Jay A3 KO4 build
Discussion in 'A3/S3 Forum (8L Chassis)' started by Jay A3, Dec 8, 2011.
  1. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    I will get some better pics soon...
    The springs on the car were standard,
    It did look like it was lowered. Maybe the bushes and top mounts were that worm it gave it that look lol
    Well having fat chicks was a temporary and cheaper alternative to changing the suspension at the time... Thanks for the numbers Reesy. You can have your girls back now...
    I am still debating if I should change them now westy... The suspension seems to have sorted out the under steer and lack of grip I was getting.
  2. Google AdSense Guest Advertisement
    to hide this advert.
  3. Westy
    Westy Double Dark Side! Diesel & 8P
    Dec 2, 2008
    17,358
    1,007
    It'll make it even better though :eyebrows:
  4. s3dave
    s3dave TFSI Hybrid
    Supporter
    Nov 11, 2009
    10,120
    732
    Top Work Jay....coming along nicely....:icon_thumright:
  5. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Thank you westy.... Your always there to help spend my cash :D
    Ive never hated and loved someone at the same time before!
    Cheers Dave! This is just the beginning!
  6. Westy
    Dec 2, 2008
    17,358
    1,007
    :friends:
  7. ChaddyA3
    ChaddyA3 Member
    Jan 12, 2012
    254
    Looks great buddy, can you please take a pic or 2 of your front grille as im thinking of doing the same :)
  8. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    [​IMG]Just for you!
  9. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Finally got this sorted!Originally scanned the car for faults and it said the coolant temp sensor working intermittently, so it would make sense to change the Green sensor right? Wrong. Turns out is was the thermo stat on this occasion. The general wear and tear of a 14 year old stat finally went. I did the digital reading on the climate control and the stat was opening at 51 degrees! Took the old stat out and you could see it was leaking. Bought the new stat from TPS. I don't have an image but if you look at the bottom of the stat you should see the number 87. 87 represents the temperature of which the stat should open to allow the g12 mixture through. Car is running nicely and heating up to 90 degrees, mpg has also restored.
  10. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Next on the list...
    Not changed one before but on a scale of 1-10 (10 being a right PITA) is it fairly easy to switch it over? I do have access to a car lift so i can get under it.
    25mm Eibach Anti roll bar for the front. Good idea or bad?
    My concern with the 25mm bar is will it fit as ive read some times the bar can rub and you need to look into adjustable drop links...
    The other option pointed out to me was the Mk4 TT arb - 19mm
    Advice would be greatly appreciated!
  11. ChaddyA3
    ChaddyA3 Member
    Jan 12, 2012
    254
    Thanks Jay, really looks great :) your help is much appreciated :) Keep well
  12. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Been awhile since i got round to doing anything... More successful weekend for me.
    So my calipers and carriers have been sitting in the garage for a while rusting away.
    Got them cleaned up again
    Masked up
    Sprayed
    I got the paint from Brake Caliper Specialist
    The paint didnt require applying lacquer. They supplied the 325ml paint (enough to paint two coats on front and rears) 100ml of hardener and degreaser. I got these sprayed rather than paint brushing it on - 2:1 mixture (Paint:Hardener) Leave for 20mins, then apply final layer and leave to fully dry over 24hrs.
    Fitted these back on along with the 312mm discs
    Side view - hopefully a slightly better view of the calipers and 35mm drop i did a few weeks back
    Hope you like
    Next week, going to paint the rears and bleed the whole system, replacing the brake/clutch fluid with RBF600 or RBF660
  13. Sandra
    Sandra MODERATOR
    Staff Member Moderator Gold Supporter TeamMisano quattro Audi S3
    Sep 12, 2010
    19,185
    3,615
    ​Looking good Jay. Good weekends work. :)
  14. Westy
    Dec 2, 2008
    17,358
    1,007
    Really liking the yellow mate.
  15. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Cheers guys! :icon_thumright:
  16. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    This turned up on Friday
    The silicone pipes were delivered yesterday but bloody delivery company left a card rather than ringing the door bell ! So i now have to wait till monday before i can get my hands on them... :crying:
  17. CHEZ
    CHEZ moderately amusing
    Supporter
    Jul 9, 2011
    3,822
    574
    lookin good james!
    lovin the rims mate! .....................giz them?
    keep well.....
  18. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Hey chez
    Thanks mate
    hows your car going? keeping it well?
  19. CHEZ
    Supporter
    Jul 9, 2011
    3,822
    574
    its been in audi to get looked at fella!
    i thought it was the dreaded oil pump on its way but turns out its the fly wheel that the mickey mousse garage put in is shizzle!
    got a slight vibration at 2000rpm and the garage wont entertain me as they said its not bad enough to take apart again the toss pots!
    i have to wait until its goosed!
    other than that i am keeping well bro! :beerchug:
  20. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    That dont sound good? Surely if you can notice it then its bad enough to get changed?
    I thought its best to change things early too avoid any other problems? Not that audi have problems of course :whistle2:
  21. Customboy
    Customboy Member
    Jan 25, 2012
    837
    41
    Looking good mate I smiled so much when I got my forge fmic! And once u fit it with the turbo watch how much you will smile then!! People call me the Cheshire cat when I drive lol
  22. Google AdSense Guest Advertisement
  23. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Your not wrong there mate! There was plenty of grinning going on when rtech first remapped my car!
