Soooo.
I have been getting a small coolant loss, 1 litre every 1000 miles or so. The low level light has never come on, the heaters are up to temp and the climate works, never gone above 90*.
Today on the way home I had a slightly weird experience, with gently pulling away in first the car went like **** then I backed off, I never asked it to go like that but it just took off.
After this the car felt slow, and I was convinced I had a boost leak and the car had over boosted. I popped the bonnet and it was hot as **** and the coolant tank was bubbling and had nothing in it. I gently let off the cap and all hell broke lose, the car threw about three litres of boiling coolant out.
Very strange.
I refilled and started the car and heard a chattering from the bottom end, immediately I suspected the water pump had sheered. But then I remembered it is a metal one :/
There is no flow in the header tank, the water is just stagnant.
There is a little mayo in the filler cap for the oil.
I took the car for a short drive and it feels down on power until you give it full beans, then it is fine. Doesn't over heat at all, blowers on or off.
So, any suggestions?
Very strange.
