Juddering when setting off, hard to get into 1st
johnnevett Feb 24, 2014
  1. johnnevett
    johnnevett Member
    245
    19
    Hi all
    i had the DMF and new clutch done about 3,000 miles ago but I've noticed recently it's hard to get into 1st gear and juddered when setting off, in cold and when the car warms up. If I over rev when setting off there is no juddering.
    Is this symptoms of the release bearing failing?
    Or could it need a software update? How can I check if it has ever had the update?
    I'm unaware of when the last gearbox oil change was done, if this could cause these issues.
    Any other ideas?
    Just a bit annoyed that after new DMF and clutch these issues are still there
    john
  2. Jamie-S
    Jamie-S Member
    274
    17
    Which engine do you have?
  3. johnnevett
    johnnevett Member
    245
    19
    Sorry mate should of said, it a 2008 2.0 Tdi 143, manual gear box
  4. johnnevett
    johnnevett Member
    245
    19
    Any help on how to check if it's had the software update for the clutch sensor first
    Then I can start looking at other options.
  5. johnnevett
    johnnevett Member
    245
    19
    Any help, anyone?
  6. trance
    trance New Member
    29
    I have same issues, audi will not admit their flywheels are ****.
    For the gear changing try a fully synthetic oil. That should help.
  7. johnnevett
    johnnevett Member
    245
    19
    It's due a full service next month so will do that then
    Have you had the software update and did it help with your issue?
  8. J1 MBO
    J1 MBO Member
    52
    I have this issue on my 2008 B7 2.0tdi... its just been in the garage and their flippant diagnostic was that it needs a new clutch, but i'm not 100% that will cure the fault, and bet its not cheap on these!! Looking for answers too, sorry I dont have any, just feeling your angst!
  9. SI-W85
    SI-W85 Well-Known Member
    1,321
    351
    If its juddering its most likely the flywheel but you may as well do the clutch while your in there.
  10. J1 MBO
    J1 MBO Member
    52
    Faith restored in my regular German Marque Specialist garage, explained the need for replacement clutch, but like you say it's the dual mass flywheel that's at fault, it just makes sense to do the clutch while it's stripped down, like you say! Thanks! May put it off as advised by the garage after the quote came in at £950!!
  11. SI-W85
    1,321
    351
    Go on darkside developments to buy your flywheel/clutch kit £400ish mine is the same but only slight judder I'm just putting it off really until it gets a bit worse but I've had 2 quotes of £800 all in for replacement flywheel & clutch.
  12. J1 MBO
    J1 MBO Member
    52
    Ha ha, yea, I'm just going to put it off for now too!!
  13. SI-W85
    1,321
    351
    I now have clutch slip since my remap :( think its going to have to get done sooner rather than later now...
  14. J1 MBO
    J1 MBO Member
    52
    Oh no - that sucks! Would the remap have actually caused clutch slip?!?!
  15. SI-W85
    1,321
    351
    It definitely wouldn't have helped it with the extra torque the clutch will not last as long however my car has just reached 50k and this is the 3rd clutch to go in it apparently when they got in there they realised it wasn't Audi original so that's not very good of a car of that mileage.
