Jardo's 'Journey to quattro' - My Story...
16Klappe Sep 17, 2011
Thread Status:
Not open for further replies.
  1. BENJAMIN
    BENJAMIN Active Member
    503
    93
    They're about £65 iirc if you get an account with them Bill. They come with different inlets up to 6".
  2. paultownsend
    paultownsend Member
    140
    Jardo I'm picking up a filter Friday. Don't suppose you could post a link to the 86-70 reducer. I can't find one anywhere!
    As I have an AGU, to me your car is an inspiration. I'm on a value vs. performance mission and the mods you do fit the bill perfectly.
    Don't be disheartened by the acts of this drain on society. You have a cracking car that can embarrass and is probably more fun to drive than metal worth x20 more.
  3. Prawn
    11,370
    3,234
    His isn't an AGU though :laugh:
    Sorry. I'll get my coat..... :racer:
  4. Prawn
    11,370
    3,234
    Where's the update Boyo? I know you spent another day rolling around on the floor with Philler, there must be some pics worth uploading, as you sent me about 15 on whatsapp!
  5. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Rolling around on the floor with Jardo is now a weekly thing, :)
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Thanks Paul, means a lot :) If you have any questions feel free to pm me or ask, and I will get the info from Prawn haha :p
    There are some updates but only small.
    I re-routed my catch can to better suit the FMIC pipes.
    Phil cut an inch out of my exhaust -
    I hard wired in my Road Angel, to make my car like Prawns. And I got Phils kids to clean my interior.
  7. Sam_
    Sam_ Down under
    3,034
    478
    Tidy. Have you plumbed your catch can back into the TIP? Looks like its bypassed? Might be me...
  8. 16Klappe
    5,795
    1,183
    Still plumbed into the TIP for now, have got a bung for it and will plug the tip tonight. Was kind of an after thought yesterday and I forgot the bung haha.
  9. phil miller
    1,211
    166
    I might have to let Lila clean Ron, with your guidance she has done a very good job, although your car is span kin inside :)
  10. Prawn
    11,370
    3,234
    Epic catch can fail there :laugh:
    Lower crank breather is venting into the can, but the rocker cover breather is venting straight back into the TIP dear boy.
    Remember what I said: before messing with things, learn and understand the system and where stuff flows and why, then it'll become pretty obvious what you've done wrong.
    As you have it in the pics above is very wrong indeed.
  11. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    lol did not notice that
  12. 16Klappe
    5,795
    1,183
    That's the same way you routed it! The only thing I did was cut down two pipes and replace them with blue!
    If I plug the TIP and run the cam cover pipe straight to the can it will be fine anyway?
  13. MIGGZ
    1,461
    304
    um not if your can does not have a 3rd pipe? as all you doing is venting the block and head into eachother
  14. Gizmo20VT
    Gizmo20VT Active Member
    294
    Yip, your motor will not breathe if your can is sealed, You could always just add a filter to the top of the can, use the one port for block, and the other for valve cover.
    Edit: Or you could link your block and valve cover into one port of the Catch Can and put a filter on the other port.
  15. MIGGZ
    1,461
    304
    like so
    only thing about having the filter in the engine bay you smell the oil when the car is hot. better to link head and block into 1 then move the breather to the back of the car and block off the tip side ot the hockey puk
  16. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    I did a bit of a half hearted catch can set up... i blanked off the tip inlet and re routed the pipe that goes to the hockey puck into the catch can. the outlet from the can just vents to the bay... no smell at all and no mess. wierd but it works .
  17. MIGGZ
    1,461
    304
    i vented mine with a filter and i could smell it when i stoped at a traffic light now iv moved it to the back of the car no issues
  18. Prawn
    11,370
    3,234
    It's not the way I routed it at all mate. You've taken some pipes off and put them back on the wrong way round.
    Like I said, understand the system and it'll all make sense.
  19. Prawn
    11,370
    3,234
    this is how i did it for reference:
  20. MIGGZ
    1,461
    304
    spark-plug ftw
  21. Prawn
    11,370
    3,234
    I also bolted it to something :laugh: rather than hanging in mid air ;)
  22. Scullies
    Scullies Well-Known Member
    1,543
    657
    Prawn is that spare spark plug there just in case :laugh:
    I vented my catch can to atmosphere, fitted a small breather filter and fitted the filter inside the stock air box below the drop in filter.
    Plan is to fit it near the cone filter on the BT setup, cold side of the heat shield.
  23. Sam_
    Sam_ Down under
    3,034
    478
    It's a flamer kit ;)
  24. MIGGZ
    1,461
    304
    Hahahahhahahahahahahah I rolled my car laughing now!
  25. Prawn
    11,370
    3,234
  26. MIGGZ
    1,461
    304
    Its cos of the plug buddy!
    Well jardo does not wana comment so we will up this threads post count!
  27. Prawn
    11,370
    3,234
  28. Prawn
    11,370
    3,234
  29. Prawn
    11,370
    3,234
    arn't I nice :laugh:
    Has this been on the dyno yet J-rod?
    StaceyS3 likes this.
  30. MIGGZ
    1,461
    304
    Lmao what a guy!!!!
    Nick you can do that to my thread it looks sad only me commenting
  31. 16Klappe
    5,795
    1,183
    There is no dyno in the land capable of assessing the power this car has, last time I put it on a dyno it just tore the thing out of the ground.
  32. Gizmo20VT
    294
    Is the chassis ok?? :lmfao:
  33. MIGGZ
    1,461
    304
    Imagine how it will rip out the tar once you running stage 2
    Gizmo's fav line " give me enough traction and ill spin the world faster! "
  34. 16Klappe
    5,795
    1,183
    I am not going to go stage 2, it's over rated. Just going to stick at stage 1 haha
  35. smurfworth
    smurfworth Well-Known Member Audi S3
    1,906
    528
  36. 16Klappe
    5,795
    1,183
    It is just flash photography on nappa leather seats, they are mint.
    I already use Glyptone which in my experience is better than anything else on the market. They smell so good haha.
  37. 16Klappe
    5,795
    1,183
    New mods, quick video.
  38. 16Klappe
    5,795
    1,183
    Old A3 is still doing the rounds, poor thing :(
    audi a3 1.8 turbo 230bhp not s3 track race px swop | eBay
    It's slipped so far down the food chain now, can't believe it's had three chavy scrote owners since I sold it and has slowly but surely been driven further and further into the ground.
    I hope it doesn't get broken this time. :(
  39. smurfworth
    1,906
    528
    Tbh looks a shed compared to when u had it. It's still gotta be one of the fastest a3's in the world right especially running over 30 psi was it?
  40. Prawn
    11,370
    3,234
    I think the old banger needs to turn over and die already.
    As a road car, it's knackered.
    As a track car, there's still some potential there, but it needs a lot of TLC before it'll be any good again, although the base of decent parts are still there on the whole.
    Shame really, used to be a really nice car 4-5 years ago
Thread Status:
