I've lost first
ScottD3 Sep 19, 2013
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    Car: Audi A4 B5 TDI Auto Avant 98
    Engine: 1.9 TDI AFN
    Gearbox: 4 speed auto DMX
    Got in the car this morning, put it in to drive and pulled away.
    It was slow and felt like it was lacking power.
    At first I thought I've lost boost again but bit further up the road it started to pick up and accelerated fine with out any issues.
    3 more miles in to my trip to work and I've worked out that the box is not dropping down in to first.
    It seems to sit in 2nd. If I manually pick 1st there is a bit of a jerk and I pull away properly, nice and strong no extra revs needed.
    Bit more playing about it and its definitely not dropping in to 1st when I stop.
    I can drive the car but every time I'm going to pull away I got to drop it in to first manually.
    No ideal but it will have to do for now.
    Possibly just pure coincidence but might worth mentioning.
    Last night was a doing a full scan and error clear with VCDS. It did the first scan, then a clear and half way through the rescan the laptop turned it self off. No sure if this is anything to do with my current issue or not.
    I will charge the laptop up, I might even run the extension lead out to the car and do another scan and see if anything is displayed. I'll also check the message blocks on the box and see if it helps identify what's going on.
    Has any one got any idea?
    I wonder if this is the end of my box :(
  2. Bradderz_1988
    3,958
    240
    Yay......5 speed upgrade time !!!
    Sorry just had too !!
    do these boxes have a hydralic block with electrovalves ?? Sounds like one of them may have gone down ??
  3. ScottD3
    15,164
    1,123
    Yup 5 speed but then I would need new shifter, TCU to go with the box.
    No idea what they got.
    I don't know much about these boxes.
  4. jbh
    jbh TDi lover
    1,412
    168
    hmmm ive got a 5 speed box sitting? ive also got a good dual mass and clutch.. saying that if I was converting one from auto to manual I would be tempted to go down the solid flywheel road..
    on a serious note though Scott ive never really dealt much with auto boxes and ive picked up a few E30's with auto box problems and ive ripped it out and stuck in an extra peddle. it was the cheaper option..
    My mate Malcolm he has a lovely 325i cabby which had an auto problem but he was wanting to keep it original he went to a gear box specialist and they advised him to source a replacement as it would cost more than the cars worth to repair the box. ( that went against the grain when he asked me to refit an auto box )
    has you're box got any electrical switches on it? IE sport mode, economy mode?
    sometimes you could be lucky and it could be the ecu playing up. other times a fluid change might help any further and it leads in to big money.
    that's when you're either trying to get a good auto box or fitting an extra peddle.
    is the passat shifter the same? would a passat peddle box work? you any ideas on this? I might be breaking a TDi passat soon but its not a definite as it might get saved. I do have a good 5 speed box sitting still with shifter attached from a TDi passat.
  5. Broken Byzan
    13,237
    465
    need to re check that fluid i recon
  6. ScottD3
    15,164
    1,123
    I wont ever convert this car to a manual. I like the Auto to much.
    When I said 5 speed, I mean 5 speed auto.
    The gear box was serviced about year or so ago.
    It might be worth doing it again cause Its not that much but then its £100ish I can put towards another box if this one fails.
    If I need to replace the box I would like to fix a 5 speed auto but I think fitting the wires, plugs, TCU and select might be a little bit to much money and time on a car that I need daily?
  7. jbh
    jbh TDi lover
    1,412
    168
    ohh... me bad..
    as said check the oil condition and level. it could be as simple as this.
  8. Sulli79
    Sulli79 Active Member
    541
    37
    X2 oh and change the filter too.
  9. ScottD3
    15,164
    1,123
    The box was serviced about 12 months ago with new oil and filter.
  10. jbh
    jbh TDi lover
    1,412
    168
    could be worth checking the level Scott there could be a leak. you never know.
    we had an old m535 that used to loose ATF it would do it over time and no one could find the leak as it never left any drips.
    turned out it was only leaking when under load and was from one of the pipes running to the oil cooler
  11. Sulli79
    541
    37
    What oil was used? Auto boxes can be pretty temperamental
  12. ScottD3
    15,164
    1,123
    Don't you have to remove some bolt on the box and the oil level should be just under the bolt line?
