Ive changed my HID bulbs and now one takes a few goes to come on????
S3 Paul Oct 28, 2011
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    I bought a pair of 6000k bulbs for my head lights and since fitting them the drivers one takes a a few turns on and off to come on.
    Is this down to the bulb or the balast pack on its way out??
  2. pangsterA3
    pangsterA3 Member
    143
    have you tried switching bulbs from side to side? - that would surely rule out the bulbs.. just a thought.
  3. Darren4
    Darren4 Member
    186
    Are you sure the connectors fitted in properly? Also do you get a warning bulb come on in the dashboard when u turn them on?
  4. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    It will be the ballast, Paul. If it was the bulb, it probably wouldn't light up at all. The ballast is intermittently failing to ignite, so will probably need to be replaced at some point. Same thing happened to the HIDS DIRECT 6000K D2S kit I fitted in my last car, ..used to have to switch lights off and on again to get my driver's side to light up. I swapped over to a kit from www.xenonshop.co.uk in the end and it was much better quality in every way and my Xenons never let me down again. HTH. Paula :wub: x
  5. Dani_B19
    9,365
    400
    Paul its common. All 8ls i know off with aftermarket bulbs do it. Mines the same and ive had mine in for the last 2 years, youll find it only happens this time of year when the temp starts to drop.
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    yeah mine do it every so often, a quick flick of the switch soon sorts it, annoying but you get used to it, mine are the same as paullies first ones too :whistle2:
  7. Rosso TT
    Rosso TT Member
    146
    Same here on my TT and yes, driver side as well.
  8. TwinCamMan
    TwinCamMan Member
    84
    Had the same problem with my wifes car, intermittent problem where one or other light wouldn't light up, every twenty goes or so, until one day one of the bulbs blew. Got a new set and just replaced the pair, as the light from the new bulbs were ever so slightly different from the old ones, and haven't had the problem since. So mightn't just be the ballast as suggested. You could just try the bulbs, they aren't that expensive and you'll probably need spare bulbs anyway at some stage.
  9. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    Defo the Ballast!
  10. Brendan12
    Brendan12 Member
    141
    My passenger side one does it all the time.
  11. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Paul - Where did you get the bulbs from?
    I have the same thing. I got 8000k bulbs off Ebay and they do the same thing, probably because they're a cheap brand. They've always done this for the past 2 years!
    Here's the trick.....
    Turn the switch on full to put headlights on, bulb warning thing will come up but ignore it, just leave the switch there in that position for 15secs, after 15secs turn switch 1 notch back to sidelights and flick back to headlights and watch how it will work :) Saves you flicking the switch on and off like crazy!
  12. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    I'm having the same issue mine on mine. Bought a pair from Ebay to and had to send 2 back for replacements! Same symptoms not coming on all the time and when they do eventually they flicker for about 5secs when they do turn on... Eventually they failed to come on at all when they do this. Getting tired of sending them back for replacements so bitten the bullet and bought some decent ones from: High Quality D2S Upgrade Xenon HID Headlight Bulb - 6000k...
    Last time I buy a cheap £20 pair from Ebay.
    PS Wasn't the ballast as tested my bulb on both sides...
  13. S3 Paul
    2,825
    107
    Thanks mate,
    I did this today and... it worked !
    Finaly i willnt look like a dogger looking for action when leaving a dark car park anymore !!
  14. jojo
    28,995
    3,641
    Just for reference, both S3's I have owned does this when it goes cold, I've found that if I fire the car up and let it idle for 10-15secs first before flicking the lights on usually lights up both sides.
