Is this common knowledge?
SteveMcB May 9, 2013
  1. SteveMcB
    SteveMcB Well-Known Member Team Sepang Audi Cabriolet Owner Group SQ5 owners group
    756
    366
    Hi, I'm pretty new on here but I just discovered something about my air inake you may or maynot know about. Mine has a full service history and the air cleaner was changed fairly recently. I was having a look around trying to spot a coolant leak - see my other thread please if you are able to help, and ended up taking out the ducting leading from the grill to the air box. When I was reassembling I noticed a thin gauze mesh halfway down one of the pieces of duct which was clogged absolutely solid with fine dust, looked like years worth. At service the mechanic has either not known about this or hasn't bothered cleaning it out. I did clean it and am amazed in the difference in acceleration, it was mapped a few months back which made a big difference but cleaning this mesh feels like it's been mapped again, on a par with a mapped/sportcat subaru gb270 Wagon I used to own. Apologies if I'm preaching to the converted but It could be easily overlooked and effectively blocks the air intake, worth a check imo.
    Wrath and gen.heinz guderian like this.
  2. NOZ
    NOZ Active Member
    215
    any pictures would be great
  3. hades-
    9,482
    646
    take the mesh out
    the service lads usaly do
  4. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    I removed mine from the intake pipe...
  5. Steve220
    Steve220 Member
    234
    15
    Is it before the MAF? If so it's to maintain equal flow around it.
  6. Wrath
    Wrath Well-Known Member
    1,196
    42
    Pics would be good.
  7. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,599
    3,175
    Yes it is; it's in the join between two sections of inlet pipe, just behind the offside headlight. I discovered mine when changing a headlight bulb; cleaned it and put it back.
  8. Steve220
    Steve220 Member
    234
    15
    sounds like the best option to me!
  9. rizzini7
    rizzini7 Active Member VCDS Map User
    983
    156
    43
    Hmm, sure i didn't see one in mine the other week. Will have to go look again now
  10. Wrath
    1,196
    42
    My 2005 doesn't have any mesh in the snorkel part. The top of the air filter box has a thick plastic mesh stopping stuff going into the pipe. The heat shield is attached to the base of the air filter housing but the whole thing lifts out i.e. don't try and unscrewn the heat shield.
  11. Steve220
    Steve220 Member
    234
    15
    To be honest, the entire inlet system of the 2.0 tdi is incredibly asthmatic! I've been tempted to change it, then wake up and realise its only a commuter car.
  12. Andy27168
    Andy27168 Member
    131
    9
    Had exactly the same experience, had the car recently serviced at a local independant, and paid extra to have the filter changed, as it was,nt due, but as the car was new to me I thought I would, trying to change my sidelight bulbs to LED recently I had to remove the air intake and the plastic filter insert in the "snorkel" part of the intake was almost completely blocked, with a black dust which seemed to be encrusted on the mesh, I cleaned it and put it back in place, though I did,nt partculary notice any performance increase though it does seem to be slightly better on fuel now.
  13. SteveMcB
    756
    366
    Sorry, my PC is kaput, not got a clue how to post pics from the ipad, it's pretty easy to find though, I unscrewed the 2 bolts at the front and the 3 sections of duct came apart quite easily, it's easy to spot after that and just pops out for cleaning. I used the hoover but it looks as if it may be designed to be washed out, it will dry quickly. Mine is the 3.0tdi, not sure if he setup on the 2.0 is the same.
  14. mm707
    mm707 Member
    286
    I can't find this on mine, 2.0 tdi BRD 2007.
    I took out the plastic duct that goes from the grill to the air filter - 2 sections.
  15. Molnboman
    Molnboman Well-Known Member
    1,338
    194
  16. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Yes I have this on mine. I thought this is what this topic has been about all along?
  17. jdp1962
    8,599
    3,175
    Yup; we're talking about the same thing. :thumbsup:
  18. Molnboman
    1,338
    194
    Doh, sorry thought you were talking about a filter inside the middle of the two parts.....apologies.
    A
  19. Wrath
    1,196
    42
    So did I.
  20. hades-
    9,482
    646
    and me
  21. mm707
    mm707 Member
    286
    me too, I guess mine has been removed
  22. V.A.G.erbond
    V.A.G.erbond Spooling
    132
    Just checked mine haven't got one either
  23. seandom
    seandom Active Member
    136
    25
    Guys ideally you all need to replace this filter as I saw this thread and wondered if mine had one. I've not had my car very long so I thought I'd just check the air filter condition aswell. I noticed that the pre-filter had also been taken out of mine, which I wasn't too bothered about, but when I checked the main air filter I noticed that I'd had a mouse nesting inside. So although it may seem useless, Audi must have put the pre-filter inside to stop this sort of thing happening. So I'm just gonna replace mine and check it from time to time.
  24. MattUK
    MattUK Member
    97
    17
    This was a life saver for me.. When I flooded the car last week that filter stopped all the **** flowing straight into the air filter.. When we took it apart all the leafs and mud etc got stuck there. I washed it all out left it to dry and put it back in.
    All I was left with was a sodden/clean :) air filter..
    Worth having I would say
    cheers
    matt
    A4_MaJiK likes this.
  25. V.A.G.erbond
    132
    Gonna price this up from Tps