    No idea.
    My regular garage recommend a transmission specialist near me. So I went there.
  13. jbh
    jbh TDi lover
    1,412
    168
  14. ScottD3
    15,164
    1,123
    BMWs had that and it was brilliant.
    Its all this sealed for life ****.
    My plan of action is to get home and scan it with VCDS, see what that says about the box and check the oil some how. Its not something I can do in my parking space.
    If that all appears fine, no codes and I still got the issue. I'll take the car to a transmission place next week (I'm on holiday) and see what they say.
    If its a new box situation then I think I'm going to look at a refurbished unit or getting mine refurbished. all depending on costs.
    I'm not massively keen on buying a second hand unit just in cause it lasts 6 months and I'm back where I am now.
  15. jbh
    jbh TDi lover
    1,412
    168
    yea the older BMW's had them but even there newer stuff is starting this sealed for life ****..
    I converted a boys 740 to manual a few years back as the auto box was playing up.
    that was box related as it would be fine for the first 50 miles or so then would start playing up. I managed to change the ATF and it was still playing up.
    we couldn't source a second hand box at a sensible price so it got an extra peddle. it was a fair carry on getting a conversion kit put together for it.. but boy it was certainly worth while as it was really fun to drive afterwards
  16. Bradderz_1988
    3,958
    240
    I now on the AL4 citroen/peugeot auto's you have two drain plugs, remove both to drain insert inner and outer plug back in then fill with oil run upto 80'c (gearbox) then remove the outer plug iirc to drain the excess fluid out at temp whilst its running !! Doubt your german auto will be like the **** french one lol but they are notorious for electrovalves going causing them to stick in certain gears !!
  17. ScottD3
    15,164
    1,123
    I thought it was only one on theses?
    On the side with some special VAG tool?
  18. ScottD3
    15,164
    1,123
    I fixed it!! :thumbsup:
    Did a scan on the auto box and there was one error code.
    I forgot to take down the exact error code but it was about talking about not communication to the speed sensor in the gear box.
    Cleared the code, went for a drive and all appeared well.
    I'll keep an eye on that code just in case it comes back but I got a feeling it was down to the laptop crashing mid scan last night. I hope its that and not my speed sensor or cable failing. TIme will tell I guess.
    But for now I have 100% clean scans (The TV Tuner don't count).
    Thursday,19,September,2013,17:39:32:27849
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: License Plate: AUDREY
    Chassis Type: XX (8D - Audi A4 B5 (1995 > 2001))
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    VIN: XXXXXXXXXXXXXXXXX
    Address 01: Engine Labels: Redir Fail!
    Part No: 038 906 018 S
    Component: 1,9l R4 EDC G60AG 1621
    Coding: 00001
    Shop #: WSC 06335
    VCID: 2645CBEEC28BC42ECEF-4B32
    No fault code found.
