  1. sturs4
    sturs4 Member
    193
    9
    I have a judder through the steering wheel that seems to get worse the faster you go and seems to get better and worse at times.its not shacking the wheel violently but there is an issue somewhere that needs sorting.it can also be felt through the throttle peddle.Anyone have any idea's?
    And its definitely not a balancing issue.
  2. roman3000
    roman3000 Member
    316
    Wheel allignment, warped brake discs.
    Have you checked those?
  3. moag
    moag she's no d-turbo
    821
    35
    Tyres pressures, wheel alignment, buckled wheel?
    If your getting shaking under braking its most likely a warped disc
  4. sturs4
    sturs4 Member
    193
    9
    It seems fine when i brake and i have had two sets of rims on and the problem is still there.
  5. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Sturs, have you tried jacking up each side and looking for excess play in the wheel bearings, steering ball-joints, or even in the steering
    box attachments, or actually in the steering box itself? Could also be suspension joint(s)/bushes etc. Give the wheel a damn good shake both horizontally and then vertically, and see what happens. If you can find any play, then get someone to look underneath while you are shaking the system to try to determine which component is moving. Good luck.
