just a quick question
S3_chris 11 Oct 6, 2012
  1. S3_chris 11
    S3_chris 11 Member
    188
    Just got to work heard some clicking and squeaking from the front passenger side. I've just had a look and my inner cv boot has split am I going to be ok to drive it 20miles home?
  2. MarkyS3
    MarkyS3 Member
    192
    Yes mate, no problem, ive driven thousands of miles with noisy CV's.
  3. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    the less you drive it the better chance of the joint being ok once a new joint is fitted and greased, you will be fine to drive home dude and being an inner theres less movement
  4. MarkyS3
    MarkyS3 Member
    192
    Joints are very cheap anyway.
  5. S3_chris 11
    S3_chris 11 Member
    188
    I was kinda hoping i could drive home as dont really want to fork out for recovery. Another question is do I get a cv boot based on the shell or the engine?
  6. S3_chris 11
    S3_chris 11 Member
    188
    It won't **** the driveshaft will it if I drive it as I'm not off now till Thursday and need to get to work and back?
  7. MarkyS3
    MarkyS3 Member
    192
    The driveshaft is made up of two CV joints, inner and outer. Inner is around £20 to replace. It wont harm the actual shaft itself no.
  8. S3_chris 11
    S3_chris 11 Member
    188
    Cheers guys appreciate it
