Jacking Up An A3
Smoothie Mar 3, 2011
  1. mike foster
    3,967
    Just as a matter of interest Nige, is the S3 chassis any different (in general terms) from the A3 ?
  2. tcardio
    tcardio Well-Known Member
    946
    267
  3. Harrelson
    Harrelson Member
    173
    You can jack up an A3 with a flat trolley jack. Had it done on my A3 on both front and rear by an Audi Tech
  4. mike foster
    3,967
    Got the bits today - needless to say typical VAG quality and fit perfectly !:thumbsup:
  5. NHN
    29,295
    1,701
    Pics.
  6. mike foster
    3,967
    Tomorrow mate - providing it stops raining !
  7. mike foster
    3,967
    As promised - here are the pics of the jacking pad install :-
    Pic 1 - The two parts
    Pic 2 - The removed cover plate
    Pic 3 - Install position
    Pic 4 - Installing the pads
    Pic 5 - Finished install
    Pic 6 - Being used
    Two things to bear in mind chaps.
    Once it's in it doesn't come out !!! - now I know why that website sells them in fours !!
    Finally, you can't replace the plastic cover plate 'cos the fixing hole is already in use !!!
    Total cost £5.44 and install time of approx 30 mins of which the first 15 were figuring out how to get the cover plate off. You just lever it with a big screwdriver !!
    Sorry about the pics guys but I'm not very good under a car - it's the arthritis you know !
    Lima likes this.
  8. brettp
    brettp Member
    95
    Sorry guys on this one, I sent Bero a message on DW and asked him if he was ok for me to post his email, he said that he wanted to post himself so that he could keep track of items and orders.
    If people are still interested I will get him to come over (again) Ive now subscribed to this to not miss anymore updates
  9. Agent_Trig
    Agent_Trig Member
    552
    To be honest mate, I think the above 'official' solution would be more ideal.
    I know it will be for me anyway - to have permanent trolley jack pads at the ready :)
  10. brettp
    brettp Member
    95
    Yeah that's no problem, I think that I am going to look at these also, just wanted to apologise also for not noticing the thread.
  11. NHN
    29,295
    1,701
    Thanks Mike, will be checking them out soon.
  12. mike foster
    3,967
    Ok mate - another thing - I didn't check the rears but I don't think there's a cover plate at the back. There is on the near side though, my pics are the drivers side.
    Just looked at the pics again - **** I forgot to rotate the last one !!!lol
  13. NHN
    29,295
    1,701
    Yeah I do actually recall some holes like your pics show, whether I'm confusing with the rear lower arm spring holes, who knows lol.
  14. brough74
    brough74 Member
    423
    22
    I bought a rubber pad off ebay and then cut a slot in it with a grinder and chisel so it will still lift the car but not flatten the lip, or it could be used for the locations mentioned
  15. Agric04
    Agric04 Member VCDS Map User
    288
    Ordered my Audi jack points today 
  16. dantdi
    dantdi ...
    519
    Cheers for the part numbers Mike Foster.
    Got set jack pads today.
  17. mike foster
    3,967
    You're welcome - glad to be of assistance :icon_thumright:
  18. fuzion
    fuzion Active Member
    225
    150
    43
  19. Agric04
    288
    I've just fitted the genuine Audi jacking points to my 2001 S3 8L, easy enough to fit, I used a bit of soapy solution and the piston out of an old brake caliper to help press them into place. I paid £18.12 in total for all 4 mounts from Boston Audi. Below are the pictures of my install:
    Could someone please reassure me that I am jacking the car up in the correct place. I have fitted all my mounting points and although the rear points seem nice and strong the front points don't inspire me with confidence. The front hole where these fit into looks to buckle in when you put the full weight of the car on them. I have no fancy plastic cover underneath my 8L unlike the 8P's so it's easy to see if the under pan is flexing.
  20. mike foster
    3,967
    Better pics than mine mate ! Can't reassure you because I don't know about the 8L chassis.
    However, if the pads fitted tightly to start with but you can now twist them in the sockets then it would seem that they are 'made to fit' the holes you have used. As you have bungs in other holes then I would assume that if these were not the right holes, then they would have had bungs in as well !
