Is this the recirc valve on an S3?
S3IZZO Mar 26, 2008
  1. S3IZZO
    S3IZZO Guest
    Looking round my engine trying to decide where the recirculating valve is located....is this it?
    Does anyone know what size the bolts are?
  2. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Yes mate, it is.
    5mm Allen wrench.
  3. S3IZZO
    S3IZZO Guest
    Cheers warren, I went for it last night anyway, the nuts were a star shape rather than the traditional hex.
    No splits in the valve :)
  4. warren_S5
    7,210
    2,488
    Well done, how did you find it (as a job to do)?
    I had to download the new Forge info off the net as the info in the box was for the 2.0TFSi (200PS) with the DV round the back. I haven't got the car here at present so had to refer to Forge instructions. Thinking back it wasn't a 5mm, I think it was a T25 star key!
  5. S3IZZO
    S3IZZO Guest
    Yes the 5mm allen nut you are refering to are the longer ones that forge send you with the upraded valve or the chavvy spacer thingie.
    It took me all in all about 5 mins, once you take it off the bracket access to the remaining 3 bolts is easy as it moves around relatively freely...much better than having it on the compressor housing as per the other 2.0T FSI's...makes changing it simple as come service time.
  6. newbiecrg
    newbiecrg windsurfer
    1,328
    star shaped... aren't they Pozidrv then?
    Pedro
  7. Savage
    Savage Savage
    68
    I think you'll find they're probably torx.
