- Joined
- Jun 4, 2011
- Messages
- 1,001
- Reaction score
- 157
- Points
- 63
- Location
- Warham, Norfolk, United Kingdom
My belt split the other week and at the weekend I noticed the fan wasn't running (temp went above half way for the 1st time) So had a look and its got some belt wrapped in it. Tried pulling it out but no luck. The fan Is stiff but can be turned by hand. My mate says chances are the fans burnt out and I should order a new one??? Obviously it looks a big job to get to.
Running a scan I got this:
2 Faults Found:
006449 - Coolant Fan Control Module (J293)
P1931 - 009 - Malfunction
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 24
Reset counter: 40
Mileage: 152527 km
Time Indication: 0
Freeze Frame:
RPM: 2464 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 94.5°C
Part Throttle
Load: 18.4 %
Speed: 51.0 km/h
001152 - Coolant Fan Control Circuit 1
P0480 - 009 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00000100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 152750 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 54.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Readiness: 0000 0000
Question is: Do I need to be looking elsewhere first? Is the fan burnt out do you think? (50/50 I know, but don't want to strip it down to find it is and have no spare) does anything else need changing as well?
Vague I know, im not very mechanically minded so please bare with me .
The belt also knocked out the 5 flaps behind the radiator but I've been told by a mechanic it should be fine without them. Plus they're the least of the problem at the moment
Thank you
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 40
Mileage: 152527 km
Time Indication: 0
Freeze Frame:
RPM: 2464 /min
Temperature: 94.5°C
Part Throttle
Load: 18.4 %
Speed: 51.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 152750 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 54.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Thank you
