is this genuine?
Adam-D May 5, 2008
  1. Adam-D
    Adam-D Member
    457
  2. Siena
    Siena Active Member
    2,626
    It doesn't look like mine, so I'd say non-OEM.
    But, my car's pre-facelift, not sure if the design changed later on.
  3. Adam-D
    Adam-D Member
    457
    mine is prefacelift too,
    ill steer clear of that one then, how much are they -ish from audi? the rest and mounting bractry etc?
    really really need one, i mean, my mondeo has one and my audi does not, maddness i tell thee
  4. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    I can't stand my armrest, just gets in the way.
  5. aragorn
    18,537
    865
    you should arrange to swap your centre consoles then :p
  6. Adam-D
    Adam-D Member
    457
    i was thinking that.....
  7. Broken Byzan
    13,237
    465
    I found that they do get in the way some what, Mine spends most of its time up,unless i am stuck somewhere waiting in the car or spmething, then it comes down as its comfy to lean against
  8. Siena
    Siena Active Member
    2,626
    Mine's always in the "down" position, never been obtrusive at all.
  9. Broken Byzan
    13,237
    465
    Must depend on your driving position
  10. Road Razor
    Road Razor Member
    411
    I found the armrest obstructive when I tried it for the first time but I got used to it. It's stayed in the down position ever since. But it does somewhat makes me feel a bit laid back whilst driving.
  11. Blue_Thunder
    1,776
    33
    I find getting to the handbrake that's tricky... oh, and shifting into 2nd, 4th or 6th!
    @Adam-D: I've got a mushroom coloured interior, I'd be surprised if you have a matching one to swap!
  12. Adam-D
    Adam-D Member
    457
    my centre bit is black,... ahwell ill keep looking, consdering orsering it from audi.
  13. jcb
    jcb Active Member
    4,132
    13
    not genuine, mine is facelift and it doesnt look like that
  14. Adam-D
    Adam-D Member
    457
    what are the correct part numbers for the bits i need?
    ill just order it from audi
  15. 951
    951 Member
    530
    Post and pre facelift consoles are the same shape but the catch release is pull up on facelift and slide across on pre-facelift ,at least it was on the ones i had.
  16. PaulJC84
    PaulJC84 Owner
    2,919
    17
    Anyone got a pic of a facelift armrest?
    I just bought one but its a preface lift and think I would maybe rather have a facelift one. But I am not sure whether I can be bothered with the hassle of selling this one and sourcing a facelift.
  17. EnzoS4
    EnzoS4 Member
    200
    the armrest are more square than the one on ebay, also didn't know if there was a difference between armrest
    not sure if this is any good, but its all I got
  18. Blue_Thunder
    1,776
    33
    I've had both pre-facelift (S4) and post-facelift (RS4) and they are both the same shape and catch assembly.
    Enzo - loving those clean Recaros! Fancy swapping for black? ;)
  19. PaulJC84
    PaulJC84 Owner
    2,919
    17
    Mine is definitely genuine. Just can tell its the old type by the texture on the button.
    I think the only difference will be the button to open will be more like the type on the b6 and b7 shape ones where the button to open is bigger and a pull up not a slide along.
