ISO to Quadlock adaptor
rsb2486 Sep 19, 2011
  1. rsb2486
    rsb2486 New Member
    26
    Hi.. hoping someone can help!.
    I've bought a Dynavin headunit (dont shoot me!) but to complete the installation i need an adaptor of some sort which will convert my stock ISO cables into a quadlock connector so i can plug-in the dynavin. Anyone know where i can get one from?...
    Cheers!
  2. mike foster
    3,967
    A quick look on ebay mate and I found this :- Audi ISO harness wiring adapter lead CT20AU01 quadlock | eBay
    Any car audio place should fix you up !!
    You don't give any info about your car but presumably you already have a double din head unit (Symphony/concert) otherwise lots of other bits will be required !
  3. rsb2486
    rsb2486 New Member
    26
    ..what im after is something that will convert the audi iso cables/connectors into a male quadlock... its the opposite of the ebay thing, as the connection on the Dynavin is a female quadlock one. (hope this makes sense)
    oh car is a 56 plate sportback with symphony 2 cd changer unit and has a antenna on roof(if that helps)
  4. mike foster
    3,967
    Should be ok then - bear in mind it's worth checking these things before you buy in future !
  5. stevewushu
    stevewushu Member
    109
    On the same subject, I recently bought the wrong Dension gateway 100 (gw16ai2) for my S3 8L concert radio.
    Andymac said that my head unit is an ISO connection and this flavour Dension is for quad lock. So can I buy an adapter that connects to my iso that leaves a quad lock connection for my Dension to fit?
    (I know most of you wanna say "just sell the one you have and buy the right one" but I got this one free...)
  6. PhilPree
    PhilPree New Member
    14
    Hi I have also bought a dynavin does any one know if there is iso conector converters ? Thanks phil
  7. chale989
    chale989 Member
    79
    Did anyone ever find a place that sells iso to quadlock adapters? just upgraded to symphony 2+ and i need the cable
  8. mike foster
    3,967
  9. chale989
    chale989 Member
    79
    Hi mike thank you for the reply.
    Will this would as i have a 2005 a3 with symphony 2 (tape player aswell) to symphony 2+ 2007 onwards.
    I currently have iso connection but the new unit is quadlock.
  10. mike foster
    3,967
  11. chale989
    chale989 Member
    79
  12. mike foster
    3,967
    I'm not convinced there is any difference !
    Two black, one brown and one orange connector into quadlock. Take off your headunit and check the plug colours.
  13. chale989
    chale989 Member
    79
    i will take a photo of the back of old one for you but the quadlock end of the link i sent looks like it would fit exactly into my new one
  14. chale989
    chale989 Member
    79
    Pictures attached of current system(in black) and picture of system i hope to upgrade to(in white)
    Any help would be hugely appreciated.
  15. chale989
    chale989 Member
    79
    Is this what i need? [​IMG]
  16. mike foster
    3,967
    The plugs that currently go into the black (existing) unit should be coloured orange, brown and two black.
    They will go into the corresponding sockets in this adapter :- AUDI A3 A4 A6 TT ALLROAD RNS-E P&P Adapter QUADLOCK - ISO FAKRA CHORUS CONCERT | eBay
    and then the quadlock (square) connector goes into the white one. By the way, that picture of the white one shows and RSNe navigation unit !
    You don't need to worry about which plug is which because they will only go into the socket designed for them and will only go in one way round.
  17. chale989
    chale989 Member
    79
    thank you Mike.
    I will order this and hope it works.
  18. chale989
    chale989 Member
    79
    All ordered and fit fine but the player makes whiring noises but wont power on!
    any ideas?
    thank you
  19. chale989
    chale989 Member
    79
    If anyone knows the answer to this then it would be worth making a sticky as these threads keep popping up and this one alone has nearly 2k views
  20. MacrosTheBlack
    MacrosTheBlack Member
    212
    20
