - 35-00 - Missing Message from A/C Controller
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - Intermittent
    18062 - Please check DTC Memory of Instrument Cluster
    P1654 - 35-00 -
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04255
    Shop #: WSC 06435
    VCID: E5C567457FC89D3032A
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-10 - - - Intermittent
    18265 - Load Signal
    P1857 - 35-10 - Error Message from ECU - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1119
    Coding: 00000
    Shop #: WSC 63351
    VCID: 60CBF651E0EA781841C
    4 Faults Found:
    00710 - Defroster Flap Positioning Motor (V107)
    41-10 - Blocked or No Voltage - Intermittent
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    41-00 - Blocked or No Voltage
    01232 - A/C Compressor Regulator Valve (N280)
    30-10 - Open or Short to Plus - Intermittent
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 63351
    VCID: 326F4C19FE86BA88E78
    1 Fault Found:
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 2000
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: 3667700942EEA6A8CB0
    1 Fault Found:
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0308
    Coding: 00001
    Shop #: WSC 63351
    VCID: 3667700912EEA6A8CB0
    1 Fault Found:
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D36
    Coding: 00400
    Shop #: WSC 00503
    VCID: 306B4611F08A889891C
    10 Faults Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    29-10 - Short to Ground - Intermittent
    27-10 - Implausible Signal - Intermittent
    01176 - Key
    00668 - Supply Voltage Terminal 30
    00576 - Terminal 15
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    01316 - ABS Control Module
    00466 - Control Module for Steering Column Electronics (J527)
    01320 - Control Module for Climatronic (J255)
    01304 - Radio
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD1117D992CAB4064E
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BD
    Component: Komfortgerát TBF 1411
    Coding: 06859
    Shop #: WSC 63351
    VCID: 74E38A014412F4B8354
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0003
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0003
    16 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01317 - Control Module in Instrument Cluster (J285)
    01134 - Alarm Horn (H12)
    01616 - Signal Wire to Interior Monitor
    79-00 - Please Check Fault Codes
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    00955 - Key 1
    37-10 - Faulty - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 J
    Component: concert II GRO 0008
    Coding: 01001
    Shop #: WSC 63351
    VCID: 2E575869EABE9E68830
    No fault code found.
    End ---------------------------------------------------------------------
  19. ATAUK
    ATAUK New Member
    15
    then the reading after codes cleared
    Wednesday,20,March,2013,14:11:52:43483
    69 75 76 77
    Coding: 00002
    Shop #: WSC 63351
    Coding: 04255
    Shop #: WSC 06435
    Coding: 00000
    Shop #: WSC 63351
    Coding: 00001
    Shop #: WSC 63351
    Coding: 0010602
    Coding: 00001
    Shop #: WSC 63351
    Coding: 00400
    Shop #: WSC 00503
    Coding: 00001
    Shop #: WSC 00000
    Coding: 06859
    Shop #: WSC 63351
    Coding: 01001
    Shop #: WSC 63351
  20. deano1978
    713
    80
    Any joy with this yet?
    Mine drives ok. So just living with it at the mo,seems a dark area!
    The only good thing is that while at 60mph im only @ 900rpm in 6th lol.
    Just a thought.... Rev counter gauge?
  21. ATAUK
    ATAUK New Member
    15
    no joy with th rev counter , just stays where it is in the pic i added ... though any throttle it flutters as though it is trying to move up. if urs is moving then maybe a reset would work ??
    The drive is great and pulls like a train , i honestly cant fault it atall..
    even after this fault i know it hasnt put me off the car , im just one of those that likes everything working :) and should i change i know ill be sticking with an audi , even the mrs likes it and is out in it today , yet she would never drive the rx8 i had :)
    maybe there is a way to fix the needle ? free it ? i dunno
    dave
