just a quickie lads found oil in intercooler n pipes tday does that mean turbo broke
mk1kid May 13, 2010
  1. mk1kid
    mk1kid Member
    74
    hi lads as title says found **** loads of oil in intercooler n pipes today does tht mean turbos broke
  2. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Sounds like the seals have gone.
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    theres usually a bit lying around what do you mean by loads......pouring out?
  4. mk1kid
    mk1kid Member
    74
    a good half of a litre
  5. durk
    durk New Member
    20
    strange you shuld mention it i have replaced the intercooler in mine and had the same problem !!! does anyone know how much work involves changing the seals on the turbo??
  6. 1animal1
    9,978
    as said above, quite a lot can get carried into the TIP and turbo boost pipes from the PCV system....
  7. badger5
    9,578
    2,040
    before condemming the poor little turbo, remember the oil breather system from rocker cover and crankcase, vents into the turbos intake pipe, which in turns blows the oily fume throughout the intake charge pipe system
    check the TIP... bet its oily
  8. mk1kid
    mk1kid Member
    74
    sorry im new to these engines whats tip n were is it lol
  9. sportstractor
    sportstractor Chugger
    2,709
    turbo inlet pipe, the pipe that goes from maf, to the turbo.
    Definately would also hold up condeming the turbo.
  10. mk1kid
    mk1kid Member
    74
    what procedure would u try then lads basically ive had the intercooler off and pipes visually checked and replaced a few perished pipes in the pcv system done a oil n filter change etc all the basic stuff just stook after tht as im 80% sure the turbo seals have gone
  11. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Half a litre? Bloody hell, thats a lot!
    As said, check the TIP for oil.
  12. mk1kid
    mk1kid Member
    74
    the charge pipe on top was oily also the pipe from turbo to intercooler was
  13. mattyboy199
    mattyboy199 Well-Known Member
    1,890
    29
    if its just oily on the surface nothing to worry about, all cars do that. if its proper thick or your finding drips/ puddles of it you have a problem
