JOM coilovers fitted, knocking noise at front (pics) help!
wez3570 Jul 27, 2011
  1. wez3570
    wez3570 Member
    704
    20
    So, after reading others users on here have the JOM coilovers fitted, without issue, I decided they'd be ok for a first go at having coilovers.
    Ben at Shark Performance had one of his neigbouring mechanics fit them and on the way home I noticed a knocking sound coming from the front.
    Took them back and had everything checked and tightened, still the same.
    Went to have an alignment done, having been told this might cure it. Still knocking.
    This has gone on for a few weeks now and I've spent time and money trying to locate the knocking.
    I was trawling the net a couple of days ago and read there could be a problem with the springs, so the very next day I jacked the car up and had a look.
    The pics above are what I saw.
    Anyone had this happen to them?
    Any idea what I can do?
    I'm half relieved to discover this, at least I now know what was knocking! (I think!)
    I got the coilovers from DPM but thought I'd post here before contacting Damian.
  2. mkimjoon
    mkimjoon Member
    166
    27
    Does this happen when you make hard turns? Atleast mine did when I had koni co. Only front left though. I hear it's normal.
  3. wez3570
    wez3570 Member
    704
    20
    No, it happens when driving above about 10 mph.
    You're saying it's normal for the springs to be hitting themselves and wearing away after only a few weeks being on the car?
  4. N8
    17,163
    720
    You based near Ben then in mansfield? I'm not sure whats wrong, but afterall they are only budget coilovers
  5. Lings
    Lings Active Member
    2,059
    31
    You get what you pay for .Cheapo crappo and Audi is a NO NO ;)
    N8 likes this.
  6. N8
    17,163
    720
    I didn't want to come across as a C_NT and say that, but yes :laugh: Thats the one Ste :laugh: :wub:
  7. mkimjoon
    mkimjoon Member
    166
    27
    it's not normal for spring to touch. Yes you get what you paid for. Personally i would have bought a used good C/O over JOM or Raceland. :(
  8. wez3570
    wez3570 Member
    704
    20
    Thanks guys, just what I was looking for. Very helpful
    Tapatalk for iOS
  9. N8
    17,163
    720
    Bro all I know is the people I know with cheap coilovers, always have problems.
  10. ern
    ern Member
    97
    Are you sure that the coils are hitting each other? That could be marks from installation while tightening up the top mounts.
    As for you get what you pay for, you should really have got a bad ride with functioning c/o not some defect.. Have to check part numbers and see if they are the right ones for your engine as you may just be putting too much loading on them if they are touching.
  11. Lings
    Lings Active Member
    2,059
    31
    You are a cnut :p
  12. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Wow ...I was thinking of getting the same coilovers ....This has made me think twice now......:ohmy:
  13. warrenlord
    warrenlord Member
    771
    15
    Spring wrong way round? Sounds stupid but could be.I have these and they have been awesome for the tiny amount of money I paid. Great ride
  14. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    and me just going to get 50mm h&r as got new shocks all round last year
    was just about to say springs wrong way up ?????
  15. Stink
    Stink Member
    how low have you gone? could be the driveshaft knocking?
  16. tyrrelll
    tyrrelll Lukey.T
    226
    Not sure of the answer bud, but deffo not normal... i've had my JOM's on for a few months now with no problems. well pleased for the money. Plus the ride is as good as if not better than stock.
  17. tyrrelll
    tyrrelll Lukey.T
    226
    The lad posted here for help, not to hear that his coilovers are ****.
  18. Stink
    Stink Member
    Again how low have you gone it could be the arb knocking the driveshaft in which case you need to get some adjustable drop links ;)
  19. wez3570
    wez3570 Member
    704
    20
    Appreciated mate
  20. wez3570
    wez3570 Member
    704
    20
    Been all the way down and a couple of turns at a time til all the way up.
    Had 3 mechanics have a look, nothing loose, no play, everything solid.
    Knocks no matter how low.
  21. flying oyster
    flying oyster flying oyster
    563
    27
    i thought you ran cheap **** coillies one of the reason i bought mine was you said they were good for the money
    still im happy with mine 3 months on
  22. wez3570
    wez3570 Member
    704
    20
    Deffo the right way up, there's numbers on there.
    Installed, the numbers are not upside down.
    Also alignment centre confirmed that they're installed correctly
  23. wez3570
    wez3570 Member
    704
    20
    There were no marks a couple of weeks ago when it was up on the ramp at the alignment centre.
    Looking in the flesh you can see where the marks corespond with contact, it's eating into the metal.