    Cant wait, i hear that the k03s turbo has a different sort of pull (slightly more aggressive) than the standard k03.
    What tip did you go for? Just a forge one?
  24. damo.h
    damo.h DVLA Say it's Black
    Feb 9, 2010
    3,610
    66
    Nice littl touch with the yellow dude, all coming together nicely. When you hoping to get it on. Is it a job for the LNM crew ;)
  25. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Cheers Dameo!!! i thought the yellow would stand out more against the black n white. I was going to ask you if you can source me some gloss black 3M wrap?? :eyebrows:
    Next month or so is the plan... The LNM is currently fully booked with the preparation for project 300.
  26. Customboy
    Customboy Member
    Jan 25, 2012
    837
    41
    Hi jay I used the neuspeed tip as its less restrictive and made a big difference !
  27. damo.h
    Feb 9, 2010
    3,610
    66
    Haha bugger!! You just have to stare at it on the garage floor for a while then mate.
    Juat let me know when and how much you need dude and I'll ship it down to you. :thumbsup:
  28. ChaddyA3
    ChaddyA3 Member
    Jan 12, 2012
    254
    Looking Boostifull buddy, Great progress so far and cant wait to see pics when the FMIC is on :) Cheers
  29. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Well I'm not far from the ground so I won't get neck strain lol
    Enough to do the roof mate and then a little extra as I am an amateur at it...
  30. ScottD3
    ScottD3 I want your faulty electronics
    Supporter
    Nov 24, 2010
    15,274
    1,082
    Don't forget the heat gun and the other things that damo bangs on about like a 3 year old with a new drum.
  31. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    He has the whole speech saved somewhere Scott. I've already been through it, heat gun all sorted. Need to get a quality knife set for the cutting
  32. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Small update...
    I got round to cleaning up the rear callipers this weekend for spraying, same Ferrari yellow as the fronts. I thought at the same time since everything was changing over, I decided to get the system bled and replaced with new brake fluid “RBF 600” I did look into the RBF 660 but for an extra £5 per bottle for little difference I didn’t see it as being worth it. (3 / 4 degrees higher temp in the RBF 660)
    While the car was on the ramp I also noticed the arb bushes were gone, so £10 for a set of bushes and job done.
    I got a chance to work on the bonnet this weekend. Originally it was silver then I wrapped it in black carbon fibre. Looked nice but attracted a lot of unwanted attention and very boy racer. Took the bonnet off to allow more room; applied with a bit of heat and the wrap peeled off within seconds. Grabbed the 1200 sandpaper and started to clean it up smoothing out and taking off a small amount of the lacquer, primed and then sprayed in matt white.
    Picture before:
    After:
    I think this looks better and smarter...
    Some special post turned up on Saturday to help smarten up my engine bay. ScottB5 organised a group buy on a water and oil caps from Porsche. Again thanks Scott! Caps look mint and fit a treat!
    Hope you like!
    Dropped my K03s up to Beach buggy today for a refurb, buggy pointed out the housing had a 2 cracks on there, felt a little heartbroken, might need to start hunting for a k03 housing in good condition, although the K03s before I bought it had no issues and definitely no smoke. Going to wait on the verdict from buggy to see what he can do...Fingers crossed!
    #70 Jay A3, Apr 1, 2012
  33. ChaddyA3
    ChaddyA3 Member
    Jan 12, 2012
    254
    Looks awesome in white buddy :) also loving the new caps they look great aswell. Fingers crossed for your turbo buddy, hope all turns out OK :) Cheers
  34. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Cheers Chaddy
    Credit for the caps all go to Scott.. all i did was hand over the cash. He tested them and made sure they fit.
    I will hear sometime this week about the turbo. got my toes crossed aswell!
  35. s3dave
    s3dave TFSI Hybrid
    Supporter
    Nov 11, 2009
    10,120
    732
    Nice work Jay, shame about the cracks in the turbo, but i think a lot have them without hindering performance....
    PS wheres the caliper pics??....;)
  36. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Calipers arent anything special dave.. not really visible behind my wheels haha
    Yeh buggy is going to check out the turbo for me and see how serious the cracks are.
  37. Westy
    Dec 2, 2008
    17,358
    1,007
    Looking much more grown up with white mate. Get those rims refurbed a lighter colour now and it'll look sooooo good :)
  38. damo.h
    Feb 9, 2010
    3,610
    66
    Well Scott I am a believer of "if you going to do it, do it right or fk off" :moa:
    Saved in the grey matter jay lol, as for knives ill send you some no2's down with the vinyl bro.
    looking so much better now you changed the bonnet, think the gloss black will improve the looks even more mate.
  39. Reesy
    Reesy Well-Known Member
    Jan 20, 2010
    3,627
    142
    Agreed, those wheels are too nice to be black..
    And the white bonnet looks much better. Now you wont get grannies in Micra's looking to embarrass you off the lights :cheers:
  40. camscockle20vT
    camscockle20vT The stigs ugly brother
    Nov 18, 2010
    1,743
    75
    Hi dude, just had my first proper read of this thread, looks awsome, with lots of effort.
  41. Jay A3
    Jay A3 More power
    Mar 5, 2011
    2,006
    304
    Cheers mate! Slowly getting the bug... Don't know why I didn't start modding my Audi years ago! Do I dare say thank you ASN??
  42. beachbuggy
    beachbuggy Well-Known Member
    Jan 27, 2010
    1,842
    164
