Jammed wipers
stuhow3361 Aug 11, 2013
  1. stuhow3361
    stuhow3361 Member
    210
    14
    Hi,just spent a couple of hours stripping my front wiper linkage to find the driver side was totally solid.After attempting to drift it out with a hammer and loads of wd40 i had to use a blow lamp which worked fine.My problem is that on re-assembly the driver side wiper blade now holds off the windscreen at about half stroke.I have taken all the bezels back off and tried adjusting the three linkage bolts with no success.Do you think that the initial attack with the hammer bent the linkage frame slightly.The spindle itself is ok since after cleaning and greasing it slid back into its housing perfectly.
  2. i had this i found the linkage was slightly out of shape because of the use of the hammer, i bent the bottom of the arm slightly to counter act it
  3. SuperV8
    SuperV8 Member
    70
    12
    Just done this myself, but when gently drifting out the spindle the aluminium bracket actually broke off!! Had to glue it back on, which actually worked well in the end. The brackets should be at 90 degs angle to the spindle. It should be easy to see if they are bent? Is the wiper arm seated on the spline of the spindle properly?
    Tom.
  4. stuhow3361
    stuhow3361 Member
    210
    14
    could it be possible that when i hit the top of the wiper retaining nut with a hammer to shock the arm loose it actually bent the body panel downwards where the linkage bolts to thus changing the spindle angle.
  5. Mike_B
    Mike_B Active Member
    533
    47
    Possibly. But that's a seriously strong bit of the car I'd have thought. I can't believe you did what you said you did though.
  6. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I doubt it - I also bent the wiper arm mechanism when removing the spindles.
    I gave up in the end and bought a 2nd hand one from ebay that was freely moving.
    I stripped this one down with ease and re-fitted.
  7. stuhow3361
    stuhow3361 Member
    210
    14
    sounds like i'll have to do this as well,tried numerous adjustments but the blade still lifts off the screen right in the middle of my sight line.
  8. stuhow3361
    stuhow3361 Member
    210
    14
    No other way to get them off.Tried a pullers initially but it only bent the frame as i tightened it.
  9. quattrojames
    14,050
    573
    I had this problem, albeit not after doing the mechanism, and I sorted it by bending the wiper arm slightly to apply more pressure to the screen in the middle.
  10. Mike_B
    533
    47
  11. stuhow3361
    stuhow3361 Member
    210
    14
    Tried this as well but it does not make much difference - looks like a new wiper mech for me.On a different subject you seem to be the guy in the know,i'm looking for a roof spoiler for my avant and have seen many aftermarket ones on e-bay.Any suggestions as to best fit or oem only.
  12. Mike_B
    533
    47
    Me? I can't help there I'm afraid but I guess there are plenty of far more knowledgeable folk who will know. Quite interested in the answer myself as it happens.
  13. quattrojames
    14,050
    573
