I've not found the A4 convertible comfortable?
AudiSport May 1, 2010
  1. AudiSport
    AudiSport Member
    509
    I've tried a few A4 convertibles and found the vision a little restricted due to the low windscreen! I've made sure the seat is as low as it will go - but the sun visors just seem to obstruct my view?
    I'm 6ft 2'' so not over tall... Has anyone else found this problem?
  2. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I am 6ft 4 and my car is very comfortable
  3. drewbee
    drewbee Member
    196
    same, mines pretty good too
  4. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    im only 5'10" but i find that the seats are really low ! and allow plenty of depth for alot taller person.
    seams strange at only 6'2" that your to high.
    are you sure your seat is going all the way down ?
    have you tried the passanger seat ?
    do you know anyone else with a cab to try.
    do you have full eleccy seats ? im woundering if this would be a reason for the seat not going down as much as a manual seat would, just a thought .
  5. markyzs180
    markyzs180 Member
    543
    i'm 6'1" and mine were fine, in fact i found them a little too low at their lowest! (too many years driving transits and ford d series wagons!)
    as 1wheel said are you sure they are set properly? if you've got full leccy you may find that all you've done is adjusted the tilt and not the height?
