Jerky acceleration
M88UES Mar 29, 2012
  1. M88UES
    M88UES Theres Never Enough Power
    60
    Ive started getting a wierd acceleration problem and i dont know if its turbo or clutch slip
    when i put my foot down in 2nd its pulling then jerkin then pulling then jerkin like a kangaroo. a bit like how you would nearly stall but obv im doing between 15-40mph at this point.
    any ideas?
    got to add my turbo's whining is getting louder and louder
    chris
  2. Best84
    Best84 Member
    137
    tfsi or tdi??
    Edit.. I'm being blind its obviously tdi.
    I had the same sort of problem last week, tandem pump failed. check your fuel doesn't have oil in it.
  3. M88UES
    60
    how do i check that mate?
  4. Brodster
    Brodster Well-Known Member Team Ibis Audi S4 Audi Avant Owner Group
    3,548
    886
    Have a look at your fuel filter if its a TDI. My previous car the tandem fuel pump seals failed which allowed oil to track into the fuel system which in turn clogged the fuel filter. Just take the top off the fuel filter and have a look. If its clogged with oil then the tandem fuel pump seals could of perished. Not that expensive either......defo a DIY job as pump change and fuel filter change. The Audi garage stressed that all fuel components would have to be cleaned or replaced but oil is combustible and diesel contains oil anyway.
    The fuel filter sits just to the left of the engine. Large cylinder with pipes coming out of the top of it.
    M88UES likes this.
  5. Best84
    Best84 Member
    137
    I pulled the fuel temp sensor out, was covered in oil.
