Is this the aircon button
audiv8quattro Jun 9, 2011
  1. audiv8quattro
    audiv8quattro Member
    443
    9
    Hi all my car has aircon well it has the aircon fan and regas valve and all the relevant aircon bits but is the button under the big square auto button the aircon button aims if so why when I press it it only lights up while the button is pushed in, as soon as I take my finger of the button it goes of, please excuse the bad pic and the state of the car it was after a long drive.
  2. aragorn
    18,543
    865
    yeh thats the AC button. If it doesnt stay on as you describe, it means theres a fault, probably high/low pressure.
  3. Bradderz_1988
    3,958
    240
    The econ button is for the air con when it's illuminated it puts the car in 'economy mode' for better fuel economy so the air con is off when it's not illuminated the air con is on. If it does kick the compressor in it may be there is not enough gas/pressure in the system for the pump to work correctly.
  4. Bradderz_1988
    3,958
    240
    *does not*
  5. audiv8quattro
    443
    9
    Cheers for the replys guys I was99% sure it was the aircon but just wanted to double check so a quik regas and should be fine hopefully, has anyone tried the regas kits you can buy at motorfactors for about 15 quid, are they any good
  6. Bradderz_1988
    3,958
    240
    Yes providing there's not a electrical fault on the system and I wouldnt no as I do it at work for now't lol but I'd think not as you have to extract the remains and vac test for any leaks then regas the system if no leaks try kwik fit !
  7. audiv8quattro
    443
    9
    Ok mate cheers I'll give them a call tomorrow thanks for replys
  8. Bradderz_1988
    3,958
    240
    Yours is the opposite to the econ button iirc yours should be lit when air con is on pic wouldn't load so just presumed it was the econ button lol
  9. aragorn
    18,543
    865
    Dont mess around with those stupid regas in a cans.
    Get the system properly evacuated, leak checked and recharged with the correct amount of gas.
  10. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    ^ +1
  11. audiv8quattro
    443
    9
    Ok will do that just going to kwick fit now there's one round the corner from me,cheers guys
  12. tangerinedream
    tangerinedream Member
    249
    avoid kwik fit get someone who actually cares about the work they do !!!
