Jimojameso's S3 S-Tronic Black Edition Stage 2+ Build thread
jimojameso Mar 6, 2013
  1. jimojameso
    jimojameso Active Member Team Nardo Section Mod Audi RS3 TTRS
    403
    180
    43
    Hello all,
    I have had my S3 a while now so thought i would throw a thread up of my build so far! :)
    I sold my mk5 golf gti last summer and made the change to an Audi S3 Black Edition. It was sad to see the golf go but i am over the moon with the Audi.
    Here is the car when i picked it up from the dealer. Fully stock with full Audi service history. :)
    The car was reasonably well specced but i couldnt live without sat nav after having an RNS-510 so i had a RNS-E and cruise fitted straight away. Thanks to DannyK9 for that!
    Next i got the roof and spoiler wrapped in black at Prestige wrap just to make the car look a bit meaner!!
    To get the stance sorted i fitted a set of -25mm H&R springs. I am very pleased with ride quality indeed. Is still very good.
    Starting to look mean now!! :ninja:
    Next was performamce mods. For Christmas my fantastic mrs bought me autotech fuel pump internals. Thanks to Rob at W8 for those!! :beerchug:
    I also persuaded my old man to get me a TTS engine cover to keep things looking neat.
    I treated myself to a VWR intake and full Milltek TBE from Awesome when they had their black friday sale.
    Came with a nice authenticity certficate.
    I also added an R8 oil cap and Porsche coolant cap.
    James
  2. jimojameso
    403
    180
    43
    Here are the mapping results from AMD! I went with Revo software.
  3. jimojameso
    403
    180
    43
    Had a little play with the sps switch! :)
  4. jimojameso
    403
    180
    43
    My forge spacers then turned up, so i was excited to unwrap them when i got home from work! These got the stance looking a bit better! :)
  5. jimojameso
    403
    180
    43
    Here are the spacers fitted. Very pleased with how the car looks now and after a good little test drive i can report no vibrations what so ever, so i'm very pleased. Here a few pictures. :laugh:
    JJWin likes this.
  6. S3Alex
    10,851
    4,838
    Nice results there,and good to meet another AMDTuning customer!
    Be very careful with the SPS,as it's possible to undo a lot of the good work already done with that interface,if you aren't totally sure of what you're doing.....I tend to leave mine pretty much alone and only ever use it if it's going near the dealer(which isn't often these days) or if I ever had to use 95RON fuel.
    Once it's adapted you may well see an increase in the mid-range torque,but the overall figures look pretty much spot on.
  7. jimojameso
    403
    180
    43
    Thanks Alex, all i did with the sps switch was take settings from the car and set up a channel for if i have to put 95ron in. So far though i have always managed to put V-Power in so not used it since then. :)
    Next i want to get a dsg map done but unfortunately all the tuners that offer this on the newer gearboxes are up in the midlands or up north. Probably going to get Shark to do it in April when i'm up that way unless anyone else has some bright ideas?
  8. S3Alex
    10,851
    4,838
    Mine is manual,so I may not be much use here,but do AMD or Revo not have something for you?......if Revo do,AMD would almost certainly be able to load it for you I would have thought.
    I either use V-Power or Momentum99 and wouldn't use anything else unless I absolutely had to either!.....having both water/meth and a boost controller does make life a lot easier as I can just switch the boost off if I needed to,but the SPS is such a useful piece of kit otherwise.
  9. jimojameso
    403
    180
    43
    I'm tempted with wmi. Hurdy on mk5gti has made some really good power with it on his R. 390bhp, 460 lb/ft. He does however have a giac extreme map with the 3" intake. Alex did you run it on yours back when you were 2+? :)
    Unfortunately both revo and apr haven't cracked post 2009 gearboxes. Revo have told me they are planning to get this done this year but apparently they have been saying that for ages.
  10. S3Alex
    10,851
    4,838
    I think both those companies have said the same,so if you can find a solution elsewhere,go for it.
    I have to say I'm surprised at the torque figures there,but I've no reason to doubt them,but I would be a little concerned if that's on stock internals,as 460lbs is pushing it a bit.
    I didn't bother with WMI or a big intercooler on Stg2+,but to look at it from another angle,if you ever plan on going further,then I would get both,as you do need them for Stg3 or 4,and at 2+,you won't notice any drop-off in hot weather,so cost aside,both are worthwhile.
    Hurdy has basically gone a different route to those results from me,and by using the Loba turbo he's avoided the need for a lot of what I've done but the bigger turbo on mine gives a LOT more top end power,and you don't get the torque drop off either.
  11. jimojameso
    403
    180
    43
    Thanks for the info Alex!! This forum does nothing apart from encourage you to spend more money!! Ha ha. Had a good read over your thread a while ago. Must resist. :)
  12. S3Alex
    10,851
    4,838
    Thank you!.......It's much easier to simply give in to the need for speed.
    What all this does show is that there are several ways to crack the same nut,and despite what some of the tuning companies say,most of them work,albeit by different routes.
    Hope you enjoy the car,and may see you sometime at AMD.
  13. jimojameso
    403
    180
    43
    If i see you there i'm gonna make you take me for a spin in the 500BHP BEAST!! Ha ha :)
  14. S3Alex
    10,851
    4,838
    You can pay for the petrol!...LOL....seriously though,you'd be more than welcome,once it has wheels and brakes!
