Jardo's 'Journey to quattro' - My Story...
16Klappe Sep 17, 2011
Thread Status:
Not open for further replies.
  1. Prawn
    11,581
    3,549
    A lot like Jardo then :laugh: you'll get on well!
  2. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    Impressive figures, one question are you still on the original clutch or has this been upgraded? Interested to know what the TI will do to life of the clutch.
  3. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    I have VR6 clutch and an ABF flywheel, however the original clutch had done 110K and three years worth of being 200bhp 290lbft+ and only gave up after I put the FMIC on. The pressure plat was glazed and over heated, the friction plate was visually fine.
  4. jojo
    28,935
    3,587
    It's ok I guess.
  5. Prawn
    11,581
    3,549
    :keule::banghead::rtfm:
  6. s3clarke
    s3clarke Money grabbing s3!
    677
    35
  7. 16Klappe
    5,795
    1,186
    When I told everyone that my car made 314lbft I think we might have got our wires crossed.
    Lbft doesn't actually refer to the torque; what I meant was "little bits, formerly transmission."
    On the plus side; Phil and I were right after all.
  8. Prawn
    11,581
    3,549
    You appear to have stolen my witty quote!
  9. Powelly
    Powelly Member
    85
    Diff rivets gone?
  10. Lewis583
    956
    91
    Hmmmm, limited slip diff time Jardo?
  11. 16Klappe
    5,795
    1,186
    No diff yet, I was toying with the idea but it can wait. Polybushing and brakes first :)
    I think what has happened is that the hard casing on the gears has worn away, hence the super fine swarf and small chunks.
    The oil wasn't that bad, but now it is changed it sounds SO bad.
  12. 16Klappe
    5,795
    1,186
    Old gearbox oil was rather metallic and full of water :(
  13. Prawn
    11,581
    3,549
  14. vanilla_ice
    vanilla_ice Active Member
    713
    Is that the same as the Awesome kit that Westy bought?
  15. 16Klappe
    5,795
    1,186
  16. Lewis583
    956
    91
    Was the clutch not changed recently Jardo? I'm guessing standard spec parts went in when it was done :slapped:
    **** luck with the box though bud. I would guess that the water would cause the increase in wear and I can't help but wonder how it got in there in the first place? You been pretending it's a Landy? lol
  17. 16Klappe
    5,795
    1,186
    Yup, clutch was changed in December for a VR6 clutch and single mass G60 flywheel.
    I will just get a paddle clutch like Prawn has linked to.
    Ordered up the polybushes for the front lower arms and the front dogbone bush, the rear dogbone was changed last night and the gearbox mount is left to do.
  18. harvey01
    harvey01 Member
    523
    9
    i had a clutch from this lot on my evo very good bit of kit
  19. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Yo dude, dont worry we will beat our time for the clutch change, im gonna ramp up the pressure and say
    same place as last time
    box out
    clutch replaced
    back together
    and road testing
    within
    2 hours 30 mins :)
    talk about pressure, but tbh thats a very doable time dude :)
  20. Sam_
    Sam_ Down under
    3,038
    480
    That glove in the oil probably doesn't help...
  21. 16Klappe
    5,795
    1,186
    Spent a few hours in the units at work with a rotary to bring it back up to scratch after the bad weather.
  22. jojo
    28,935
    3,587
    I'm surprised your car still has paint left Jardoooooo.
    MIGGZ likes this.
  23. s3clarke
    677
    35
    it does look good tbf
  24. 16Klappe
    5,795
    1,186
    Non-metallic black ftw. Thanks Clarke :)
    Just ordered Powerflex front and rear lower arm bushes, Powerflex front dogbone bush, engine and gearbox mounts, Powerflex steering rack bush, Powerflex rear axle bushes, a tube of Tiger Seal and a set of mats.
    Cheers Amazon.
  25. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    soooooo much love here! but we need pics lol
  26. Prawn
    11,581
    3,549
    Phil Miller: you have much work to do
  27. JudderMan
    JudderMan Well-Known Member
    1,010
    168
    Excuse my French, but Jardo that looks the f**kin' tits! :)
    Every time I go out my paintwork seems to be worse everyday. Bloody salty roads.
  28. s3clarke
    677
    35
    Non metallic blacks the best. I love the old Rs turbos in black!
  29. jojo
    28,935
    3,587
    It's called Brilliant Black! :cool:
  30. 16Klappe
    5,795
    1,186
    I can't believe how much it's changed!
  31. 16Klappe
    5,795
    1,186
    Tiger sealed engine and gearbox mounts -
  32. phil miller
    1,211
    166
    Looking good dude, the bottom arm rear bushes should be a breeze to fit with a piece of wood and water pump pliers :)
  33. 16Klappe
    5,795
    1,186
    Do you think we could get the front dogbone bush done that way? I'm trying to think of something genius; currently my best thought is letting the car down on a piece of wood over it with the dogbone supported by a socket...Any thoughts?
  34. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Isnt the tiger seal going to transmit the vibrations to the cabin?
  35. 16Klappe
    5,795
    1,186
    Yes dear.
  36. 16Klappe
    5,795
    1,186
    New gearbox mount is loads better than what came out.
    The old mount wasn't actually that bad to be fair, it had the same sort of movement that the new one did before being filled. But the tiger seal has made a massive difference, car doesn't hop and skip when the wheels spin now which is great.
    Poor wet car :(
    Respraying the front bumper in the shed at the moment :)
  37. Westy
    Westy Well-Known Member
    17,443
    1,105
    Both my mounts were still in good shape after 123k miles. I've seen some come from cars with a lot less miles then mine and they've been dreadful. Gould could move it all about by hand!
  38. Dani_B19
    9,336
    391
    How much were the mounts jado and where from?
  39. <tuffty/>
    21,576
    4,048
    Tiger sealing the engine mounts is something I have been meaning to do for ages... bought a tube of the stuff last year when I got all the gear for my battery relocation... would ideally prefer to buy VT mounts but this could act as a stop gap...
    The THS ones I have were night and day different to the tired old ones I removed all those years ago but having driven a car with VT road mounts in I realise what I am missing out on and think my THS ones are a little tired now...
    Vibrations in the car from the VT road mounts isn't bad at all... Bill did a BT conversion on a Polo a while back and the VT comp mounts used on that were evil... most of the cabin noise a 4k rpm seemed to be vibrations... Hollies TT in contrast on VT road mounts was no worse than my THS but felt far more connected...
    This has moved its way up the todo list...
  40. Prawn
    11,581
    3,549
    Hmmmm. Jardo in good work shocker :laugh:
    well done chap if its working. I currently have ina track density engine mounts, but I'm not convinced they couldn't be better. Might inspect a spare std mount and see where you apply this tiger seal.
Thread Status:
