Issues with a3 tdi sportback..........fault codes......please help!
vw754 Jan 18, 2010
  1. vw754
    vw754 vorsprung Durch Technik
    2,331
    58
    I'm in trouble...your advice please!
    Apart from the alarm going off and dash display showing the boot to be open,ive now got a couple of other issues.......when i switch on the ignition....only sometimes il get the dash lights turning on and off by themselves,sometimes when cars running theres no dash lights or heaters.
    Also when i turn the ignition on the fan kicks in,then go's off then on again randomly,also the handbrake light and the battery light constantly flash when ignition is on......any ideas?
  2. vw754
    2,331
    58
    Tuesday,19,January,2010,19:51:20:18030
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    VIN: WAUZZZ8P95
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Cannot be reached 1100
    09-Cent. Elect. -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Cannot be reached 1100
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Cannot be reached 1100
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 1110
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: Malfunction 1110
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC 0000SG 6337
    Revision: 12345678 Serial number: AUX7Z0E1FNG04N
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    1 Fault Found:
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 6.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00000100
    Bin. Bits: 00000000
    (no units): 144.0
    Readiness: 0 0 1 0 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023174
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory
    Address 08: Auto HVAC
    Cannot be reached
    Address 09: Cent. Elect.
    Cannot be reached
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 003620028UHP
    Coding: 0034622
    No fault code found.
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
    Component: KOMBIINSTR. VDO H73 0300
    Revision: D04 Serial number: 2241ED04006344
    Coding: 0004443
    Shop #: WSC 00047 210 62144
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500105208043E
    Coding: 3D3F0B42072103
    2 Faults Found:
    01336 - Data Bus for Comfort System
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 86
    Mileage: 133116 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 23:02:13
    00470 - Combination comfort Databus in Single Wire
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 133116 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 23:03:49
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D04 Serial number: AUX7Z0E1FNG04N
    Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.7 1502
    1 Fault Found:
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Mileage: 3080 km
    Temperature: 26.0°C
    Voltage: 13.10 V
    Voltage: 12.90 V
    Address 46: Central Conv.
    Cannot be reached
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH03 0180
    Revision: 00002 Serial number: 10000001230153
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3E2059450
    Coding: 0001001
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    00466 - Control Module for Steering Column Electronics (J527)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 86
    Mileage: 133092 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 21:07:25
    Freeze Frame:
    Bin. Bits: 10
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    Address 7D: Aux. Heat
    Cannot be reached
    End ---------------------------------------------------------------------