  15. smurfworth
    smurfworth Well-Known Member Audi S3
    1,954
    548
    Absolutely gorgeous, love it!
  16. daniel.ireland
    daniel.ireland Member
    111
    31
    Awesome :thumbup:
    Good changes
  17. N8
    17,163
    720
    Nice looking motor!
  18. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Looking stunning James, looks so much better than I remember, and even then it was still stunning.
    It was a pleasure working on your car fella. Enjoy!!
  19. jimojameso
    403
    180
    43
    Thanks for the kind comments peeps :)
  20. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    Lol its like reading my own thread! I did roof and spoiler at Prestige Wrap too, good lads working on thier website. In regards to the intake did you check your car's fuel trims at all? Mine were about 10-14% and have had to return it back as its above engine spec therefore car could run a bit too lean. Would be nice to meet up at some point:]
  21. jimojameso
    403
    180
    43
    Ha ha great minds! I work over in woking actually so not far from you at all. We'll have to get a southeast s3 meet set up!
    Regarding the vwr intake i checked with vwr and mine is from a good batch according to them. When AMD had it on he rollers everything was ok. I just got dash command last week so i will have a look at the fuel trims when i got it all working. I'm tempted with the revo intake! Very nice!! :)
  22. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Looks lovely. Very similar spec to mine in terms of modifications.
  23. RedDejavu
    1,806
    337
    Nice one! Coffee meet up would be nice at some point if we can get more ppl up for it:].
    mine had the MAF pipe replaced but still wasnt giving fuel trims low enough so i returned it and bought AMD:]. Fitting it Sun with some other bits at AMD Essex.
  24. S3Alex
    10,851
    4,838
    As you're an AMD customer,you should also take a look at AMDTuning's own intake here.....
    http://www.audi-sport.net/vb/news-l...uning-2-0-tfsi-induction-kit.html#post1807334
    It may not be as pretty as Revo's,but it's well thought out,very smoothly tapered around the MAF,and the largest I've seen....and it's going on mine.
  25. BigWillyStyle
    BigWillyStyle Member
    566
    58
    Loving the car. Spacers Definitely an improvement.
    What colour are your alloys? They look bronze like in some pictures....or is that just me?
  26. jimojameso
    403
    180
    43
    Thanks mate yeah the spacers made it look so much better. The wheels are are the standard black edition colour. Anthracite i think its called. The photo's arent the best as i only took them on my phone. :)
    Thanks for the input on intakes. I'll keep an eye on my fuel trims. I looked at the AMD intake aswell but the Revo one is just so pretty ha ha :)
    If i do have to get another intake i'd be tempted by getting a 3" one along with the GIAC extreme engine map because that produces a lot more torque.
  27. jimojameso
    403
    180
    43
    When the weather gets better i'll set up a south east meet thread and see if we get much interest. :)
    S3Alex likes this.
  28. jimojameso
    403
    180
    43
    Oooo it looks nice in the white!! :)
  29. S3Alex
    10,851
    4,838
    That's good.
    I'm usually up for that sort of thing.
    Show me some coffee and I'm there. Lol.
  30. The Engineer
    The Engineer Member
    356
    22
    Zak0123 likes this.
  31. dRicKyy
    dRicKyy New Member
    Your car is looking sweet! Where have you bought that emblem? Looking forward to have one too.
  32. jimojameso
    403
    180
    43
    Thanks matey. Its an apr badge but i just didn't use the apr part. Badge is available from awesome gti :)
  33. dRicKyy
    dRicKyy New Member
    Haha thanks a lot mate! I did my 2.0tdi remap couple days ago so I don´t feel bad about to order that one lol :arco:
  34. jimojameso
    403
    180
    43
  35. jimojameso
    403
    180
    43
    Another little update. Cleaned the car this morning then got dash command running. I can now wirelessly look at all engine information on my iphone or ipad. Pics of guages working just after engine started :)
    ImageUploadedByTapatalk1362918569.534249.jpg ImageUploadedByTapatalk1362918580.038829.jpg
  36. S3Alex
    10,851
    4,838
    Thats rather nice.....maybe another toy for me there.
  37. XFi
    XFi In need of a V8.
    491
    47
    What size spacers are those forge items if you don't mind me asking? Do they rub at all?
  38. jimojameso
    403
    180
    43
    The spacers are 11mm all round. I have absolutely no rubbing at all even with 2 people in the back but i did cut down the rear arch screw tab as recommended by people on here when i fitted them. This is very easy to do and takes 2 mins. If you need a picture of it just let me know. :)
    Don't forget if you get the forge spacers you will need to order sepeartely longer wheel bolts and longer locking wheel nuts.
  39. jimojameso
    403
    180
    43
    Small update.
    I always wanted recaro's when i was searching for the right S3 but didn't manage to find one in the spec i wanted at a decent price. Anyway finally got some recaro's and went for the RS4 ones. They are retrimmed in red nappa leather and i'm over the moon with them. Door cards and rears will be done to match once my bank account has recovered a bit. :)
    One of my fav mods so far! They hold you in the seat so much better and look the business. Always used to slide around a bit in the bends, even more so for the passenger who don't have the wheel to hold onto :)
    S. and BigWillyStyle like this.
  40. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,082
    575
    love them. would love recaros for my car.
