Jetex filter install help please!
Ginge Feb 2, 2011
  1. Ginge
    Ginge It's never fast enough !
    192
    Right so iv'e installed the jetex cone from Bill (Thanks!!) and it is awesome! :)
    However there is a pipe that came off the air box that im not sure what to do with :) any help please
    ^^ overview
    ^^ actual pipe :)
  2. superkarl
    superkarl MAN OF STEEL
    9,467
    2,420
    weird i've never seen that before
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    secondary air i think just buy a little filter to go on it .....done
  4. finesse
    finesse Active Member
    2,805
    it's a mystery :)
  5. <tuffty/>
    21,140
    3,828
    Looks like your S3 is a non ESP APY so that would be the SAI pipe... you will need a little filter (crankcase filter or similar) as Dave has mentioned or just do an SAI delete...
  6. g10chy
    g10chy Member
    155
    I don't have that either!
  7. Ginge
    192
    Thanks guys :) whats the advantages of the sai delete, can I just block the end or will that cause problems ?
    thanks again :)
  8. coyle
    coyle From Show... to GO
    435
    I have the same issue, mines just like urs in the picture.
    Il need to get a filter or something as said above.
    Mines APY with ESP
  9. Ginge
    192
    What happens if i dont put a filter on it ??
  10. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Breather filter will do the job.
  11. s3dave
    10,110
    736
    Well it was filtered in the airbox so you need to filter it to stop **** getting into the secondary air pump....or delete it altogether
    they have them on APY with esp too, yes
  12. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    correct all APY's have secondary air system ESP and Non ESP
  13. Ginge
    192
    Thanks for all the help once again guys, all sorted with a little 28mm cone filter off fleabay :)
  14. coyle
    435
    I just did an SAI delete intstead :)
    Ive got a 3" tip from bill, then my jetex is straight on the MAF,but this leaves the jetex a few inches from the wing.
    So id like abit of silicone between the MAF and the filter, maybe just 2inches long.
    My question is, internal diameter of the hose needed?
    I thought 80mm would go on the maf and filter, my mate thought 76mm?
    Any ideas?
  15. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    ESP APY engines have them as well dude to be fair.
    Mine did, many moons ago....
  16. coyle
    435
    Yep, mines APY ESP, all APYs have SAI
    (enough use of 3letter abreviations?!)
  17. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    how much are the jetex filters anyone iv forgot tar
  18. s3dave
    10,110
    736
    £45...ish
  19. coyle
    435
    £62-£64 delivered from bill
  20. audi_a3_turbo
    audi_a3_turbo Member
    215
    sorry whos bill? lol
  21. s3gazz
    1,376
    99
    cheers everyone
  22. <tuffty/>
    21,140
    3,828
  23. coyle
    435
    Anyone know the size of silicone i need??
  24. Prawn
    11,500
    3,411
    80mm :)
  25. coyle
    435
    Is there a decent way to sort out a cold air feed? as the one which was used on the standard airbox isn't great with a jetex in its place.
  26. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    I believe Jabba do an enclosed unit/case that installs in the original airbox mounts.... Would be curious to know if they still do it, may give them a call.
  27. JS1500
    JS1500 Howdy
    1,166
    10
    Try working with helicopter manuals, it's an abbreviation nightmare!
