Is this the outer cv joint leaking?
OVRA3 Sep 15, 2012
  1. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Hi all,
    Just doing my calipers and found oil behind the hub? Is this a leaky cv joint?
    It's the rubber bit directly behind the hub
  2. MTRL
    MTRL Split Grill!
    459
    52
    Is it oil or grease? While you have the wheel off you can check for a split.
  3. OVRA3
    1,079
    80
    I squeezed the rubber bit and air and grease came out so assuming its split? Is that the outer cv joint? Its collecting in the hub.. To be fair though it seemed like oil more than grease
  4. OVRA3
    1,079
    80
    Yuk! Guessing this is the outer cv boot is that right?
  5. bmh.01
    bmh.01 Member
    291
    17
    I'm afriad so. Looks to be split/damaged from that pic.
  6. MTRL
    MTRL Split Grill!
    459
    52
    Yep its split. Id recognise that ******* grease anywhere - my old enemy.
    Outer joint connects to the wheel end, inner to the gear box end.
    You going to change it yourself?
  7. OVRA3
    1,079
    80
    Having had it all over me no! I've got a mate who is a mechanic who said 55 quid and he will do it.. He'll pick the car up an drop off so can't grumble really.. That grease is a ***** to get off!
  8. Lewis583
    956
    91
    Yeah that grease is horrid stuff. I had to drop the shaft out when i did mine and put the shaft in a vice. They're not too bad a job
  9. OVRA3
    1,079
    80
    Hi all, where can i find the part number for one of these, my mate went to order one and it was £43??!!! So I am going to try and source one but I cant for the life of me find a part number?
    Anyone help with this?
  10. dex140
    dex140 Member
    223
    I have recently done mine... i did it with a stretch boot and i think it was around 15 quid......CV boots are more of a universal part i think!