    Looks dangerous to be honest.
  24. wez3570
    wez3570 Member
    704
    20
    I knew I was buying the cheapest coilies out there, but with members on here having NO probs, I thought I'd give them a try.
    TUV approved, 2 year warranty, made in Germany.
    Could it be the 3.2 is just too front heavy for the springs?
    I just checked the label on the box and it def says suitable for 3.2
  25. Lings
    Lings Active Member
    2,059
    31
    Sounds like the front springs are not on right or the top mounts are shot?Did you get yours changed ??
    Thats right pal :) .I have never said mine were no good just a bit crashy etc ?The build quality is not fantastic . you get what you pay for though and i have had these on a while but they will be off and on ebay shortly(payed £100 for these) .Mine creak and are no where near as smooth as my mates quality ones .I will not be buying cheap coils again ,But i am glad i tried them for myself ..
  26. wez3570
    wez3570 Member
    704
    20
    New top mounts all round when originally installed.
    Springs are installed correctly, when u look at them it's virtually impossible to get it wrong.
    Alignment centre who fit coilovers all day long assured me they are installed correctly.
  27. Lings
    Lings Active Member
    2,059
    31
    Well last time i heard this had happened it was to RS on here ,the installers fecked his driveshaft up ...
  28. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Really sorry to hear you're having probs with these coilies Wez :(. I personally don't think it matters how much these cost you as - by the looks of your pics - they are NOT FIT for purpose!! It does look to me (not that I know a lot about them, granted) that they are perhaps not strong enough for the 3.2 you have. Perhaps whoever packed them at the factory put in the incorrect springs for your engine, which is pretty heavy, wouldn't be the first time I've heard of this happening. Have you contacted Damian @ DPM yet, Buddy? I think they need to be returned to JOM for replacements as other people on here who bought them have no probs. Whether you get what you pay for or not, ..this shouldn't be as it is. Really hope you get it sorted out, it's gutting when stuff like this happens and you end up out of pocket trying to solve it yourself :(. x
  29. Lings
    Lings Active Member
    2,059
    31
    also i beleive the diesel engine is heavier than the 3.2 ? Paddy ?
  30. wez3570
    wez3570 Member
    704
    20
    Thanks for the kind words Paullie, I thought I'd get some opinions before contacting Damien.
    When I looked at the springs compared to the S line springs, they are thinner metal which made me think maybe the 3.2 is too heavy.
    I'll drop Damien a message and direct him to this thread, rather than try and explain it without pics.
  31. wez3570
    wez3570 Member
    704
    20
    *UPDATE*
    Spoken to Damien today, JOMS are going back and I'm getting the V Maxx plus with height and damping adjustments.
    Been an expensive lesson, one I won't need to be taught again!
    FYI customer service from DPM is second to non.
    Thanks for your help guys and gals (well some of u) :whistle2: lol
  32. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Good outcome!
    DPM seem very good, will be getting the new bits for the next car from him.
    Just in case you haven't already, get some new top mounts fitted before getting these new ones fitted as (a) they should ride better in brand new mounts, (b) you won't suffer a top mount failure so soon and have to pay to get it all out again!
  33. wez3570
    wez3570 Member
    704
    20
    Yeah, DPM are really good. Pricebeater, free delivery and excellent after sales care.
    Top mounts all round are brand new, fitted about a month ago.
  34. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,265
    365
    the only thing i can think of is they must be the wrong spring rating as you have got a v6 under your bonnet they must be for a smaller engine model thats all i can think of buddy , is it only happening on the one side or is it both sides ??
  35. FranA3
    7,265
    365
    i know not a subject on the jom's but how much were your top mounts one of mine has let go and im sure the other one is going too , where did you get them from audi/euro car parts etc... cheers bud
  36. Paullie
    2,076
    288
    Great news, Wez! Your lovely new V Maxx coilies will be bringing a massive grin to your face very soon and you can put this episode right behind you and carry on enjoying your car! :wub: x
  37. FranA3
    7,265
    365
    yeah v-maxx's are very good coilies
  38. wez3570
    wez3570 Member
    704
    20
    Got them from euro car parts with an online discount code. All in was about £50
    Thanks Paullie, booked in for next Thurs, if they arrive in time. Apparently they come straight from the manufacturer.
    Tapatalk for iOS
  39. FranA3
    7,265
    365
    cheers mate im going to buy two of them as once one goes the other one is not far behind lol
  40. shady-ninja
    shady-ninja Active Member
    999
    53
    did you change your topmounts on your suspension.??
