just a little bit pee'd off
rob v6 May 22, 2010
  1. rob v6
    rob v6 Learning the VAG way
    161
    One the way back from the shops this morning and the cambelt on the v6 thought it would give up the ghost. just need to find someone to fix it now before we go to barmouth in 3 weeks
  2. tux
    tux Member
    89
    That sucks dude. Can the V6 be repaired, or is it likely to be new engine time?
  3. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Bloody hell! Whens the last time it was changed dude?
  4. aragorn
    17,893
    689
    Thats really sucky. The belts due soon on the TQS so i think i'll be doing it before anything else. Was it overdue?
    You'll probably need a pair of new cylinder heads, or at the very least a set of valves and possibly guides.
  5. rob v6
    161
    will not know until monday when the mechanic has a look at it.
  6. rob v6
    161
    thanks Byzan a4 for changing the title was not thinking straight when i typed that
  7. mckay9uk
    mckay9uk A4 2.4 30V PES Supercharged
    158
    That sucks man, it might be easier, quicker and cheaper to just change the whole lump to a 2.8. i've just Supercharged my 2.4 i'm a little bit concerned that the waterpunp wasnt changed when the belt was done about 20k ago but it was done about 8k before that i might be in the same boat in a few months ! lets say i like living dangerously!
  8. Broken Byzan
    13,235
    464
    No probs matey, i understanf how you feel/felt :friends:
  9. rob v6
    161
    It might be but it all depends on how much it is going to cost there is only so much i am willing to spend on a car when it is only worth just over 2k. Plus i need the car for our holiday in 3 weeks that the kids are rally looking forward to and i do not want to disappoint them.
  10. rob v6
    161
    Well the car is all fixed cambelt had gone but it had taken the hydrolic tensioner (so the garage said) first which saved the engine so the garage has changed the
    water pump + housing
    stat
    cam belt
    aux belt
    all tensioners
    complete coolant flush
    and new under tray (Engine protector)
    for the grand total of
    £550
    so not to bad considering a week before i had a quote to change just the cambelt and aux belt and that was £450 .
    They had qouted me over 1k if it had take any valves out so i am a very happy man agin even if my wallet is now empty
  11. Jonion
    Jonion Member
    193
    So to look on the bright side.... for an extra £100 you had a load of other things changed/checked as well. :cool:
    Happy for you.
  12. griswold
    griswold Member
    348
    Glad its up and running for you now.
    Been meaning to check when the wifes 2.4 v6 is due its cambelt
    priced a belt kit up so better get it done soon
  13. rob v6
    161
    yep and the chap that did it worked at audi for 25 years before setting up his own place so he knows his stuff
  14. rob v6
    161
    i would mate defo worth it as it can get expensive if it does go
  15. Jonion
    Jonion Member
    193
    Not too far from me , might chat you up for his number if I CBA t odo my own ;-)
