Jacking Points!
AS3TOM Mar 7, 2009
  1. AS3TOM
    AS3TOM Member
    190
    Hiya guys, just wondering if one of you knowledgable lot can help me out here.
    I need to take the wheels of but i'm scratching my head a bit as to where the best place to jack the car up is on each corner?:search:
    Dont want to risk causing any damage, so if ya can shed some light on this for me, cheers! :beerchug:
  2. fingermouse
    fingermouse thats me
    4,027
    120
    I never use the std jacking points, for the front I jack where the rear inner bolt is that holds the front lower arm. The rear I think I use where the trailing arm fixed to the chassis I`d have to look to be sure Its a automatic thing.
  3. swatchuk
    swatchuk Member
    313
    14
    The standard jack goes on a lip under the car at either end. Or if your using a troley jack any solid part of the chasis is good
  4. HTC
    HTC Active Member
    3,428
    9
    When using the standard jack, place a piece of rag between the jack and sill. It's easy to damage the underseal.
  5. AS3TOM
    AS3TOM Member
    190
    Thanks guys, i wont be using the standard jack that comes with the car, i'm going to be using a trolley jack!
  6. 1animal1
    9,978
    yup and dont use the chassis as the long square columns just collapse:ohmy:
  7. Raggy A4
    Raggy A4 Vorsprung Durch Tecnik
    41
    And just incace it all goes tits up, place the space saver under the car......just incase lol
