Jay A3 KO4 build
Discussion in 'A3/S3 Forum (8L Chassis)' started by Jay A3, Dec 8, 2011.
  1. Prawn
    Offline
    Dec 8, 2006
    9,913
    1,614
    [Jul 17, 2014]
    if the map, maf, and injectors are the same as they were on the ko3S, it should be fuelling just fine shouldn't it?
    Or have you stuck larger injectors in already before the map jay?
  2. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Jul 17, 2014]
    Don't be silly prawn, I wouldn't make such a noobie mistake. I would pm everyone first to check :p
    Yeh exactly same setup, maf and injectors on the k03s map
  3. BENJAMIN
    Offline
    BENJAMIN Active Member
    Mar 3, 2011
    501
    82
    [Jul 17, 2014]
    Lambda position is a little different, that's my thoughts.
  4. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Jul 17, 2014]
    Do I need to move it to the second position? Hope not if I recall the second position is bunged and welded....
  5. aragorn
    Online
    Jan 30, 2008
    16,000
    364
    [Jul 17, 2014]
    lambda isnt used at WOT on M3.8 AFAIK, so its not going to be lambda related.
    Jay A3 likes this.
  6. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Jul 17, 2014]
    Just checked my oil and it's fine. Sitting on the max line. Looking really clean too! Been told to keep an eye on it, so I hope it simply is just over fuelling...
  7. BENJAMIN
    Offline
    Mar 3, 2011
    501
    82
    [Jul 17, 2014]
    Weirdly it does seem to play a part on the agu as to where you position it. We've had a few issues with lambda position. On the transition between closed loop and open loop you get a puff of fuel that dissipates. Also can have an affect on trims.
    On the same token, Some agu's are more sensitive than others. I know niki has had it before. Odd!
  8. Prawn
    Offline
    Dec 8, 2006
    9,913
    1,614
    [Jul 17, 2014]
    AGU's are fecking odd! I've had several issues with lambda position before on my various setups.
    If the lamda is moved, it changes the trims, and it seems to apply those changes at WOT also even though it's not relying on the sensor at WOT as it's open loop. God knows if it's meant to. They do weird things at the best of times!
    A3-Lee and BENJAMIN like this.
  9. superkarl
    Online
    superkarl MAN OF STEEL
    Mar 28, 2010
    7,972
    1,348
    [Jul 17, 2014]
    I ate a big red candle
    CHEZ, Jay A3 and Prawn like this.
  10. BENJAMIN
    Offline
    Mar 3, 2011
    501
    82
    [Jul 17, 2014]
    Sure it wasn't a big red rubber dildo?
    ScottD3 and Westy like this.
  11. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Jul 17, 2014]
    Safe assumption
    Westy and BENJAMIN like this.
  12. superkarl
    Online
    Mar 28, 2010
    7,972
    1,348
    [Jul 17, 2014]
    ****, I wondered where the wick was
  13. Westy
    Offline
    Westy Double Dark Side! Diesel & 8P
    Dec 2, 2008
    17,349
    1,001
    [Jul 18, 2014]
    He's had that thing stood up in the middle of the dinner table for months but it would never light!
    MIGGZ and superkarl like this.
  14. superkarl
    Online
    Mar 28, 2010
    7,972
    1,348
    [Jul 18, 2014]
    dinner party with the family and everyone was acting dead weird!
    Jay A3 and Westy like this.
  15. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 2, 2014]
    Waiting for this remap is killing me. I have been looking for something to do... Decided my headlights were looking a bit yellow and needed a bit of upgrading. Sourced a spare set from Reesy
    So firstly I removed the indicator and the levelling motor.
    *tip
    Twist the motor to become undone but don't remove it yet as it's still connected to a clip inside. Turn the adjuster at the top so it moves the light towards the rear.
    This makes it easier to remove. Tilt the motor and slide it out the clip. They have a tendency to snap but can be bought of eBay for £4 each. Easy to replace.
    Remove screws on the indicator side x 3
    Remove seal
    Pry off the 4 metal clips holding the lens on (2 top and 2 bottom)
    Pre heat the oven to 120 degrees. Place the headlight in the oven for 3-4 minutes, this will soften the silicon. Bit tricky but with a flat screw driver and a knife it will come apart.
    The light holder itself comes off by unscrewing the adjusters pushing the light out to the front as much as possible
    Everything else comes apart easily
    Took off all the chrome and with a scotch pad (picked up halfords)
    Out comes the black satin paint. Applied around 2 layers
    Put back in reverse order. Before I dropped the lens back on, I put the unit back in the oven for a few minutes to soften it up again to get a good seal.
    Word of warning the adjuster / cogs can be a bit fragile and worn. Not sure if these can be easily sourced, but luckily I had my old unit as spares
    I will get a pic with these on the motor later on today
    Alex C, VAG-Slag and g60leigh like this.
  16. g60leigh
    Online
    g60leigh Well-Known Member
    Jun 16, 2007
    1,445
    138
    [Aug 2, 2014]
    Nice write up Jay. When will mine be ready
  17. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 2, 2014]
    Easy to do yourself mate ;)
  18. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 2, 2014]
    MIGGZ likes this.
  19. BENJAMIN
    Offline
    Mar 3, 2011
    501
    82
    [Aug 2, 2014]
    Nice one jay, they look great.
    Jay A3 likes this.
