Just been told my car can't be remapped?
Zonda_ Oct 20, 2009
  1. Zonda_
    Zonda_ Member
    66
    While I was getting a quote for an exhaust asked about a remap, they said it couldn't be done as my car is too old. It's a 1998, are they right?
  2. Dani_B19
    9,380
    402
    That's ******, sound's like they just dont want todo it, is that all they said to you, it's too old?
  3. Zonda_
    Zonda_ Member
    66
    They said it was too old and didn't have an OBD2 port. My 1993 Vento had one!
  4. JS1500
    JS1500 Howdy
    1,166
    10
    They probably mean it can't be remapped through the OBD port.
    They'd have to use a chip on your ECU - costs the same.
    I had my A4 (1998) done by Superchips. The Superchips supplier in Aberdeen had to take my ECU out and send it down to Superchips, they returned it the next day and my car was only off the road for 2 days.
  5. Essflee
    Essflee Well-Known Member
    2,154
    67
    I had an A3 on a 98' and that was remapped without a problem, your OBD port iirc is under the ashtray at the back of the cubby hole, shouldbe a little blanking plate that you remove, the port should be there...
  6. Zonda_
    Zonda_ Member
    66
    Same as on the Vento then.
  7. badger5
    9,598
    2,060
    depending on age of ecu/car will depend if its flashable at all or physical solder in a chip affair.
    older ones are likely non-flashable
  8. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    My 2000 A3 was mapped by plugging into the ECU direct which is under the scuttle panel. The car was then checked on VAGCOM by plugging into the port at the bottom of the dash by the drivers footwell.
    Seems odd them saying it cant be done...
  9. Andrew@A.L.D
    3,879
    617
    Can a 09/10/1999 S3 be remapped or does it have to chipped ( soldered in ),Engine APY04365? not sure the ECU code?
  10. jojo
    28,997
    3,649
    My early APY(no ESP or strut brace model) was mapped through the diagnostic port, I don't think you have anything to worry about.
  11. NHN
    29,576
    1,779
    Yeap my S3 apy was mapped through port aswell that was 99 car.
  12. Broken Byzan
    13,237
    466
    S3's are a different kettle of fish and all DBW and flashable, the OP has a 98 which is chipable, but requires the ECU to be removed and a chip de soldered and a replacement "chip" fitted.
    Tom, i am intrested to know if you have your ECU number handy, it's for research on finding alternative ECUs that are flashable and are you DBW or do you have a throttle cable?
    [/Thread hijack]
  13. A3Tom
    3,504
    14
    My cars a throttle cable K03 AGU, and I dont have the number handy I'm afraid. How important is it?, sure I can find time to whip the scuttle off and get hold of it for you over the weekend.
    T
  14. Broken Byzan
    13,237
    466
    Or read it out via VAGcom? even easier !!
    Not mega important, but would help seeing yours was flashed onto the ECU without removal for chipping
  15. A3Tom
    3,504
    14
    Ahh, I dont have VAGcom I'm afraid!!.
    T
  16. Broken Byzan
    13,237
    466
    Ahh right, well if you get 2 mins can you dig it out for me, pretty please !!
  17. A3Tom
    3,504
    14
    I'll have a look over the weekend for you, cars getting new wiper blades etc so I'll do it then.
    T
  18. jcs356
    jcs356 Brum brum
    2,734
    70
    My 1994 Ibiza has been rechipped for over 11 years now. That was a chip out job. Still have the original in a box somewhere....
  19. Swornd
    Swornd Member
    50
    Same situation here, couldn't be flashed so they had to send the ECU off. Took it in the morning and got it back same day! Guessing a superchips place isn't too far away from here. Superchips map was nice and cost me around £280ish, had a few other bits so can't remember exact price
  20. badger5
    9,598
    2,060
    it is drive by wire it can be flashed yes, by port or direct into ecu
  21. h100vw
    h100vw Member
    218
    I had a 98 AGU engined A3, you can bench flash them. ECU part number ends ins AQ.
    Any Custom-Code agent would have the capability, I do.
    Gavin
  22. badger5
    9,598
    2,060
    R reg A3's are older ecu variant
    flashable ones should be:
    06A 906 018 AQ
    06A 906 018 AR
    06A 906 018 BA
    06A 906 018 BB
    06A 906 018 CG ** most common i see
    06A 906 018 CH
    06A 906 018 CJ
    06A 906 018 DR
    06A 906 018 R
    Port flashable sometimes, often requires bench flashing as the comms on these cars sux big time
    regards
    bill
