Jumping when Idle...
S3MMA Jun 18, 2011
  1. S3MMA
    S3MMA Member
    235
    My S3 is jumping irregularly when idle, it has been doing it today at lights etc but only when in neutral... it has just had a service ...any idea's??
  2. Sandip
    2,440
    91
    Either the throttle needs a clean or it's the MAF.....
    Look out for me, i'm in Bolton too lol
  3. Dani_B19
    9,165
    362
    What do you mean by jumping? The car is or the rev counter is?
    If the rev counter is then mine always does it, cleaned tb, new maf etc and the revs still flutter!
  4. S3MMA
    S3MMA Member
    235
    I will need to ring the garage on Monday again..it only came out on Friday!!
    I will is that your car in the pic?
  5. S3MMA
    S3MMA Member
    235
    The car is, only slightly and like I said irregularly like after 5 secs then maybe 10 secs...but when it does it you can really notice it...
  6. Sandip
    2,440
    91
    Yeah that's mine, did you buy it from Bolton Audi?
  7. S3MMA
    S3MMA Member
    235
    No, from a small dealer..
  8. Sandip
    2,440
    91
    Ok, it's sounds like the throttle needs a clean i think, easy fix :icon_thumright:
  9. S3MMA
    S3MMA Member
    235
    I Hope so... I have read a few threads on here about DMF replacements!!
  10. Sandip
    2,440
    91
    Funnily enough my revs drop slighty but i can hear my DMF (rattles a bit), but it's been like that for a while, aslong as it ain't slipping i ain't touching it lol
  11. S3MMA
    S3MMA Member
    235
    Fingers crossed then.. its something and nothing...:shrug:
  12. Sam_
    Sam_ Down under
    3,037
    480
    I'd say give it a throttle body clean and alignement with VCDS (Do you have that yet? It's very handy) and go from there before replacing things like the MAF.
  13. Dani_B19
    9,165
    362
    Sam how do you do a tb alignement again?
  14. Sam_
    Sam_ Down under
    3,037
    480
    Dani,
    Take a look here:
    Throttle Body Alignment (TBA) - Ross-Tech Wiki)
    Or you can simply disconnect and reconnect the battery, but then you have to faff around with the clock and windows.
  15. Dani_B19
    9,165
    362
    Cheers mate.
    The battery ways not mesnt tobe good, there was something in seatcupra.net about why you should use vagcom as thats the only way to correctly do it.
  16. S3MMA
    S3MMA Member
    235
    Thanks everyone, I will have to get this done this week!
  17. fudwiza
    fudwiza New Member
    15
    My car does this too is it bad? and blonde question but whats a DMF?
  18. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    DMF = Dual mass flywheel
    It could possibly be a vacuum leak get the garage to check pipes paying close attention to the pipes under the inlet manifold....
  19. S3MMA
    S3MMA Member
    235
    Dual Mass fly wheel
  20. S3MMA
    S3MMA Member
    235
    It isn't doing it today, which is strange....it only does it now and again....
  21. sportquattro
    sportquattro Active Member
    835
    51
    Emma, check the vac pipe that runs underneath the inlet manifold these are notorios for splitting and case exactly this problem, I had it and the hopes was split, new hose no more irratic idle.
    Hope this heklps
    Nige