  20. g60leigh
    Online
    Jun 16, 2007
    1,445
    138
    [Aug 2, 2014]
    Definitely look better.
    A+ for effort. Go to the top of the class.
    MIGGZ and Jay A3 like this.
  21. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 2, 2014]
    Cheers fellas :)
  22. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 11, 2014]
    The headlight lenses were a little scratches up so I thought I would try the meguiars restoration kit. Comes with sanding pads, plastX and a polishing head.
    Turned out nice enough, needs another go at it but impressed with the kit
  23. Prawn
    Offline
    Dec 8, 2006
    9,913
    1,614
    [Aug 12, 2014]
    car is looking really good Jay! Be great to see what it makes when mapped :)
    Jay A3 likes this.
  24. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 12, 2014]
    Yeh I can't wait to get it mapped! Currently on the hunt for some saab redtop injectors and the car is ready. Well one or 2 more oil changes.
    I'm just phaffing around with cosmetics at the moment as I'm so bored waiting...
  25. MIGGZ
    Offline
    MIGGZ nanananananananan BATMAN
    May 17, 2012
    1,292
    207
    [Aug 13, 2014]
    wow saw that kit here and never took much to it, now i know im gona get one sort my lights to look as pretty as yours :superman:
    Jay A3 likes this.
  26. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 13, 2014]
    It's not bad, the sand paper pads they give you isn't enough imo. But the plastX stuff works very well
    MIGGZ likes this.
  27. Tim_Attard
    Offline
    Tim_Attard Active Member
    Nov 12, 2012
    466
    43
    [Aug 19, 2014]
    Nice one mate, k04 is very nice. cant wait to get mine mappe too!
    Jay A3 likes this.
  28. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 24, 2014]
    Time isn't going quick enough Tim!
  29. Neru
    Online
    Neru Member
    Jan 21, 2012
    129
    9
    [Aug 24, 2014]
    this looks amazing, I wanna paint mine the same colour after seeing yours
  30. superkarl
    Online
    Mar 28, 2010
    7,972
    1,348
    [Aug 24, 2014]
    put your watch forward then!!
    MIGGZ likes this.
  31. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 24, 2014]
    Don't think rtech would squeeze me in if I did
  32. antwan64og
    Online
    antwan64og Active Member
    Nov 13, 2013
    338
    59
    [Aug 26, 2014]
    Any chance the new fuel pump has exposed a failing fuel pressure regulator causing a rich issue.
    Kinda like how a new clutch exposes a failing clutch master cylinder.
    Stock A3 pump flows ~ 84 Lph
    S3,TT225, LCR pump flows ~ 108 Lph
    Sytec ITP331 flows 195 Lph @ 3 bar and 174 Lph @ 4 bar
  33. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 26, 2014]
    I see what you mean. The new fuel pump was installed prior to the engine swap and was fine on the k03s setup. Same map, same injectors, same fpr. Only difference is the k04 turbo...
  34. antwan64og
    Online
    Nov 13, 2013
    338
    59
    [Aug 26, 2014]
    The only thing to change that could affect the tune is the o2 sensor location.
    Have you pulled your plugs to see how they look? If they're badly fouled i'd be inclined to change them.
    On any other older car i'd say just unhook the battery for 15min to reset the long term fuel but your "lucky" like me and have a dumb as f*ck ME3.8.3 Ecu.
    These reset the fuel trims everytime the car switches off, so your car probably runs fine when you first turn her on, once the o2 sensor warms up fuel trims come into play.
    If you can't move the o2 sensor I guess you'll have to wait till the tune can be leaned out and/or target AFR voltage changed.
    Jay A3 likes this.
  35. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 26, 2014]
    Sounds about right antwan. It doesn't smoke till the sensor is warmed up a little. I haven't checked the plugs and will do this week. Yeh deffo can't move the sensor position so it may be I just wait till the map.
  36. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Aug 29, 2014]
    Last piece to the puzzle
    Sourced saab redtop injectors as my current calibra yellow tops will max out.
    Stuck them in an ultrasonic cleaner for a few cycles and job done.
    Part number: 0280150431
    All I have to do now is wait for map day...
    influxrye and MIGGZ like this.
  37. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Sep 1, 2014]
    Day 1... I will just leave this here
    superkarl likes this.
  38. StaceyS3
    Offline
    StaceyS3 Well-Known Member
    Dec 17, 2010
    2,194
    234
    [Sep 1, 2014]
    Top work jay!
    Didnt realise this was your thread, scrolled past it god knows how many times but thought it wasnt you as wasnt white lol
    Look forward to the finished product :)
    Jay A3 likes this.
  39. Jay A3
    Offline
    Jay A3 More power
    Mar 5, 2011
    1,953
    265
    [Sep 1, 2014]
    Haha it's been around for a while now! Not sure there is going to be much more development on 289bhp. Got 307bhp injectors are at max and fuelling was disappearing too quick. Need to look at some 440s...
  40. StaceyS3
    Offline
    Dec 17, 2010
    2,194
    234
    [Sep 1, 2014]
    Still top result mate
    Shows how much attention to detail us fellas pay ey, just like when the mrs gets her hair cut lol
    In fairness had scrolled past it god knows how many times but theres lots of users with variations of Jay A3 ;)
    Really need to get my arse in gear and catch uo with everyone
    Jay A3 likes this.
