Judder/Misfire @ 1400rpm
sarah1989 Mar 19, 2010
  1. sarah1989
    sarah1989 Member
    Hi, i have a 54 plate 2.0TDI DSG, had a few problems before with misfires etc, got that sorted with replacing the wiring harness from the injectors to the loom.
    Over the past few weeks my car judders at 1400rpm especially in gear 4, I had my friend plug his equipment in to it who is a auto electrician and the fault it brings up is cylinder 2 combustion failure
    Would this be the problem with the judder?
    What does that error actually mean is it injector 2 that needs replacing?
    Thanks in advance for any info.. Sarah x
  2. edition
    edition Active Member
    1,426
    Hi Sarah,
    Do you have the fault code that it's bringing up?
  3. sarah1989
    sarah1989 Member
    No didnt think to write that bit down:lazy:
    But the exact message was cylinder 2 combustion failure x
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    possibly a dirty injector ? can you swap them around to see if the problem moves?
  5. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    I have a set of injectors if you need some Sarah.
  6. sarah1989
    sarah1989 Member
    What sort of money for the set? x
  7. devonmikeyboy
    1,245
    £105 for a set delivered by courier to get to your door in 24 hours.
  8. sarah1989
    sarah1989 Member
    I will let you know early this week, its booked in to my garage for tomorrow.
    I'm going to sound real stupid here, but my auto elec plugged in to it yesterday and had a play and he told me some important stuff which just went above me and I cant remember half of it :crying:
    It was along the lines of he cant read or run anything between 1200rpm and 2000rpm.. which is just where the problem is.
    The problem only happens when cold, once it is warmed up then thats when it starts.
    Could any one shed any light?
    Thanks x
  9. sarah1989
    sarah1989 Member
    Spoke to a mechanic yesterday which suggested it could be the fuel im using, month and a half ago I put shell V Power Diesel in for the first time, and that possibly is when the problem first started to show? What do you guys think?
  10. devonmikeyboy
    1,245
    The words ****** and don`t ever take you car to that idiot sorry i mean "mechanic" spring to mind.