    Readiness: N/A
    Address 02: Auto Trans Labels: None
    Part No: 01N 927 733 CN
    Component: AG4 Getriebe 01N 3815
    Coding: 00000
    Shop #: WSC 00000
    VCID: 7F0B3E8A7D91B5E6ED9-0966
    Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
    Part No: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Shop #: BB 24548
    VCID: 5EB5A30EDA5B5CEEC6F-5178
    Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
    Part No: 8D0 820 043 P
    Component: A4 KLIMAAUTOMAT D56
    Coding: 00044
    Shop #: WSC 06325
    VCID: 2D5734C2E77DF7760F5-25BE
    Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
    Part No: 8D0 959 655 L
    Component: Airbag 7 Audi 0503
    Coding: 00106
    Shop #: WSC 06335
    VCID: 3F8B7E8A3D1175E6AD9-5196
    Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
    Part No: 8D0 920 980 J
    Component: B5-KOMBIINSTR. VDO D12
    Coding: 02440
    Shop #: WSC 19411
    VCID: 326D27BEFE43A88E527-5196
    XXXXXXXXXXXXXXXXX AUZ7Z0Y1725219
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D05
    Coding: 13163
    Shop #: WSC 06335
    VCID: 397F109223355BD693D-4F72
    Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
    Part No: 4B0 035 192 K
    Component: RNS 4.2 H06 BNO 0140
    VCID: 2547CCE2BF8DCF36C75-4B18
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00102
    Shop #: WSC 06335
    VCID: E0C91DF6602FEA1E743-4B7C
    Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
    Component: Radio BNO 0001
    Coding: 00206
    Shop #: WSC 76210
    VCID: 2547CCE2BF8DCF36C75-4B00
    Address 57: TV Tuner Labels: 4D0-919-146.clb
    Part No: 4D0 919 146 B
    Component: TV Tuner H05 0704
    Coding: 0000030
    Shop #: WSC 00000 000 00000
    VCID: 2859C5D6989FD25EFC3-5196
    4 Faults Found:
    00863 - Antenna 1 for TV (R55)
    011 - Open Circuit
    00864 - Antenna 2 for TV (R56)
    011 - Open Circuit
    00865 - Antenna 3 for TV (R57)
    011 - Open Circuit
    00866 - Antenna 4 for TV (R58)
    011 - Open Circuit
    End ---------------------------------------------------------------------​
    PAULF and Broken Byzan like this.
  19. jbh
    jbh TDi lover
    1,412
    168
    good news Scott. I hope it has just been a case of the laptop crashing mid scan. stranger things have happened though.
  20. ScottD3
    15,164
    1,123
    Dang
  21. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,939
    735
    This is why I don''t like knocked off copies of VCDS (Not suggesting for one minute that is what your using scott) but it goes to show even genuine copies could do some damage if things go wrong. Glad you go it sorted.:thumbsup:
  22. ScottD3
    15,164
    1,123
    It looks like its a proper error not caused my laptop restarting.
    Removing that error and the box works fine.
    When the error comes back the box is stuck in 3rd gear.
    I'm impressed that the car can pull away in 3rd.
  23. jbh
    jbh TDi lover
    1,412
    168
    ohh not handy.
    I had an old 1.7tdi cavalier that the linkage went on and I had to drive it nearly 200 miles using 3rd and 4th.. It managed it and I was surprised it got me home
  24. aragorn
    18,544
    865
    Sorry but knocked off VCDS or not, an aborted scan on the diagnostic interface isnt going to cause the autobox or anything else drop into limp mode.
    Its a real fault, and needs fixed.
    Check the wiring connector for corrosion first off!
  25. ScottD3
    15,164
    1,123
    I've had VCDS crash my HVAC before. That was genuine.
    That's my task today. Find the sensor, strip the plug and clean and see what happens.
    https://www.dropbox.com/s/hx374fq76vpxue1/01N Location.xps
    Page 12 fig 9.
    I'm doing that this weekend.
  26. ScottD3
    15,164
    1,123
    I've just ordered a new sensor as well.
    I'll collect it tomorrow, so if the clean don't work I can bolt the new sensor in.
    Hopefully that will be it.
  27. Tom_B
    Tom_B Member
    296
    20
    Not quite on topic - but as an interested slush box driver - what flywheel set up do autos have?
  28. aragorn
    18,544
    865
    they have a flex plate and a torque converter, no flywheel.
    Tom_B likes this.
  29. ScottD3
    15,164
    1,123
    I fixed it.
    WooHoo.
    FItted a new G38 sensor, cleared the code and it all worked fine.
    Gear change has smoothed out, it seems more responsive on pull away.
    If your box is getting jerky, I would recommend replacing the Speed sensor.
    I'm going to replace the other one in the next couple of months.
  30. adamss24
    adamss24 Well-Known Member
    4,584
    407
    If you ever think about that 5 speed auto conversion i have a fully working one of missus's a4 tdi. Only breaking for parts...everything available !
