Jetseal109 or collinite
shariain Nov 8, 2012
  1. shariain
    shariain Well-Known Member
    1,182
    190
    Which would you choose and why.
    Told her in doors was wanting a da polisher so will be getting used by da and also by hand.
  2. shariain
    1,182
    190
    Someone must have an opinion on these 2 products.
  3. the_cueball
    the_cueball Active Member
    494
    218
    43
    if it's collie 845, I've used it before... it's OK, lasts for a good while...
    :thumb:
  4. Rom
    Rom Member VCDS Map User
    443
    I've tried some collinite stuff. It's not bad.
    Not tried jet seal.
    Now I use Zaino range.
  5. Juicy Jen
    Juicy Jen Jen @ Juicy Detailing Site Sponsor
    828
    121
    Both are synthetic products (ie. man made) and offer excellent durability with a few coats of each product your looking at between 8-12 months durability.
    They offer a more glassy look rather than wet that you can achieve from a wax/ organic based product.
    Jetseal 109 is very easy to apply and buff off - apply a coat to the whole car, leave for 20 minutes and buff off and then repeat. It can be applied either via hand or using a glaze/finishing pad via DA.
    Collinite can be a little more picky (that's any of their range) and you need to apply to only a couple of panels at a time as it will cure within 10 minutes. If you leave it too long its a PITA to remove and you'll get arms like popeye! Only the 845 can be applied via machine all the other need to be done by hand with a foam applicator.
    Hope that helps :)
  6. shariain
    1,182
    190
    Thanks looks like I'm buying some jetseal 109 to give it a try.
  7. Juicy Jen
    828
    121
  8. moag
    moag she's no d-turbo
    821
    35
    Jetseal!
    I've tried lots of different waxes and synthetic sealants on my car over the past few years and so jetseal has provided the best finish for me so far. Wipe the car down with hybrid v7 after applying the jetseal and after washing to improve its durability!
