JEFF's Acrylic or Carnuba for Sprint Blue
Juniper44 Jul 8, 2008
  1. Juniper44
    Juniper44 Member
    47
    Hi Guys
    Just looking at the wax protection products and wondered which ones were best for Sprint Blue.
    Tania
  2. jamiekip
    jamiekip Guest
    Hey,
    Polished Bliss recommended the acrylic for mine based on the fact the acrylic kit really brings the flake in the paint out.
    I've not tried anything else since as it does such a good job, is easy to use, can be built up easily over a few washes and then lasts for a good 4 months.
    Washing in that time becomes pretty easy, as getting rid of the worst of the dirt build up is a simple blast at a jet wash (never use the brush!!!) meaning bigger cleans are less frequent (a bonus in London!).
    Thoroughly recommend this product.
    Some pics to show you the finish you can expect:
  3. Ian W
    Ian W Active Member
    1,058
    12
    S3 above looks lovely :drool:
  4. Juniper44
    Juniper44 Member
    47
    Jamie - S3 looks really good in the pics. Just out of interest do you clay yours every 6 months? If so what have you used.
    I've only had my S3 since March so want to make sure i keep it looking sweet for as long as possible.
  5. jamiekip
    jamiekip Guest
    Hey Juniper,
    I got in touch with Rich at Polished Bliss before receiving the car - it was my frist car from brand new and I wanted to make sure I looked after it properly. Rich recommended the Werkstat Acrylic kit (amongst many, many other questions!)
    The car was delivered in a lorry to me and was immaculate when it arrived.
    Before I even took the car out for a spin I set about adding the Werkstat Acrylic kit, Prime first, then a couple of layers of Jett.
    Every wash after that I added another layer up until I got to about 5 or 6 layers.
    Then added another couple of layers of just the Jett every couple of months.
    The car stayed looking in great condition, but then had this issue to contend with:
    http://www.audi-sport.net/vb/showthread.php?t=55348
    Since getting the car back after this I have given the car it's first clay, that was after about 14 months of ownership and a long drive to the alps and back. Keeping on top of the Werkstat applications means it's harder for the contaminants to bond to your paint and you therefore need to clay less.
    When I do clay I use meguirs mild clay - I don't trust myself with anything harsher.
    Other top tip - always wash your car yourself - mines not gone near any cheap hand car washes or jet/drive through washes as the brushes just put fine scratches all over the car.
    Long answer... but hope it helps.!
  6. danny_s3
    danny_s3 Member
    234
    what a night mare!!! im hearing a lot of good things about this jett wax.
    like you said , if want a proper job doing, do it yourself.
  7. Juniper44
    Juniper44 Member
    47
    Sounds like you have been through the mill with yours.
    Thanks for the advice though, since i have had mine have been very careful with regards to washing (the polished guides helped immensely) I will always wash it myself and the longest it has gone without a wash is about 4 weeks.
    Got some good products also from polished bliss, it had a great coat of wax on it from new and was in tip top condition so didn't want to overload with wax.
    I'm tempted to clay in a couple of months time then apply the acrylic kit so the wax is going onto a perfectly clean surface.
    Thanks for the help.
    BTW - you still loving the car? I'm loving it (especially when people look at the car and see a woman driving it)
  8. khalil
    khalil Member
    774
    so do you use "Werkstat Acrylic Glos" http://www.polishedbliss.co.uk/acatalog/werkstat-acrylic-glos-maintain.html this every time you wash your car?? also do you spray this all over your paint work??
    so whats the difference between "Werkstat Acrylic Glos" and (lets say) "Meguiars NXT Spray Wax" http://www.fasteronline.co.uk/Meguiars-meguiars-spray-g12824-p-2296.html or are they the same sort of things?
    also whats a "quick detailer" (Werkstat Acrylic Glos)
  9. White220
    White220 White 220
    64
    Khalil,
    As per the PB guide the Prime should be used first (after optional claying) This cleans up the body work and leaves an initial base of acrylic to begin with, residue of this prime is occasionally a bit tough to remove (I have not found it hard) so the glos is used to cut the prime and should be wiped off before moving onto the trigger stage.
    The trigger is applied last and as someone else will probably confirm is a glaze or sealant step as opposed to a wax. The trigger can sometimes be hard to fully buff off and as before can be cut by the glos. I hope this helps!
    I use this system and whenever I have long enough to do my cars I like to apply the trigger and buff off to such an amazing shine and a car that is so slick and easy to wash the next time.
  10. khalil
    khalil Member
    774
    so the "Werkstat Acrylic Glos" is only used to cut the other products? i thought you can use it after every wash to boost the shine, meaning every week when you wash your car you spray that on and dry it off,is that right? or is it only for cutting the other products?
  11. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    The primary purpose of Glos is as you suggest, i.e. for a quick wipe down after washes to fully remove any water marks and add more gloss (plus a little bit of extra protection - think of it as a sealant booster). The second function it performs very well is an aid to residue removal for Prime and Jett if needed. :icon_thumright:
  12. White220
    White220 White 220
    64
  13. jamiekip
    jamiekip Guest
    Mucho respect for the pride you are taking with your motor! :thumbsup:
    You can't go wrong with the guys (and gals!) at Polishedbliss. They have helped me so much answering all my questions and giving completely impartial advice.
    If I were you, I'd strip the car back to it's paint using somethign like this:
    http://www.polishedbliss.co.uk/acatalog/p21s-total-auto-wash-wash.html
    This will remove all the current wax/sealent on the car.
    When you have used this and washed the car as normal, run your hand across the paint. Sometimes putting your hand in a platsic bag helps you feel the imperfections on the paint surface. If the paint already feels glass smooth you've got the perfect base to start on already. If it feels rough you're car is ripe for claying!
    No prob's with the help!
    Regarding loving the car, yes, had it 16 months now and I'm still really pleased with it. It's not missed a beat and ticks all the boxes bar one that I'm after (the missing one is the engine noise.... need a V6 or V8 to tick that one!).
    Ha ha, yes I imagine you do get a few green eyed looks!:yes:
