Is this really normal?
J17_KNO Jun 23, 2013
  1. J17_KNO
    J17_KNO Member
    102
    Good evening folks,
    Had a wee shock today driving back from a weekend in Edinburgh, the "check your oil level" light came on (never happened to me before) Changed oil 6k ago (approx 3 months-ish).
    After finding a garage to top up with oil, I had a look at the book and it says Audi say roughly 1L per 1000 miles is normal. Now I know that some oil will be used but say for example a car on a long life service interval, would that not mean topping up 10L or so of oil between services? Don't get me wrong I know some oil does get used but can this be right?
    Forgot to say It is a diesel 170, but my mk4 diesel golf barely touched it's oil between 6k services.
    justin
  2. mdre83
    mdre83 Member
    634
    Hi Justin, I've got a 170 too, I've only ever had to top the oil up between services after some numpty never replaced the dip stick correctly.
  3. wuta3
    wuta3 Well-Known Member
    1,131
    347
    lol I have to put bang on 1L every 1000 miles (so much so, I use the dash mile counter for it)
  4. chinnyhill10
    chinnyhill10 Member
    151
    They all seem to be different. My mk5 Golf 140 went through phases of drinking oil> There was no rhyme or reason for it.
    Dunno about Audi, but with the MK5 Golf VW included a bottle of oil in the boot. That's what the little cubby hole was for. I always carried a litre with me in there. Would do with the Audi but there is no cubby hole.
  5. danb986
    danb986 In awe of VCDS Team Daytona
    523
    +1 what chinnyhill10 says.
    Some use loads of oil and some don't use any. We had a batch of A3 TDi's at work and some used oil and others didn't. It's all a bit weird, but nothing to worry about. Unless you start seeing patches on the floor or blue smoke from the exhaust.
  6. J17_KNO
    J17_KNO Member
    102
    Just out of interest what does blue smoke indicate? Heard of white smoke being bad but not heard about blue smoke?
  7. Matt A3
    Matt A3 New Member
    12
    Blue smoke means the engine is burning oil; while smoke usually means steam (i.e. the engine or exhaust has condensation in it and the heat is turning it into steam or if it goes on for a while the head gaskets gone and the engine is ingesting its own coolant...)
  8. TDI140
    TDI140 Well-Known Member
    1,632
    174
    Ive not had to replace mine and ive done 3000 miles since last oil and filter service, so get under you car and check sump plug also chek turbo oil feed pipe make sure thats not leaking
  9. Jack_tdi
    Jack_tdi Member
    287
    12
    You get a bottle with a brand new audi so there obviously ment to lose a bit. Don't worry and just do what the book says dont get anything changed or pay someone to look at it. There isn't a problem unless all you out in the top comes out the bottom 5 seconds later. :)
  10. hades-
    9,481
    646
    its normal
  11. fangio
    fangio Well-Known Member
    1,513
    180
  12. J17_KNO
    J17_KNO Member
    102
    i will get underneath tomorrow if I can and have a check.
    thanks for all the advice guys, was throwing my toys out the pram and looking to get it sold! ha ha I will remember to keep a litre in the boot just incase and check it more regular than I have been!
  13. wuta3
    1,131
    347
  14. fangio
    1,513
    180
    Not really, it just holds a litre bottle of oil! :undwech:
    (At least, mine does......)
