It's not my maf stalling me
hellierlee Feb 28, 2012
  1. hellierlee
    hellierlee New Member
    13
    Ok story goes- my 2004 Audi a4 1.8t was stalling when idle and I couldn't drive it at all. I unplugged the maf and it was ok on idle and I could drive. Therefore it led me to believe I had a faulty maf. I ordered a new one and it turned up today. So I got the old one out and put the new one in and plugged the electrics into it expecting to start the car and it be fine. But nope it does exactly the same as before just stalls on me so I unplugged it and started the car again and its fine so if it's not my maf what is it?
  2. simon.m
    simon.m Active Member
    2,747
    i dont no the name or if the 18t have it but my tdi has a sensor on the pipe that runs to the intercoler this is also to do with the air sistem there is a black pipe running along the back of the engine on mine gose from the turbo i think to the coller 2 screws holding it in very easy to see and clean/change if need be
  3. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    Map sensor
  4. simon.m
    2,747
    i maybe lol sure it can do the same problems though
  5. stu_m
    1,440
    yes wasnt there something someone posted that was similar?
  6. hellierlee
    13
    Yeah but why is it stalling when I'm plugging the maf in
  7. Pabs
    Pabs Active Member
    650
    54
    Have you had your car scanned, might give you a better idea where to look, does it stall straight away at idle or is it lumpy and then stalls?? maybe crankcase breather valve there is a recent thread about it, helped me out massively when i had a really lumpy idle, and saved me a fortune, these are a really commen fault on 1.8t's
  8. hellierlee
    13
    It's not straight away but within 5 secs. Starts getting lumpy then stalls
  9. quattrojames
    14,050
    576
    I know it's a cliche, but a VCDS scan really is the first place to start.
  10. pauldazzle
    pauldazzle Well-Known Member
    1,162
    86
    Is the new MAF a genuine VAG part? If it's aftermarket then there's the problem.
  11. marktdisport
    marktdisport Active Member
    1,195
    15
    scan it first...... theres been a few on here recently with crankcase breathers causing this sort of issue, but there also the throtle body cleaning and resetting which are all simple jobs and not to pricey
  12. Broken Byzan
    13,237
    465
    I had the same and it was a faulty NEW Bosch MAF, replaced the replacement and it's been good ever since