  21. dantdi
    dantdi ...
    519
  22. owenjt
    owenjt Member
    118
    Is this right what it says in uk-mviks?
  23. TOM.S
    TOM.S Active Member Silver Supporter
    551
    110
    43
    lads dont meant to be rude .but all i see in here in this pic is a simple'' ice hockey puck'' with a big efin chunk being cut out of it.
    so you might as well manufacture theese for ur self.just buy a hockey puck and get some proper tools for the cutting part as its vulcanized ruber (quite strong)
  24. Agent_Trig
    Agent_Trig Member
    552
    This has got me thinking now....
    Can anyone on here confirm that they have jacked up their A3s with the pads without any bother to the floorpan? I bought some the other week but yet to try them out.
  25. NHN
    29,295
    1,701
    TBH it stands to reason tbh, if that areas not reinforced then it can cause deformity, I'm steering clear.
  26. Agent_Trig
    Agent_Trig Member
    552
    So if you wanted to jack up the front of your A3 with a trolley jack and put it on stands, how would you go about it?
  27. 1inchpunch
    1inchpunch Member
    451
    I jacked my car up by putting the jack just past the seam. I use a rubber pad that is actually an old rubber CD wallet that is about 3cm thick. Done one side, slipped an axle stand in then did the other side. The trouble I had was that the road outside my garage appears to be soft as pudding as the axle stands had dug into the road when I went to remove them 2 hours later.
  28. Agent_Trig
    Agent_Trig Member
    552
    What jack did you use Paul, and when you say just past the seam, where do you mean exactly in relation to the jacking notch recommended for the standard scissor jack?
  29. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Sorry to bring this thread back to life Mike,
    Going to order these as like many others, I damaged the vertical jack points using a trolley jack. Lucky I got side skirts so it does not show.
    Question is, when I give my dealer the part numbers you kindly supplied, do I order two of each, one for drivers and one for passenger?
    Also would these be the same for the rear?
    Until they arrive, if I remove the trim as you showed, do you or anyone else thing I would be ok using a bit of wood on that point just as a temporary measure.
    Many thans
  30. mike foster
    3,967
    Forgotten about this thread !!
    Yes, you need two of each. As you will see from the photos one part actually goes inside the other and then into the jacking point.
    As far as I'm aware the rears are the same although I haven't got them.
    Once the cover is removed you can use that jacking point with a block of wood or something provided it seats properly on the jacking point.
    One thing to bear in mind is that you should really jack up both sides at the same time (presumably using two jacks) to ensure that you don't twist the chassis too much.
    Good luck.
  31. Dannykn9
    1,123
    56
    Many thanks Mike,
    Thanks for the quick reply.
  32. WAFTER
    WAFTER Member
    281
    19
    I solved this problem years ago and used on many cars. First a hard block of rubber placed on the jack cradle. ( several layers of rubber mat sections gaffer taped together works for a while ). Then using a section of old rubber pipe ( the cold/hot flexible pipes used for washing machines is ideal ) cut lengthways and slid over the seam. What is mega sad I have made a set of 4 using red washing machine pipe and they are permanently in place at the jacking points.
  33. moag
    moag she's no d-turbo
    821
    35
    2x4 with a groove cut in it for the jacking point. job done
  34. Schlaag
    Schlaag Bwah
    472
    32
    any idea if these will fit an 8L s3?
  35. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Far simpler and cheaper way is, use a small block of wood in conjunction with flat topped/padded jack.
    Works for me every time on the GTi or A3.
    Ollie2014 likes this.
  36. Synchromesh
    Synchromesh :-)
    98
    I just use the points described in the manual (I don't use the standard jack though, that thing is scary)... I've done this many times and my sills are still perfect.
    On a related note, can someone point out where I should put the jack stands at the back of an a3?
  37. SootySport
    SootySport Well-Known Member Team Silver
    2,633
    682
    This method is what I use. It's the simplest and cheapest and can be used on all the VAG range of cars.
