jus done the n249 removal and car runs like poo poo help needed
AARON77 Jun 18, 2011
  1. AARON77
    AARON77 Well-Known Member
    1,324
    31
    as the title says lads????
    car seems to be popping and splutering?????
  2. Speedy Steve
    Speedy Steve Active Member
    1,258
    is the N249 still wired in?
  3. talentwalsh
    talentwalsh Member
    139
    Mine spit the dummy when i did it also. Make sure the connections are tight and the hose is the right size. It calmed down eventually and now is spot on.
  4. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    Is your car an apy? It needs a t piece off to the sai. And keep the valve plugged in
  5. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,305
    375
    yours is a '99 plate S3 which is an APY right? So you will have SAI, did you follow wellys guide for the SAI too?
  6. AARON77
    1,324
    31
    yup mine is apy and i did put a t in and ive left the 249 plugged in ???????
  7. superkarl
    9,623
    2,488
    Hmmm odd one that. Id the dump valve working alright? Just check it over again and again. Or like that fella said above, it might settle
